Question about Jacuzzi Magnum Force Series Pool Pump 1 Hp1 Speed ()
Leaks on back side of pump - Jacuzzi Magnum Force Series Pool Pump 1 Hp1 Speed ()
    President:
  • Jacuzzi Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
The pump seal is leaking...
In general the process is the same for any brand...Disassemble the motor from the pump, lock the motor shaft at the end opposite the pump, spin off the impeller (which may be covered by what is called a diffuser), replace both halves of the seal (one is pressed into the pump housing and the other rides against or on the back of the impeller) and assemble in reverse order. If you need more specific directions, please add a comment with your question(s) or contact me using our web site at www.arrowpools.net.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on May 24, 2011
Why does it leak antifreeze underneath on the passenger side?
Water pump , when they start going bad there is a weep hole on the back side of the pump that leaks .
Nov 23, 2015 | 1999 Buick Century
Water appears to flow back through pump
When? When, at the time pump turns off?
or... When everything has been off for a while, and there is no more water in the pump? Or another words, loses prime during off time?
check for air leaks on pressure side of pump. If there is an air leak on suction side of pump, then the filter canister will build up air within it, and while the pump is on it is compressing the air, just like an air compressor, in the filter tank. And then at the time the pump turns off all the water will be blown back the way it came, because of the pressure that was developed and built up in the filter tank! If this is the case, locate that section leak on the suction side of the pump... Check all union connections, for bad seals/orings, or threaded connections for a bad Teflon tape or silicone sealant connection, etc. etc. any point of entry for air to get into the plumbing system is not good.
Mar 28, 2015 | Pool & Spa
2007 dodge charger how to fix water leak from back of wter pump
Is the leak coming out a hole on back side of pump ? If it is you need a new pump !
Aug 14, 2014 | Cars & Trucks
Antifreeze leak side of motor
is it leaking on the side of the motor where all the pulley's are or is iton the back side of motor if it is where the pulley's are it sounds like the water pump is leaking or is bad if it is on the back side of the motor it sounds like one of the freeze plugs is leaking or busted
Mar 14, 2012 | 2003 Buick Century
We replaced the theromostat and the radiator but it is still leaking under the car on the drivers side
Leaking water on teh drivers side indicates a cracked block or cracked head in most cases. Unless you have a water injected motor, I don't remember Ford using one, there are no water ports on that side of the motor. It could be the water pump leaking and being pushed back when the vehicle is running so check for leaks around the water pump. You need to check the heads, side of the engine block and the freeze plugs to make sure there are no cracks or leaks around the head gasket seal.
Jul 06, 2011 | 2000 Lincoln LS
All water empties from the pump back into the
This is a leak in your system. If it is just slowley going back to the pool it is probally on the pressure side (after the pump). If it goes back with a big wosh it is probally a suction side leak (before the pump).
Feb 01, 2010 | Water Pik Aqualink Rs4 Package - Pool and...
Water Pump leakes from steel tube.
when installing new o-ring on tube, lubricate o-ring and stick it in water pump. Then pull pressure back on tube and then tighten hold down clamp. problem solved
Apr 16, 2009 | Dodge Caravan Cars & Trucks
Leaking while draning
take the back off,,look up under the tub thats where the pump is at,,either the pump is leaking or the drain hose,,,or tub to pump hose...onthejob
Feb 15, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Leaking
The pumps usually have rubber hoses fitted them and they can deteriorate over time, moreso around the clamps that hold them onto the pump. Also, maybe the pump has been slightly opened via a worn seal. Either way, there may be a risk of fire if any water gets onto the electrical connections of the pump or spray onto any other open electrical connection inside the machine. It would certainly be advisable to have it checked with some urgency.
During the final rinse and spin, I would think the pump may not be used during these cycles.
Hope this helps somewhat.
Sep 14, 2008 | Whirlpool WTW6400SW Top Load Washer
Whirlpool® 4.6 Cu. Ft. Cabrio® HE Washer leaking water
coins may have breached the outer tub. expensive way to learn to remove loose objects fro clothes before washing them
Sep 14, 2008 | Washing Machines
Jacuzzi Magnum Force Series Pool Pump 1 Hp1 Speed () Logo
160 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
