Question about IBM ThinkPad R40 2722 Notebook
I bought a used ibm r40, changed the hard dsrive and tryed to load xp pro. after loading the system files the computer wants to reboot to finalise. After this it goes right back to fresh install start.
    Sniper:
  • 79 Answers
When you say you tried to load XP Pro, did the hard drive already have XP installed or are you installing it fresh from a CD? If you are installing it fresh from the CD and it is asking you to reboot, it seems as if you are letting it try to boot again from the CD. When it reboots and says "Press any key to boot from CD..." don't press anything, just let it boot. It should finalize the installation there!
Hope that helps!
Posted on May 23, 2011
I am unable to get windows xp to load onto my ASUS A2500H anymore. Everything was working fine for a long time, even with an external HDD attached until today. All of a sudden the laptop died and when...
The best you can try is to remove the external HDD and see if computer boots..
If it does, you know where the problem is..
If it doenst, reboot computer, start tapping F8, if you get advance boot options, try to boot computer with Save Mode, Perform system restore from save mode.
If the above doesnt work, you need to perform repair installtion of Windows XP.
Apr 11, 2011 | Computers & Internet
I bought a used IBM R40 whose hard drive failed. I tried installing someone else's XP Pro on my computer and then trying to use my license key from the bottom of my machine. It didn't work. I get the now...
must use an OEM install copy of the version on your key sticker. retail and upgrade versions will not work. i had the same problem with my r40. had to use e-donkey file sharing program to find it.
Aug 07, 2010 | IBM ThinkPad R40 2897 Notebook
My laptop will not boot up, instead it goes directly into a screen I haven't seen before and says, "Operating System not found"
usually this means that the previously installed windows/linux operating system is corrupted....best to re-install operating system via disc windows/linux....so that it replaces corrupted informatiom/instructions on hard drive....if you have files you want to keep then dont do a format on install as you will definately lose them......
Jun 12, 2010 | IBM ThinkPad R40 2722 Notebook
Window Installation Problem at first Setup
disconnect your hard drives, see if the setups loads after that, if it does not, then the issue is on your mainboard.
Sep 11, 2009 | IBM Computers & Internet
T30 wont reformat
Sounds like you have a faulty hard drive. Can you see or detect the hard drive in the BIOS? To test the hard drive, remove it from the laptop and connect it to a USB hard drive adapter and plug it into a working computer's USB port. If this computer sees it as an external hard drive and you can open the various folders and files, then it os OK and the fault is in the laptop. If the hard drive is faulty, then you need to replace the hard drive in the laptop and install Windows to get the laptop working again.
Jun 03, 2009 | IBM ThinkPad T30 2366 Notebook
Thinkpad won't load xp
Try setting up xp again. If you need the files as is, try repair from the xp cd while boot from the cd.
May 27, 2009 | IBM ThinkPad T21 2647 Notebook
Use second hard drive
The Windows operaring system is on your 1st drive (ie C drive) and if you change it to a slave drive the computer won't work.
You need to set the jumper on the 2nd hard drive as a slave drive and leave the original drive as the master drive expecially if the 2nd drive is on the same IDE controller and cable as the 1st. hard drive.
It doesn't matter if the 2nd drive is set to master or slave if it is on the 2nd controller.
When you boot up you should see both hard drives and can copy files from one drive to another.
Apr 08, 2009 | IBM ThinkPad R40 2681
XP won't boot without IBM 10/100 EtherJet NIC
Check the BIOS to make sure the machine is not trying to boot off of the network card (PXE boot) and make the hdd in question the primary boot device.
Feb 26, 2009 | Computers & Internet
Just purchased IBM Intelistation 6221..installing windows????
hi! try this. reboot your cpu, then press the CMOS setup key (del), then select load default setting, then go to hard disk detection settings, select the LBA setup. I believe you know how to manipulate the CMOS setup configuration. if still doesn't work out, bring it to the service center near you and ask for assistance, Im sure they would love to help you. Have a nice day!
Dec 20, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
Can't load xp pro onto my IBM Lenovo M52 Desktop
Check to see if the CD is an upgrade. If so, load an older OS first and then use the CD to upgrade.
Dec 11, 2008 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
IBM ThinkPad R40 2722 Notebook Logo
60 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
