Question about Whirlpool Washing Machines
The machine shows clean pump light and won't wash
  • Whirlpool Master
  • 3,051 Answers
Hello there and thank you for choosing fixya
This is one of the better features of this machine it is simply telling you that the pump filter is clogging up and needs to be cleanned out
This is done by first unplugging the machine (THIS IS A MUST THIS ALSO WILL ELIMINATE THE ERROR WHEN YOU ARE THRU)
now you have to remove the lower panel by the floor in the front there may be a screw on the inside of the lip on each side of the panel ok. then once this is off look into the area and you will see the pump now on the pump or just to the side of the pump you will see what looks like a plug or a round thing with a place you can get a hold of and unscrew simply unscrew it if it is really hard you may have to use a pair of pliers or a wrench once it is off clean it really well and lookand see if therere is stil stuff in the piping then clean it really well and reinstall the plug snug so it wont leak then plug it back in and attempt to retry the machine ok the error should be gone if not let me know and i will show you what needs to be done next.
Hope this is very helpful for you
Best regards Mike
Posted on May 23, 2011
Noisy pump on bosch 300 series washer
This video will show you how to clean the pump and how to find the fault on a washing machine that won't drain or empty the water away on Bosch, Neff or Siemens. Please remember to subscribe to our YouTube channel for all appliance tutorials
a thumbs rating is appreciated for answering your free question.
Aug 19, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Wfs1072aw
try following this video it's on a bosch but basically the same
Jul 30, 2013 | Washing Machines
Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Nov 03, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Zanussi electrolux zwf14581w won't start, displaying Er40
my father had a zanussi dishwasher that did the same thing, turns out one of the door sensors had gone and would not release the lock. had to get an engineer out, luckily it was under warranty.
Apr 05, 2012 | Washing Machines
Washing machine won't drain
Bosch maxx 5 washing machine will not drain This video will show you how to change the pump washing machine
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 19, 2012 | Washing Machines
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
Washer washes but won't drain and won't proceed through the rest of the cycles. It just humms.
hi it sounds like your pump is blocked have you tried cleaning your filter these pumps are magnetic and will sit and hum if blocked
Nov 15, 2011 | Washing Machines
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal De
