Question about Cameras
Nikon D3100 stuck in flash mode but flash won't come up
  • 406 Answers
SOURCE: Nikon D3100 - how to
For Quick Response Mode and other Release Modes, please see "image1":
For remote control shooting or Bulb mode, see "image2":
image 2
Posted on Nov 24, 2010
  • 102366 Answers
SOURCE: I have a D3100 Nikon
You're seeing blown-out highlights. These are the portions of your photos that have been so overexposed that they've gone pure white, losing all detail. The camera doesn't know whether you were deliberately going for this effect, but this is generally considered a bad thing and so the camera is warning you about it. The proper fix is to use exposure compensation to reduce exposure and shoot again to bring back the highlight details. This risks losing details in the shadows as they go pure black, but this is generally considered not as bad. After all, we don't expect to see details in the dark.
That was the long answer. The short answer is to press up/down on the multiselector to cycle through the different views of your photo until you see one you prefer.
Posted on Jan 27, 2011
SOURCE: I have a Nikon D3100
Hello mehran_vafae, is supposed to have put a DX lens.
The mode dial, select in what way is going to take a picture.
You can make combinations according to the mode set in the mode dial, with the Fn key / command dial, command dial / aperture A mode, command dial / shutter speed S mode, Full Auto / + / - compensation sw, etc. ..
Please carefully read the user manual supplied with your camera and if it fails take them to Nikon service.
Regards
Posted on Mar 21, 2011
  • 102366 Answers
SOURCE: Can I safely use a
Yes. The trigger voltage of the Canon 199a, rated by Canon at 6.0V, is low enough to be safe with new digital cameras.
Posted on Apr 01, 2011
  • 102366 Answers
SOURCE: What is the " fEE
You need to turn the aperture ring on the lens to its smallest aperture (largest f/number) and lock it. You can control the aperture from the camera body, the same way as on lenses without an aperture ring.
Posted on Jun 22, 2011
Nikon d3100 stuck on flash mode
What do you mean by flash mode?
Have you read the manual how to use the camera?
If nothing from there helps, try connecting it via USB and check if there is firmware update. If even that doesn't help, try acessing menu and doing hard reset from there.
Mar 03, 2014 | Nikon D3100 Digital Camera
Nikon D3100 won't flash
If you have set the main dial to the green camera logo, with automatic in bad light, and the flash still does not pop up, you could start worrying. The mail mode dial is very easy to turn, even without knowing. It happens to me more often than I would like. My next camera must have a special button to lock this dial.
When you chaco the manual, you will see there are settings the flash won't pop up and even when it is up it won't flash, because that menu excludes the flash.
Jan 12, 2014 | Nikon D3100 Digital Camera
Are there any problems usig a Quantaray PZ-1 DSZ flash with the Nikon D3100?
There is no problem with the trigger voltage, which I assume is your primary concern. You may not get all of the features you would with a Nikon flash, but you should be able to use it with the D3100 just as you use it with the N80.
Dec 06, 2012 | Quantaray PZ-1 DSZ for Nikon TTL Flash
Some time internal flash does not work in my nikon D3100 camera
When in program and manual mode, you will have to set it to flash. Make sure the circle around the electric bolt on the screen does not have a line through it, and it should work. There is usually a button with the symbol on it somewhere around the lcd(I'm not very familiar with your model or I'd tell you where) or it may be in the on screen menus if it's not a button around the screen.
Mar 15, 2012 | Nikon D3100 Digital Camera
Flash is not working
Night mode? As a professional I can set a camera to shoot at night by the settings thats why we dont use point and shoot cameras
go buy a Nikon D90, or D3100 and set the modes for night shooting
good luck.
Feb 15, 2012 | Nikon Cameras
How to install a Nikon SB-700 AF Speedlight Flash for Nikon Digital SLR Cameras
Basically, you put batteries into the flash, put it into the flash mount on the top of the camera, turn everything on, select a flash mode, and start shooting.
The flash comes with a detailed manual describing its operation. There is a section in the camera manual describing the various flash modes. The SB-700 is fully compatible with the Nikon iCLS system, which includes the D3100.
Since you asked a general question, I can only give you a general answer. If you have any specific questions, please feel free to ask them.
Jan 05, 2012 | Nikon D3100 Digital Camera
When i came to used my camera, i found that when i looked through the viewfinder the image was blurred, when i take a photo the photo is black. in need of a solution
Sometimes cameras that have been stored for a long time can experience stuck or sticky shutters. This is caused by lubrication oil residue building up on the shutter from non-movement over this extended period of time. But this can sometimes be easily fixed, without even opening the camera. To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
If you do succeed in opening the shutter, remember to conduct the post-fix multiple continuous shutter shots to lubricate the shutter.
Dec 12, 2011 | Nikon D3100 Digital Camera
My shutter is broken d3100 how much to fix it
I have the same problem. I just took it to a camera shop. Labor will run 185-200 and parts will be upward of 250.
Oct 29, 2011 | Nikon D3100 Digital Camera
Cameras Logo
216 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
