Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
Just install rebuild light engine.when i install back i the tv it stays on for a very short time.i take the back off and the tv stays on.could the fan be running to slow to pull the heat out or is there something els going on.install lamp 4 months ago
  • 643 Answers
Try using a vacum with hose attachment and pull out any dust and dander out of not only the fan, but all the vents on the sides. Yes there is a thermal sensor that may be tripping the power.Hope this helps.
Posted on May 23, 2011
Trying to put starter back together using same bushings but can't get them to stay in place so I can put them over the shaft. Please Help!
Mark, It can be tricky, use small ***** driver to push back brushes one at a time while working armature in place or if you can get a buddy to hold them both back while you slide armature in place.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to rebuild Briggs and Stratton starter motor replacing bottom end cap...
How to rebuild starter small engine
STARTER REBUILD on KOHLER KT 17HP Bobcat UTV Engine wmv
brush installation AVI
Apr 02, 2016 | Kohler Command PRO OHV V-Twin Vertical...
Low oil pressure, and light knocking noise from back half of motor. (after engine is warm)
If the pressure is low it will turn the light on. If you have a light and hear knocking it's a sign that a rod or main bearing has worn to the point that it's allowing oil to escape from the crank, thereby lowering pressure to all other components. There is no "fix" for that short of a bearing replacement,
Expensive, and most times not worthwhile as debris from the bearing gets into the oiling passages and causes more problems shortly after the repair. Best option is a scrapyard engine or total rebuild.
May 27, 2011 | 1992 Buick LeSabre
I HAVE A CHEVROLET 2001 TAHOE AND HAVE NOT HAD ANY PROBLEMS WITH THE ABS IN THE LAST FIVE YEARS OF OWNING THIS VEHICLE. HAD A ABS MODULE PROBLEM SO HAD IT REBUILD. AFTER REBUILD I STARTED HAVING...
There is a ground wire connected to the engine block. Look for it on the back passenger side of the engine towards the top. Remove it and clean the connection and the wire connector and replace. Sometimes they get real bad and throw the ABS light on. Sometimes a brake light out can throw the ABS light on.
  • You said you rebuilt the ABS module, do you have a short in it you are missing? The bulletin for this originally suggested to replace the module and was corrected because the ground itself was the major offender.
  • Try to reground the EBCM. The code 0265 says "loss of communication with the brake module" The EBCM Ground is located on the frame beneath the driver's side door. If multiple grounds are found in this location, the EBCM ground can be identified as the heavy (12-gauge) wire. Clean the area, front and back, using a Whiz Wheel.
  • Install the ground, then the washer and then the bolt to the frame. Important: It is important to use the bolts, washers and nuts specified in this bulletin. These parts have been identified due to their conductive finish.
  • Install a washer and nut to the back side of the frame.
  • Tighten the nut to 9 N·m (79 lb in).
  • Cover the front and back side of the repair area using Rubberized Undercoating. An additional check can be made to ensure a good connection for the Battery Cable to Frame ground.
Regards, Tony
Apr 18, 2011 | 2001 Chevrolet Tahoe
TV comes on stays on for a short time than goes black with loss of sound green flashing light untill TV comes back on. takes maybe 2 min.
Jul 11, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
My TV switches of automatically on startup. It started occurring 20 days after I switched a new bulb. At first it would turn off and turn back on for about 6-7 times and then stay on. After a while it does...
sounds like you r color weel is going bad bad thing is that your color wheel in most of the toshibas is in the light engine and can not be changed seperaly so if this is your problem then your looking at 600-900 replacement or 300-400 to rebuild
May 18, 2010 | Toshiba 52HMX84 52" Rear Projection...
Status light stays red no tv no power light
TV requires service. but try to reset it by pressing system reset
Apr 17, 2009 | Mitsubishi LT-52244 TV
My Samsung DLP TV is making a noise that sounds like a bad fan.
This high pitch noise comes from the color wheel. Now is unbalanced and the noise is going to be even hardest with the time. send it to change now. this part is inside the light engine
Dec 26, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
About 52 in zenith tv fan
If the air filter needs cleaning The fan will stay on for an extended time to cool the light engine. Try cleaning the air filter that should solve your problem
Mar 11, 2008 | Televison & Video
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
35 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
