Question about Garden
Starts, but wont run, stops running after a few minutes-then wont start for several minutes. Changed oil, spark plug is good-cleaned carburator, checked air filter.
    Novelist:
    Champion:
  • 222 Answers
You didn't mention what machine you're referring to. My guess is that is is still the carburetor. You missed something. Happens to me all the time. Sounds like a fuel problem if it "Starts, but won't run".
James
Posted on May 27, 2011
2000 yamaha grizzly issues when warm
Check oil level capacity, to ensure in specs. Check spark plugs, ensure its clean and correct plug for your quad.the only other could be is ign coil breaking down when warm. Check fire at plug when this happens. First ensure oil level is correct. Make sure your electric fan is on when bike is warmed up.
Nov 07, 2017 | ATVs
95 Dodge Neon
common problem for dodge 4 cylinders...
never lower the oil level unless its real high on the dipstick..
you have the replace the spark plug guide seal.... it seals it from oil in the valve cover going into the spark plug guide and killing the spark... yes oil goes past the threads on the plug....
just did the valve cover on my 94 jaguar... has the same setup valve cover design
Jun 09, 2013 | 1995 Dodge Neon
Why does my 86 2.9 l. ranger kill spark plugs
your truck is running too rich with fuel if you have a carburator have it check
Sep 18, 2012 | Cars & Trucks
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
My dewalt air compressor with honda gx160 5.5 engine starts runs for 2 secs then dies. then wont start for several pulls. after a minute it will start but then dies again. Ive changed plug, gas cleaned...
Control your OIL level in the honda engine ? take of (beware) for only a short moment your oil alert sensor control to know if the level is correct to reset the sensor and if the engine is running for a short time good connect it again on the working engine to reset. if the level was not correct. Control the fuel hose tank filter , change sparkplug control spark on color and a measure on the switch off connector for some dirth or connection lines or other problems that will connect to massa.
Feb 17, 2018 | Air Tools & Compressors
Briggs and stratton runs good for 5 minutes then starts to smoke
My first thought is that the throttle lever is being pushed so far forward ( max RPM's ) that you are running the engine 1/2 or better choked
Look at the choke butterfly with the throttle in your normal run position it should be completely open
This may require and adjustment in the control rods or might be as simple as not pushing the throttle wide open
Apr 06, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman riding mower starts rides a few minutes then stops
Make sure that when you check the oil that the mower has sat I say for at least 5mins. Your mower might have an oil sencer. If not I think it might be the coil gettin hot and shorting out.
Aug 23, 2009 | Garden
Mower will not start
you could have water in gas,look in the gas tank for any bubbles floating on bottom of tank this is water empty gas from tank and remove carburetor bowl too remove water from it .
May 13, 2009 | Garden
Garden Logo
218 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
