Question about Electrolux Freezer Kelvinator Ice Cream Freezer Dipping Cabinet 4 Facing
Kelvinator dipping cabinet holds 8 tubs. unit is freezing only on one end of the unit. what is the problem?
  • 5,370 Answers
Check the thermostat setting.It must be set on low cooling or its not functioning properly and not cooling complete unit.The thermostat is located on the server side of the cabinet, directly behind the service grill. It functions to control the temperature inside the cabinet.If you notice cooling problem, check thermostat setting, if its set ok, then its faulty thermostat. ---------- Also it can be the issue of low refrigerant in compressor or weak compressor. ---------- Also see if the condenser coils are got very dirty, if yes clean the coils with brush and dry cloth.
Periodic cleaning of the condenser can be easily accomplished by brushing the coils with a soft brush and/or using a vacuum cleaner with a brush attachment. Be sure that dirt, dust and collection of other debris do not build up to a point air circulation through the condenser is restricted.
---------- Also see if the storage compartment door is getting properly closed, if not then there will be cooling problems. ----------- This should be checked, to confirm the problem.Thanks.Helpmech.
Posted on May 23, 2011
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: unit is freezing only on one end of the unit. what
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 23, 2010
Our frigide is defrosting water into the bottom the fridide the lays in the cavity under the crisper and after a while(8 or 12 DAYS)RUNS OUT ON THE FLOOR
you have a clogged defrost drain. when y our unit goes into defrost, the water that is supposed to go down a tube from your freezer down to the bottom outside of the unit, into a pan to evaporate, instead is going into your fridge etc. This drain needs to be cleared. I would not recommend doing it yourself, you may cause further more expensive damage.
Refrigerator FAQ and Tips
Mar 21, 2010 | Electrolux Freezer Kelvinator Single Door...
Kelvinator Single Door Hardening Cabinet Flash Freezer fan
If the fan motor shaft is smooth with 1 flat spot the hub on the blade probably has a hex set screw that can be tightned with an allen wrench. If the fan motor shaft is threaded there should be a nut holding the blade on. Also yur motor bearings could be going bad causing vibration which damages the fan blade.
Sep 22, 2009 | Electrolux Freezer Kelvinator Single Door...
Ice Cream Dipping cabinet running but not working?!
Ice cream needs to be below 0 degrees. It sounds like you have a refrigeration problem. The unit runs constantly because the temperature control is never satisfied. ;)
Jul 13, 2009 | Freezers
Unit is freezing only on one end of the unit. what
Jun 27, 2009 | Electrolux Freezer Kelvinator Ice Cream...
Stopped freezing all the sudden. it remains cold but most items are thawing
switch off your refrigerator for at least 5 hrs. than again switch it on.. if your problem is not solved that it is sure that your thermostart is not working........please replce it
May 14, 2009 | Electrolux Freezer Kelvinator Single Door...
Kelvinator freezer is not freezing!
you mean it cools but not as afreezer ok, rework again the system properly vaccum and slowly charge it but please watch out the proper amperage of the compressor or might be the compressor motor now is weak, how old this unit,sir.thankyou
Aug 05, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Freezers Logo
79 people viewed this question
Top Electrolux Freezers Experts
AJMAL KHAN
Dennis Boxerman
Wayne Tolonen
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
