Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
About the device adapter
Does uninstalling any one of the parallel devices lead to the uninstalling of the other?
    Sergeant:
  • 263 Answers
Let me assume you are talking about the USB hub. Then "Sefely removing" one device may remove them all. Simply unplug the cable wait 20 seconds, then replug it
Posted on Aug 15, 2008
SOURCE:
ISATAP Code 31?
receive error code 31 if the device driver is not updated.
As you have already updated the device try reinstalling the device driver and check if that works, if that does not resolve the issue you may ignore the error message, below link will you go more information related to this issue:
On a Windows Vista-based computer or on a Windows Server 2008-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark next to it in Device Manager, and you also receive an error message
http://support.microsoft.com/default.aspx/kb/932520
Steps to uninstall and reinstall the device driver:
Uninstall and reinstall the device from device manger. Steps to uninstall the device:
i. Click Start, type devmgmt.msc and press enter.
ii. Locate Microsoft ISATAP Adapter device
iii. Right click on the device and select uninstall
iv. Restart the computer for the changes to happen
Uninstall and reinstall the adapter from Program and features. Steps to follow
i. Click Start and choose Control Panel
ii. In Control Panel double click on the "Programs and Features" icon.
iii. Here you can find all the programs and items which are installed in Windows Vista.
iv. To remove adapter click once on the program and then click on Uninstall/Change and follow the prompts.
hope this helps
Jul 03, 2012 | Microsoft ISATAP Adapter
Vistascan 3.1
I tried to resurrect my Astra 1220P scanner to work with my WinXP Home machine. I began by calling UMAX, they told me I needed XP drivers and suggested that I purchase the VistaScan 3.55 driver CD for $18.00. They also told me to get a Parallel to USB Adapter Cable, which I purchased from Radio Shack. When the CD arrived, I went to work installing the cable & loading the drivers to no avail. The scanner does not appear in the Device Manager list under image devices or other devices, In fact, it is not anywhere in the list.
Of course the scanner does not work. I called them back and asked for assistance, they told me they could not guarantee operation of the unit using a Parallel to USB Adapter Cable...and sorry, we cannot refund the cost of the driver CD. Isn't that special - I was so looking forward to scanning some slides and film because I had previously purchased a Transparency Adapter.
Now I begin my search for a new scanner that will work with transparencies.
Anyone have a suggestion?
Nov 22, 2011 | Umax Astra 1220P Flatbed Scanner
Wireless adapter not found
uninstall the drivers
click on start then right click on my computer, then click on manage, the a page will come up, on the left side of the page you will get the option of device manager on the left, once you will get the device manager, click on device manager, you will get the list of devices, in the list of devices, click on network adapters
once you click on network adapters there would be an option of wireless adapter, right click on wireless adapter and click on uninstall, once it is uninstalled, restart the computer, it will detect the drivers automatically
Aug 14, 2011 | NetGear Push2TV TV Adapter for Intel...
I have HP Laserjet 4000 PCL6 printer with parallel port only. I purchased a parallel to USB cable to try and get it to work, but there seems to be no way to get it to print. There is no option for setting...
Many USB to Parallel, and USB to Serial adapters/cables just don't work well, due to the processing 'overhead' in the software of the drivers for these devices.
The parallel (or serial) device at the end of the cable just doesn't 'see' responses quick enough, so asumes it not to be connected to anything.
Network adapters are plentiful and cheap for these printers. Perhaps this is the solution.
Mar 18, 2010 | HP LaserJet 4000 Printer
While giving print command msg comes as communication error
1. Check the cables
2. Check wheather the printer is detected?
if detected
3.Uninstall and Install the printer driver
Still facing the issuse, then you need to double check the cable
If the cable is working fine then try to do the system recovery
Sep 17, 2009 | BafoTech BAFO BF-1284 Parallel Adapter
Address keeps changing
When you say the address changes, is this dongle device connected to a parrallel adapter running on your computer network?
If so you could try going into the network settings of your device and forcing that IP address that your on to stay on that device rather than having the router assigning it to you.
The other way is to leave the computer on. That should keep the same IP address as well.
Jul 02, 2008 | StarTech.com PCI1PECP Parallel Adapter
Need an usb to parallel cable
You may want to try this site. They have an assortment of USB to parallel printer adapter cables which will connect your parallel port printer to your USB port.
Good luck and kind regards.
Nov 08, 2007 | Computers & Internet
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at [email protected] if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
Error Printing to LPTUSB1 for the printer Brother Hl-1230 series
Connect the device to a different usb port. Download the newest software/drivers from the Belkin web site. Remove the old software and install the newest downloaded version. Please supply the error.
Apr 09, 2007 | Belkin USB Parallel Printer Adapter...
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
Ekse
Clive
Clive
