Question about LG LS-L1210CL Mini Split Air Conditioner
LGF122CS mini split will not turn off by remote, have checked with another remote, same problem however, fan speed lowers when the off button is pushed on the remote. operates properly by pushing the on/off button on the face of the interior unit
  • joe7341 May 24, 2011
    As I stated in the original post another remote was tried, the original was reset prior to you comment and I have cold air it doesn't turn off, but hey thanks for trying.
    Master:
  • 328 Answers
Thats why there is a reset button somewhere at the back of the remote and some times under the batters remover the remote control battery cover remove the batters find the rest it will looks like a tiny hole you will have to press it with a needle insert batters back enjoy cold air
Posted on May 23, 2011
Error message U4
Signal transmission error. Indoor and outdoor PCB's cannot communicate. Usually a faulty controller board in the outdoor unit. If the indoor unit otherwise functions normally (can control fan speed, louvres, beeps in replay to all remote buttons) then it is probably OK so check outdoor controller PCB.
Jul 21, 2014 | Daikin Mini Split Concealed Duct Units
My remote will not change the fan speed on my mini split heat pump in the heat mode but will change speed in cooling mode. checked batteries and pressed restart button no changes
in the heat mode the fan mode run automatically first in low mode and after a while it run normally ,how you set on the remote.if you can-t set on the remote is possible to have problem to the remote.
Dec 12, 2013 | Comfort-Aire EHW 12 Air Conditioner
Condenser fan does not come up to full speed.
These Ptac units are advance system that are designed with variable speed motors that modulate in order to save energy, This is normal operation, because starting a motor at a lower speed rather than the conventional high speed will save energy, which translates to saving you money. As the load increases (heat) on the condenser coil, the fan will ramp up accordingly.
Aug 02, 2013 | LG LS-K2430HL Heat Cool Mini Split Air...
I RECENTLY INSTALLED 3 LG INVERTER MINI-SPLITS.TWO 12,000'S AND ONE 24000 BTU.THE 12'S SEEM TO WORK GREAT THROWING NEARLY 140' HEAT. THE 24 IS LUCKY TO THROW 90' HEAT AND I DON'T SEEM TO BE ABLE TO CHANGE...
I think you keep in Auto mode. If in Auto mode, you can't change fan speed. Keep in cool/heat mode and then press fan button in remote to select desired speed.
Dec 16, 2010 | LG Heating & Cooling
Need to know what the icons stand for on remote control for Toshiba Split System Air Conditioner. Don't have a manual?
Generally all the symbols on each unit are the same. The snowflake does cooling, the sun does heating, the fan does fan only mode, the water droplet does dehumidify and the arrows means automatic mode. The increasing bars refers to the fan speed.
Mat
Apr 25, 2009 | Continental Electric CE-AC7581 Ductless...
My mini split does not run
Check that you are on the correct mode setting. Open the remote and press the mode button (the one with about four little icons, star, teardrop, triangle and sun) until you get to the mode you require. If cooling required, select the star or crystal, if heating required select the sun (circle with little lines)
Mar 06, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Kelvinator split system a/cond
An air handler comes with a low, medium, and high speed wire taps and can only be set through these taps.
Oct 16, 2008 | Heating & Cooling
Soleus KFGHP-09-ID Mini Split
This is normal operation for these styles of minisplits. The thermostat is not in the remote but is located on the return air of the indoor coil, so the air needs to be flowing in order for the thermostat to measure the rooms temperature. Set your fan speed to auto and the fan will slow down when setpoint tempurature is met.
Phil Hodges,
Tech support Soleusair
May 18, 2008 | Soleus KFS18GW 18,000 BTU Heat & Cool 230V...
LG LS-L1210CL Mini Split Air Conditioner Logo
296 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
