Question about Char-Broil 7000 Quick Set Gas Grill
I need a diagram of the upper warming rack. I can't get it back in.
    Brigadier General:
  • 4,736 Answers
Char-broil 7000 is really not a Model Number. Fortunately, there are only 2 Quick Set Grills. I have included a link to both manuals that you can download and print for future reference. Choice the one that matches your grill.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463741510%20english.pdf
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463666510%20english.pdf
Hope this helped you. Please let me know and Happy Grilling.
Posted on May 23, 2011
Kenmore 3380957 rev a won't get dishes clean
Make sure that that upper arm is free to turn. Check it while you have dished installed, because sometimes, dishes on the lower rack may stick up too high and hit it. Otherwise, check the back of the water-supply tube attached to that upper rack.... Is it lining up with the water feed port or hole at the backof the dishwasher? Is there a gasket that is either ripped or missing? And check that wash arm carefully.... Might it be split or bent? Are the holes on the bottom clear? (Those holes are usually angled to push the arm around; if they are clogged, the arm won't rotate.)
Mar 15, 2012 | Kenmore Dishwashers
Top rack automatically slides out upon opening door
This is actually a feature to allow the user easy access of sliding out the top rack. A look at the parts diagram disclosed that there is no mechanism activating this and therefore could be assumed to be gravity driven. It would stop a few inches due to the action or rather inaction of the rollers which would require user intervention (pull).
The only modification I could think of is to change how the inner rails are attached by inclining it to prevent the sliding out. The idea would be to lean in the upper rack to prevent gravity from sliding it out. Am not sure if inclining the entire dishwasher would affect the overall performance but it is also a possibility.
I have taken the liberty of including the diagram of the upper track should you wish to reference it.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 28, 2008 | GE PDW8680NSS Built-in Dishwasher
I removed all the racks from my upper oven (including the side racks) to self-clean and am getting the "remove racks" light. I've cleaned the oven before and never had this happen. The...
There is a button on the top receiver bracket on the left side... when you take the rack support bracket out you will see it. Take a damp sponge and go over that area, pressing the plunger/button in several times. That should do it. Sometimes grease build up can prevent the button from popping out all the way, so the oven thinks that the racks are still in there.
Aug 21, 2011 | Electrolux ICON Designer E30SO75ESS Oven
Top Rack doesn't get clean
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 12, 2011 | KitchenAid Dishwashers
Advice on removing upper rack needed thx
you may want to refer to the assembly diagram and see how the wheels and tracks are aligned. This should help you guide the rack out of the track.
Good luck.
May 13, 2011 | KitchenAid KUDM01FK Dishwasher
Top (upper rack) of dishwasher does not wash. bottom does mediocre job
Make sure top rack is backed up into water entry in back of diswasher. Also check to make sure holes are not plugged in rotating wash arm. You may have to wash your dishwasher..take out the racks and look to see if they have food gunked up on them, if so wash them off in the sink. Take out the top rack clips and wash the rails inside the tub if they are dirty. You can use a squirt bottle with warm water. Do this after you run a rinse cycle so that dried food gunk is softer. There are alot of places in this machine for food to stick then resurface later. you may try also adding vinegar and baking soda to a rinse cycle and then leaving in it soak before restarting it.
Feb 10, 2011 | KitchenAid Dishwashers
Need part no. 9741982 Upper Rack for my Kitchen Aid dishwasher. It is a discontinued item. Where can I find one?
My mom bought new racks for her dishwasher and now her dishwasher has died. I have both an upper anda lower if you are still looking for one.
Dec 10, 2010 | Maytag MDB3100 Dishwasher
How to mount a Bell bike rack on a 2001 Chev Blazer which has a glass window completely covering the upper section of the rear hatch.
The picture in the manual for this typical rack shows it mounted on an SUV with the upper support right on the glass hatch. If you think about it, there isn't really an forward horizontal force on the loaded rack.
Here's a picture of it.
http://biketrunkrack.com/bell-triple-back-locking-3-bike-trunk-mount-rack/
I contacted Bell Sports and complained about the lack of downloadable manuals. They said they are in the process of developing the website which will provide them.
http://www.bellbikestuff.com/
It has some basic stuff about helmets and tire changing right now. Stay tuned and check it once in a while.
In the meantime, they sent me the manual for the Doubleback/Tripleback Car Rack in English since that was the one I used as an example.
If you post your email to this solution I will be notified and will send it to you.
Aug 31, 2010 | Carrier 1--2--3--4 Bike Rack Holder...
Need an upper rack for a kitchenaid kdi21a
WHOOPS - turns out on that same diagram #24 is actually the top baaket.... and is $230.
I would think you could get an entire dishwasher for that price :D
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 23, 2009 | KitchenAid Dishwashers
Upper wash tube assembly came off back of unit. can not reattach.
We had the same problem with our Bosch 4800 and found that the upper wash arm and tube assembly should attach to the bottom of the upper rack (rather than to the back of the dishwasher). The wash arm and tube assembly slides in and out with the upper rack. When the dishwasher door is closed the tube assembly is forced up against the back mounting/water supply.
Nov 30, 2008 | Dishwashers
Char-Broil 7000 Quick Set Gas Grill Logo
380 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
