Question about Behringer Eurolive B205D Active 150-Watt PA/Monitor Speaker System
The behringer b205d will work fine for 10 minutes then begins pulsing off and on at a regular interval around 5 seconds.
4 Suggested Answers
  • 5603 Answers
SOURCE: behringer mixer power goes off after running about...
That time lag would indicate a thermal problem.
Likely the power supply is a switching type that has some three terminal regulators after it such as 7805, 7815, 7915.
These have thermal protection in them and one may be shutting down.
Use circuit cooler to isolate the part that is shutting down.
Posted on May 26, 2010
SOURCE: Xenyx 1002fx Mixer 10 Input 2 Bus with Efx: behringer mixer power goes off after running about...
i have a problem i need to know all about this power supply what the output is and the input and so on everything thats writen down the the adaptor
Posted on Jul 09, 2010
  • 3107 Answers
SOURCE: Behringer B205d...Is it worth fixing if speaker voltage was used in input? Main board burned out I suppose. Mfg date is 2009. No power now, was smoking from overload when it happened.
It's probably not cost effective to repair it' Check the horn driver and the raw woofer to see if they are still good, and if so retain then as spares.
Posted on Jan 03, 2017
Jan 02, 2017 | Behringer Music
Behringer B112D wont power up until 10 minutes after switching on
This will be a power supply problem. Take it in to your repair shop for service.
May 07, 2016 | Behringer Eurolive B112D Powered PA...
Power light is on but no speaker output?
Disassemble it enough to get to the speaker to check for continuity. If it's blown, replace it, If not, the amp board is probably blown and needs to go in for repair.
Mar 08, 2016 | Behringer Eurolive B205D Active 150-Watt...
Hi My left side behringer truth b1030a monitor speaker has a problem. It plays for 5-10 minutes and then just goes off. Im suspecting a blown capacitor. Please help!
If it come back on after shutting down, you have a part overheatinga and then working again after it's cooled off, rather than "blown. You will need to take it in for service.
Aug 31, 2015 | Behringer Music
Powering on and off
Like as not, Behringer is a disposable brand once the warranty (which does not cover wearing parts like pots and faders which wear out quickly and are not worth replacing due to the design in most cases)
We normally sell behringer kit if it still works just before warranty expires.
Feb 13, 2014 | Behringer Eurolive B205D Active 150-Watt...
Just bought. New b205d power is on but no sound
These are a nice unit... just bought three of them that were dead... I have repaired one so far. I assume you mean the blue LED is on indicating power is on. What I want you to test is if injecting signal on the BACK of the unit jack (power amp in) will create sound. If it won't then better exercise your warranty. The one unit I have completed repair had a bad 15 volt regulator in it... the second that is almost fixed somebody had blasted the input circuits... probably connected to a speaker output... don't do it... these are LINE and MIC level units. If you need to tap off a speaker output, use a DI box with the unit. The third unit I have not received yet. Drummer used the repaired one as monitor last night and was impressed with the power this unit has.
Jul 22, 2011 | Behringer Eurolive B205D Active 150-Watt...
On stage live...I want to use the B205D as a personal monitor...the band uses a Yamaha EMX512SC 8 powered mixer on stage...What would be the correct connections to hear only my vocals in the B205D monitor...
Oh my... the EMX512SC does NOT have any "sub busses" there fore there is no way to just hear YOUR vocals where there are other vocal present. The way to connect this is to run YOUR mic into the B205D and then run the line output that is intended to run to other B205D's from the B205D into a channel of the EMX512SC.
Jun 24, 2011 | Behringer Active 150Watt PAMonitor Speaker...
Behringer mixer power goes off after running about 5 0r 10 minutes then power turns on.what is problem with the power supply board
May 20, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Problem is likely thermal. Open unit carefully and use freeze mist (circuit cooler) to find bad component.
With that long a time period, it is possibly a component mounted on a heatsink.
May 18, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Behringer Eurolive B205D Active 150-Watt PA/Monitor Speaker System Logo
155 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
