Question about Microwave Ovens
I have a kitchen aid gas range; model kgsc 308 lsso Oven takes very long to heat up; then seemingly. Fan has stopped working which usually is always on when baking, broiling .... Is it the fan I should replace or temperature sensor?.... Thank you. Very much
heatman101
  • 43501 Answers
SOURCE: the burners on the kitchen
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter
http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Aug 19, 2010
  • 248 Answers
SOURCE: I'm looking for repair manual
web search-kitchen aid range manuals- or -kitchen.manualsonline.com
Posted on Oct 15, 2010
rickead1
  • 1998 Answers
SOURCE: Kitchen Aid free standing range
so you have changed which piece exactly? have you done a ampere test to the ignitor?to assure that you have 3-3.3 amps on the wire for the ignitor also you would want to do a continuity test to the oven tempreture sensor should be around 1100 ohms at room tempreture if this were the gas model trying to figure out what you meant by the bake rod? you never replace any pieces until you have a postive confirmation due to your testing that the piece is bad. also do you have a multimeter or voltage meter this way you can perform the tests to assure which piece is malfunctioning. If you have any further questions please message me back and please remember when our chat has concluded in full to rank how this opinion has helepd in your appliance situation Thanks again
Rick
Posted on Dec 24, 2010
heatman101
  • 43501 Answers
SOURCE: My kitchen aid over the
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 03, 2011
Macmarkus
  • 2605 Answers
SOURCE: On a Kitchen Aid gas
Welcome to FixYa.
I have a suspicion of what may be at fault, but first a couple of questions before I attempt to diagnos your oven.
1) when you said in your post "the flame will go out before the oven has reached set temperature", how close does the temperature get to the setting ?
2) does the oven cycle back on eventually
3) does the broil burner appear to work ?
I'll watch for your reply and hopefully I can help you move forward from there.
Regards,
Macmarkus :)
Posted on Mar 30, 2011
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
My kitchen aid micro wave stopped heating the food. Everything seems to be working. Model Khms155L. I want to replace it but it is no longer in production. Is there a replacement model that is an exact...
Take your measurements and compare them to the measurements from various microwaves online, then go to the store that has the same measurements. I wouldn't use the microwave for fear of a fire.
Dec 25, 2014 | Microwave Ovens
GE over range microwave JVM1870SK03 stops working approximately 3-4 minutes into heating cycle
<--- I'm happy to help you. Yes, it's overheating and the magnetron's thermostat is opening to protect the magnetron until it cools, then it turns power back on.
It could be due to a failed or unpowered cooling fan motor. Have your cooktop lights gone out recently?
When a cooktop bulb goes out, a surge may occur if the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
I repair boards in such cases.
It may instead be a dirty filter.
If the unit is set to recirculate, it will use a charcoal filter, which should be replaced every 6-12 months.
If it's not set to recirculate, then the grease filter may just need to be washed.
Or your ductwork may be blocked by an animal nest or debris. The entire duct and the outside vent / flap must be clear.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Dec 20, 2013 | GE JVM1870 Microwave Oven
My kitchen aid over the range microwave Model No; KHMS105EWH-0 stop heating.
Basic
heatman101
Feb 03, 2011 | KitchenAid Microwave Ovens
The burners on the kitchen aid superba range work, but the oven doesn't?
heatman101
Aug 19, 2010 | KitchenAid Microwave Ovens
Our Kitchen aid microwave works for a minute or so and then stops. It will not run for a while after that at all.....
Likely the cooling fan for the magnetron has failed. Then the thermal cutout on the magnetron will cut off until the magnetron cools.
Take unit for servicing. The fan should not be too expensive.
Jan 30, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Ge jvm1540dm2ww over the range unit: have a gas range and the fan on the above mounted microwave once in awhile turns on automatically while something is cooking on the range below it....
The heat sensor in the electronics panel senses the rise in heat from the stove below. Once the amount of heat reaches a certain level, the cooling fan turns on to keep the electronics inside the microwave cooled.
I wouldn't worry about it. mine does the same thing.
Jun 19, 2009 | Microwave Ovens
Microwave Ovens Logo
55 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
