Question about Fisher and Paykel 36 in. CE901 Electric Cooktop
The two elements on the left hand side of my smooth top sometimes work.Sometimes I can have a pot on the ring going then for no reason the element will go out
How do i turn the outer ring on for a dacor stove top
Pushing the button for the element will turn on the inner element at level 5. Before adjusting the level (so while the level indicator is still blinking) press the little circle on the right side of the controls for that element. The circle should light up. Now press the UP control for that element, and the level indicator should stop blinking. Now the outer and inner elements are both heating up. Adjust temp level to desired setting.
Jan 30, 2013 | Dacor Millennia ETT304 Electric Cooktop
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Oct 02, 2012 | Neff Cooktops
Left burner is not working
these elements merely unplug when you lift up the one side of the element,then just easily rock back and forth till it unplugs from the stove top
Apr 25, 2010 | Kenmore 30 in.44084 / 44089 Electric...
One of the heater elements would not turn off
switch is bad needs replaced
Jun 24, 2009 | Cooktops
Burner Elements on Electric Kenmore Elite 790 Stove
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jun 02, 2009 | Maytag MEC5430BDS Electric Cooktop
ELEMENT WONT SHUT OFF
Sounds like that specific element has shorted to ground inside it's sheath. You'll probably find the element does not get as hot as it normally would.
A fuse will not blow, or breaker not throw, because of the point in the element that the element has grounded.
Elements are available from a number of resources.
A way to test if the element is shorted to ground:
Tools needed -
Ohmeter
1)Disconnect power from the appliance
2) Remove the element (Sometimes they are plugged in, sometimes the wires screw onto the ends of the element.
3) Set the Ohmeter to Rx1000 or more.
4) Measure the resistance between the outside metal sheath, and either of the two power connection points on either end of the element. Under any condition, you should not get a reading. If you do, the element is bad, and you need to get a new one. They are not repairable.
5) Re-install in the reverse removed.
6) Check all connections are clean and all is re-assembled as you originally found it.
7) Turn on power and check if element comes on.
It is unlikely the problem is with the control, but it is a possibility. Give me more info about the cook-top (make, model) so I can investigate further.
Jan 14, 2009 | KitchenAid 32 in. KECC502 Electric Cooktop
Dacor cooktop Model # SEC30-1C
is this a smooth top? glass? if so gently scrape with a razor blade yes a razor blade. then buff with cerama bryte or comparable cleaner available @ walmart or home depot etc..
Apr 22, 2008 | Dacor Millennia ETT304 Electric Cooktop
Circuit Braker Jumps Off
You probably have a burnt out element. They almost always short out when they burn out. If it is a coil unit it may be visible. A smooth top unit can't be diagnosed without removing the top glass. Most of the time you can do this yourself. Sometimes when a burner goes it will ruin the switch also.
Mar 29, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
No Ignition
Dirt. Spilled oil, grease, milk etc. act as isolator and prevent contact between burner and casing (mass). You need to clean up burners, scrub all the dirt and make sure their seats are cleaned too (brass elements below burners).
Mar 14, 2008 | Cooktops
Fisher and Paykel 36 in. CE901 Electric Cooktop Logo
62 people viewed this question
Top Fisher and Paykel Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Fisher and Paykel Cooktop Expert? Answer questions, earn points and help others
