Question about Car Audio & Video
Why is my vr cubed amp running hot it is a 400 watt 4 channel
    Sergeant:
  • 167 Answers
All amplifier running hot if it's hot the sound is good try to place a pc fan at the top of ampli. to ease some heat
Posted on May 23, 2011
Will the amp blow my speakers?
If you bridge the amp and get 1000 watts RMS and that is split going to two speakers then you will get 500 watts RMS at each speaker. If you have your amplifier on maximum gain it may blow your speakers, not because they are overpowered but because you might run into "clipping" issues running the amp at maximum capacity. Just to be safe I would dial the amp's gain down to 3/4 of the way to full gain. That should give you ample power and keep your amp from clipping and running hot.
Aug 11, 2015 | MTX Car Audio & Video
I have Sony xm-2165gtx amp 165 watt rms x 2 at 4 ohm 200 watt x 2 at 2 ohm 400 watt x 1 bridge output at 4 ohm stereo or bridge mono output 4 ohm stable in bridge mode this mean can't go lower then 4 ohm...
You can't bridge that amp onto a load lower than 4 ohms. So you can't bridge that amp onto two 4 ohm subs. To get the most power out of your subs is easy. Run one channel to one sub and the other channel to the other sub. 165 watts RMS is plenty for most subs.
Dec 05, 2013 | Car Audio & Video
I have to hook up 4 amps in my car. 4 channel 700 watt ken wood, 2 channel 800 watt Sony, 4 channel 740 watt Jensen ,and a 2 channel Rockford fosgate. Which is best way to hook them up so I'm not ki
Pace posted on Saturday, March 05, 2005 - 01:08 GMT Your subs are dual 4 ohm voice coils so if you want to bridge your 2 channel amplifier to your two subs then wire them parallel, meaning the + to + and - to - ( Do this to both subwoofers), Then run a wire from one positive and one negative on each sub and bring the two positives together and the two negatives together and hook both positives to the far positive connection on your amp and connect both negatives to the other negative on your amp,
This will create a 4 ohm load on your amp.
Although if it's a two channel and you have two subs it's usually pointless to bridge them because if you use one channel per subwoofer its going to be the same as if both subs were bridged. example) 800 watts x 1 bridged power of your amplifie (4 ohms) is the same power as 400 watts x 2 at 2 ohms.
Nov 26, 2012 | Computers & Internet
What is the actual watts per channel @ 8-ohms and 4-ohms on the Behringer PMP3000?
Those specs would be right - I have this same board but the amp was fried by a previous owner. I pulled the amp board out and tossed it and use the mixer now to drive an external amp. Great board. This amp is rated at 1200W "peak", bridged into an 8ohm load. That would equate to about 900W RMS bridged into 8ohm or 450 per side into 4ohm loads per side. You can't daisy chain all 4 speakers....impedance would be too low. You can run two of your 8ohm speakers per side - that results in a 4ohm load per side for the amp. That would give you amp delivery of 450W per side. Your speakers are rated to handle more than that so you're fine. For the record.....you could run one speaker per side no problem....just lower power output.
Aug 16, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
I have a 12 inch auduobahn 400 watt that is a special edition d jones. what is the best and most efficient way to install it with a jensen 400 watt 2 or4 channel mosfit power amp.
Is it a 2 or 4 channel amp???? Does it have a lpf (low pass filter)??? If its a four channel it prolly wont sound too great. If its a 2 channel you need to bridge sub to amp. Usually its the 2 outside terminals on the amp. Might have a diagram on the bottom of amp
Feb 27, 2012 | AudioBahn Car Audio & Video
How many watts is this amp
Specifications Power Output: 100 Watts RMS x 2 channels at 4 Ohms ≤ 1% THD+N Signal-to-Noise Ratio: 80 dBA (reference: 1 W output) Additional Power Output: 200 Watts RMS x 2 channels at 2 Ohms ≤ 1% THD+N
400 Watts RMS x 1 channel bridged at 4 Ohms ≤ 1% THD+N THD+N (Distortion): <0.25% (reference: 1 W output) Frequency Response: 20 Hz to 20 kHz (-3dB) Maximum Input Signal: 5V Maximum Sensitivity: 100mV Dimensions: 14.37 x 9.72 x 2.5 (365mm x 247mm x 63.5mm)
Jan 03, 2010 | MTX 4002 Car Audio Amplifier
Best amps for bose 901
You need an amplifier with at least 200 wpc to get the most out of your BOSE. Look into getting a NAD, ADCOM or CARVER amplifier. I prefer CARVER myself. I am running a CARVER M-500T(251 wpc) on my 901's and they sound incredible.
Aug 25, 2009 | Bose 901 VI Main / Stereo Speaker
Latest model surround receiver for bose 901 speakers VI
I can think of no reason any amp pushing 120 watts would not work with 901-VI's. They're very efficent and will probably play louder and cleaner than you would ever need. As I recall, my old series IV's have no maximum amplifier rating specified, but I did blow up a bridged Carver M-400 Cube (pushing 400 watts to one speaker with a DVD-Audio of Yes - Fragile cranked dangerously high) with them. I'm convinced my speakers are indestructible in any home application.
Keep in mind that whatever you decide to use as your control/amplifier section, a pair of 901's need a dedicated stereo amplifier. I suspect you're thinking surround sound so a receiver with separable preamp/amp channels, due to the Activbe EQ, would be needed and as far as I know they don't exist. A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds.
Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. 120 clean watts is good. I'm using only 110W for mine.
A Carver M-200 is a fine, efficient amplifier that would have you cooking just fine (2x100W).
Mar 20, 2009 | Bose 901 VI Main / Stereo Speaker
Bridging 800a4
That all depends upon whether or not the sub you are running has dual voice coils or just a single voice coil. The 800a4 is a four channel amp; thus the only way you can bridge it will be 3 channel or 2 channel. If you are running a dual voice coil sub then you can wire the amp two channel and get 400 watts x 2 @ 4 ohms. Make sure that you sub can handle this kind of power though.
Here are the specs:
4 x 100 @ 4 ohms (13.8V - <0.05% THD)
4 x 200 @ 2 ohms (13.8V - <0.10% THD)
2 x 400 @ 4 ohms bridged (13.8V - <0.10% THD)
Fuse: External 60A
Manufactured in 1999 - 2001
Jun 18, 2008 | Rockford Fosgate Punch 800a4 Car Audio...
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
