Question about Garden
Need a new lawn mower! what would you buy? and why... thanks, jana I'm over and under whelmed depending on the marketing or consumer reviews I'm reading.
  • 2,841 Answers
Well I do now know if you want a riding mower and how much yard you are mowing. If you are mowing 1 acre or more and the land is fairly level I would recommend a Dixon or Bad Boy ZTR mower. The Bad Boy sells for $4,999 at Tractor Supply and is a well built heavy duty mower. The Dixon will be slightly cheaper and it also a quality mower. The Cub Cadet & Husqvarna are cheaply built mowers that sell for less but are not dependable. You get what you pay for. If you are looking for a push mower then the Cub Cadet is a decent mower for the price and the Honda is a top notch quality mower that sells for much more.
Posted on May 23, 2011
  • Garden Master
  • 2,046 Answers
If you have a small lawn you probably don't need an expensive mower. I just bought a cheap tractor because I am retired and have a half acre of grass and can't push any more. But if you have a larger lawn you should get a good one. Like they say you get what you pay for. There are a lot of good makes and prices out there.
Posted on Mar 18, 2015
My huskee 21 173CC OHV powermore push mower starts then stops. What could be wrong? I changed the spark plug and the air filter.
Cindy, try running with gas cap off , if it runs OK then the caps vent hole is plugged, either try and clean vent hole or replace cap. It could also be a dirty carburetor which would need torn down and cleaned/rebuilt. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Why Your Mower Won Start Mower Reviews Consumer Reports
Lawn Mower That Starts then Stalls
Lawn Mower Starts Then Stalls
Engine starts and then shuts down
Jun 25, 2016 | Garden
Is a d130 a durable mower or should i buy something else i heard bad reviews about todays john deere mowers
They get an awful lot of money for that green paint that makes them stand out from all the others. Look into Craftsman and other brands. Subscribe to Consumer Reports for a while.
Jul 30, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
Was mowing and the mower wouldn't let me move forward backward left or right. I walked behind the mower and found a coil with a hook piece underneth. Bought a new coil but don't know where it goes....
sounds like the hydro release rod, at back bott of mower, what this does is releases the hydro so you can push the mower around, then you have to release this and then your hydro works
Aug 02, 2011 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Pulled the cord out of the mower trying to get it back.
you have to remove the top of the mower and you may need to buy a new spring depending if it broke or not, then wind the spring up and slide the rope back through the holes and tie a knont in the rope and let the spring wind the rope back in. reassemble the top on to the engine.
Jun 16, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Honda lawn mower bent crankshaft repair
I would start by making sure the crankshaft is actually bent, as a pro I've owned Honda mowers and throught he years I've hit all kinds of things and have never bent the crankshaft of any mower, these were regular mowers not some super commercial model so get a second oppinion, if the crank is bent buy another mower as it's too expensive to fix and you will lose warranty anyway and then get rid of that stump!
Jun 24, 2010 | Garden
Poulan lawn mower, Briggs Stratton engine, revving problem
Most likely problem is dirt?moisture in the carburetor float bowl. You would have to remove the bowl, clean it out and also clean the main jet up in the center of the carburetor. Another problem could be that the governor is out of adjustment but this is not something a novice could or should do
Sep 12, 2009 | Poulan "Poulan" Push Mower
I would like to buy a petrol lawn mower, i have found out there are mulching lawn mowers on the market, what are your views on this type of mower
Mulching mowers are great if you dont have the time to rake the excess grass or the means ( time or ability) to dispose of te collected remains. The mower will mulch te grass right back over te top of the cut grass with minimal apperance of grass being left behind, if you kep up on the cutting schedule that is. Better for larger areas where "lines" would usually remaine with a non mulching mower.
Aug 11, 2009 | Black & Decker Black and Decker Mm575 18"...
Looking for a good lawn mower
Any mower will do the job if you keep the blade sharp and do your maintenance. But you cant go wrong with the big names.
Apr 23, 2009 | Mg International MasterCut 20" 123cc Push...
Replacement batterys for cmm1200 black&decker electric mower I have a Stealth Black & Decker rechargable mower and would like to know what battery I need and can I replace it myself Thanks Cherie
I discuss the solution to your problem in my review. I am using a replacement AGM Lead Acid battery that increased my mowing distance and does not take more power to charge because the battery has an lower internal resistance. The battery is a Power Sonic, PSH-12180FR, 21Amp Hour unit. You will need to order two of them.
We should all do our part to save the enviroment and encourage the growth of the solar and wind power industries.
Cordless electric lawn mowers go a long ways towards these goals. I recently purchased the Black & Decker Cordless Electric Lawnmower the CMM1200.
In the review I describe how to upgrade the mower to mow over 9,000 SQFT!
I hope my review will help you make a decision about our future.
http://www.epinions.com/review/Black_Decker_19_In_24_Volt_Cordless_Mulching_Mower/content_445899312772
Sep 30, 2008 | Garden
Garden Logo
311 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
