Question about Jura Capresso 454 10-Cup Coffee Maker
Numbers on LCD display go out partially then might come back on at next use.
Printer won't stop printing. Turn off and turn back on and it starts printing..
Perform a partial reset Perform a partial reset to restore the product settings to the default values.
  1. Write down any fax numbers and country/region and language settings stored in the product memory.
    CAUTION: A partial reset might remove all speed dials and other settings from the product memory.
  2. Disconnect the power cord from the rear of the product.
  3. Press and hold the # and 3 buttons at the same time while plugging the power cord into the rear of the product.
  4. Release the buttons after 30 seconds or when Part NVM Reset displays on the control panel.
  5. If the product does not turn on automatically, press the Power button (c01602202.gif ) to turn it on.
  6. Press OK to continue the current task.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Next solution
Dowload the Firmware fix on this line. make sure it's connected over the usb cable.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-77368-1&lc=en&dlc=en&cc=us&os=228&product=3795406&sw_lang=&key=null&site=null
Mar 24, 2011 | HP Officejet 6500 Wireless All-in-One...
UA-787 - Numbers on display are only partially visable
I'd suggest you send it back to the manufacturer.
The address in on the silver label on the back of your monitor.
Jul 29, 2010 | Lifesource UA 787V Digital Blood Pressure...
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
Oct 23, 2009 | Canon ZR85 Mini DV Digital Camcorder
The numbers on the digital readout are partly
If the display is showing "partial digits" on the display, it means a scale is excessively shaken (sometimes during shipping) it's possible for the LCD to become partially separated from the PCB (Printed Circuit Board). On many models you can gently press on the LCD and it will reconnect. However on many scales it's difficult to reach the LCD (without removing the cover) and thus the scale will often have to be returned to the manufacturer for repair. Contact them at 1-800-326-6247 for the Conair appliance customer service center.
Sep 09, 2009 | Salter 9007 Glass Lithium Digital Scale
It will work ok sometimes but, most of the time i only get a partial display of numbers on the lcd screen.
If this unit is less than 2 yrs. old.....Sent it to Bushnell and they will replace it under warranty at no cost to you. 800.423.3537
MTG
Jul 26, 2009 | Bushnell Tour V2 Pinseeker Laser...
LCD light for time/date
This is a problem with intermittent display contacts.This problem occur because of heat and vibration during operation. The connection are solder to the connectors. The solder joints that make the connections expand during heating and eventually lose contact with the connection points. When you tap on the display you move the connection back into contact. This will eventually fail to happen as the connection get worse. The Clock/Radio's display needs to have the contact points resoldered. This is a service usually performed by a service center. The Emerson customer support Telephone number is 1-800-909-1240 you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of your Clock/Radio. Tell about the problem you are having with the intermittent display. They should be able to tell you how you can get the Clock/Radio repaired. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day.
Jan 11, 2009 | Emerson Smartset Clock Radio
LCD screen is messed up
I can't set the time. Can you give me the instructions
Dec 08, 2008 | KNG America Mcqueen (028623) Clock Radio
Partial Screen Display
Problem in the LCD back panel board. check the interface unit or ADC unit, also check the video clock pulse. one section is not working.....
Oct 09, 2007 | Dell E173FP 17" LCD Monitor
Jura Capresso 454 10-Cup Coffee Maker Logo
48 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
