Question about Philips Televison & Video
Philips HTS3154 Theater System. The redlight by the standby button flashes on/off continuously and depressing the standby button will not get the machine to turn on. Like wise the remote control will not switch on / power up the system. The television was also flashing on and off until I disconnected the scart from the Theater System to the TV, which then operated normally.
  • 2 more comments
  • baldrickbark Aug 15, 2008
    All speaker wires are as they were before the problem, all checked. I don't think I've explained this well. The system will NOT power up from standby, there is no VDU read on in the panel. The standby light is just flashing on/off. Is there a 're-set' button anywhere?
    Does this system have a 're-set' button please?
  • baldrickbark Aug 16, 2008
    Does anyone know if this syastem has a re-set button please yes or no?
    Thanks Ken,
    I did try that one, but no go I'm afraid
  • Philips Master
  • 13,433 Answers
There may be a reset hole / switch in the back.
Posted on Aug 16, 2008
    Master:
  • 521 Answers
Ur problem indicates that there is somthing wrong in the hardware section.it is very much advisable to call a company technician better than trying out somthing which can worsen the problem more
Posted on Aug 15, 2008
    Master:
  • 623 Answers
Hardware problems take it to a local service center
  • 10,594 Answers
Your Home Theater has problem in Amp section. Please check speaker wires are connected properly and see its insulation as well. If found fine, Amp Output in Home Theater is bad.
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Aug 15, 2008
    No Sir, Its not issue of reset or related with software. Its problem in Hardware, Output Amplifier. Your Home Theater is in shutdown mode and this will happen when there is hardware failure in system. You need to take it to Philips service center for proper repair as its not case to do-it-yourself.
    No Sir, it doesn't have any reset button in it.
    Its not Setting Issue. It is hardware failure and needs Philips service guys to take care.
    Sergeant:
    Champion:
  • 258 Answers
Some DVD players can be reset [rebooted] by pressing the power button for 12 seconds.
Ken
Need to find a DVD loader for Philips MOdle HTS3154 part (996510001630). Can anybody help me locate one?
Have you asked a TV repair place yet there are some small shops that fix DVD players we have one here close by at Plainfield Pa . Look in the white pages of your phone book marked business sometimes they will list . I have two that I have used and trust Ce Service center email wwwceservicecenter.com or Hoover's Tv repair he works on dvd players 717 243-3797 sometimes it is cheaper to replace than fix depending on price of part. Hope this helps
Dec 15, 2014 | Philips Audio Players & Recorders
Unit stays on standby
The only thing I can find in the manual (link below) is to remove the power cord for a few minutes & try powering on from the "Standby ON" button, also set the "source" to anything other than TV. http://www.p4c.philips.com/files/l/lx3600d_25/lx3600d_25_dfu_eng.pdf
Jul 07, 2007 | Philips LX3600D System
My hometheater is on standby mode even when i operate it with the remote control
Press and hold the power button on the unit it itself. Ensure that the batteries are properly installed in the remote. http://download.p4c.philips.com/files/h/hts6515d_37/hts6515d_37_dfu_aen.pdf
Oct 24, 2014 | Philips HTS6515D Theater System
Stanby light flashes red. System will not turn on. Trouble shooting does not work
Have you tried unplugging the power supply cable. Wait a couple of minutes then plug it back in. See what happens.
Or HOLD steady the standby button for a couple of seconds and release it once you see the color change to blue. Hope it works.
Jun 24, 2010 | Philips HTS6515D Theater System
Philips Home Theater - Annoying high pitch sound while on standby
I have the same problem with the same model, so obviously it's not a single-unit problem. My only solution, since taking it back isn't feasible at this point, is to have a DVD on play-pause so that it's not on standby. Waste of energy, so I don't do it all the time, only when I'm sitting in the room late at night making the high-pitched noise hard to ignore.
Apr 17, 2010 | Philips HTS-3555 System
I have a HTS3410D Home Theater system. I cannot
a blinking or pulsing power light usualy means a problem with the power supply. Check for burned resistors or swallen capacitors on the power board it will be the one with the one with the main power running to it.
Nov 17, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
STANDBY LIGHT KEEPS BLINKING
Unplug the power cord, wait for 5 minutes, plug the power cord back in and try to operate the unit.
If this does not work, you will have to get a technician to look at it for you.
Please rate this solution - THANKS
Dec 26, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
Dvd player
There are hacks available on the web. Some require a "secret" combination on the remote. Others require soldering inside. Each player is different. Some cannot be hacked at all. Try a search engine entry for Phillpis HTS3154 region code. If I find something specific I will return and repost the URL.
Dec 31, 2007 | Televison & Video
Televison & Video Logo
289 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
