Question about Delta Model 200: Classic Single Handle Kitchen Faucet - Chrome
I am repairing my Delta 200 faucet. Having a problem getting the spout off. How is that done? Thanks
  • 2,841 Answers
Remove the set screw holding the handle on. Pull the handle off and then remove the large diameter slotted nut holding the ball valve in place. After you remove that the spout, remove the ball valve abd then just pull the spout up and off. You may have to work it back and forth and you may have to spray some WD40 and let it sit overnight. It will come off.
Posted on May 23, 2011
How do I tighten the base on my Delta kitchen faucet? It is like the Lewiston, just a round base sitting on the sink with a pull-out spout. Do I need to remove the water lines to take this thing apart...
There should be a nut and washer clear up against the bottom of the counter top. I think the clip you are looking at holds the spout hose to the diverter assembly. You need to look beyond that to see the nut you are looking for. I could be mistaken, but every one of this type of faucet I have seen mounts this way including Delta. It is not easy, there is no room to work up there but it can be done. The best way is with a large basin wrench (a sort of swivel-head jaw on a rod) but with some perseverance and possibly a colorful word or two it can be done with a large pair of slip-jaw pliers too, I've done it.
May 26, 2011 | Delta Faucet Company RP21462WH Waterfall...
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
Hard to turn spout side to side
Remove the spout and apply a thin coating of plumber's waterproof silicone lubricant to the O-rings on the spouts mounting post. If the spout is still difficult to turn, replace the O-rings. Here is the link to the delta waterfall parts breakdown.
Sep 04, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
I have a Delta Waterfall 172 SSWF faucet in my kitchen. I need to replace the water spout - I have the replacement spout. It appears there is a plastic retainer ring that holds the spout in place but I'm...
Normally you just turn that ring, counter clockwise. If too hard to turn, I usually put a rag over it, to avoid scratching, and use a pair of channel lock pliers, and squeeze just hard enough not to slip.
Jan 15, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
My delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
Sep 28, 2009 | Delta Faucet Delta RP17453 Pull-Down...
Single handel kitchen faucet: Over time the
shut-off the water, pull the handle and the spout. change the 2 "O"ring and make sure the spout body has no dirt in them. apply some the plumbing grease bewteen the spout body. put everything back.
Apr 22, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Water pooling at base of delta waterfall faucet spout
I have the same problem. The part that is needed is found with a simple Google search for "Delta Waterfall RP22934 O-Rings"
Simply Slide the collar up at the base of the spout where it swivels.
Gently open the now exposed split plastic retainer so that the tabs near the bottom are pulled from their holes.
Lift the spout off the base to expose the o-rings.
Replace with the new o-rings and apply o-ring grease.
Re-assemble and enjoy a dry sink area.
Nov 25, 2008 | Delta Faucet Delta 172-SSWF Waterfall...
Delta Model 200: Classic Single Handle Kitchen Faucet - Chrome Logo
185 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
