Question about Tilia FoodSaver VAC420
The Vac runs and runs but does not seal. Can you order a replacement seal unit in Canada and where?
  • 300 Answers
Practically speaking, before you start thinking about spending money on replacement parts, please visit here:
http://www.foodsaverblog.com/
You will see a comprehensive list of models and prices.
Then you can decide what to do.
You can also check here: http://www.foodsaver.com/Index.aspx for your nearest retailer of parts and supplies.
Posted on May 23, 2011
2000 blazer hesitates from a stop when accelerated
might be time for a fuel pump.
good luck with that.
my 1996 is in for total fuel system replacement.
...my pump $300..........4 door. (canada)
...chek for vacuum leaks. cud be MAP sensor vac-line.
There was a vac leak on my 96. @ or near brake master cyliner.
....the line rubbed on a sharp metal edge. I replaced with steel at that location. // the brake vac tank rusted at bottom..and was replaced.......if that helps later??
Oct 19, 2014 | 2000 Chevrolet Blazer
Hoover steam vac modal # F5915905
I can tell you this you need to replace the hoses and seals that run through the cleaner and are used to carry the water from one place to the next and replace the sprayers to
Mar 20, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
We are a l business in Ontario, Canada which is open during the summer months. We have purchased a Hobart SR24H dishwasher recently to replace an old machine. As we are not open for the winter months, and...
Hi James, This may sound a bit odd but... if you really want to make sure all of the water is out of the unit just remove the drain hose and use a shop vac to draw out all the residual water. Then just place about 1 to 1.5 cups of vegetable oil in the sump for the winter. I do not recommend anti-freeze due to the associated health reasons of same. Then next season remove the drain hose and draw out the vegetable oil before returning it to regular service. This works well for resorts in cold climates. The vegetable oil can over several seasons fatten up or harden pump seals but is no more harmful than the anti-freeze on the seals.
Thanks for choosing FixYa,
Kelly
Oct 30, 2010 | Hobart SR24-H Built-in Dishwasher
I have a foodsaver and it sucks the air out but won't seal. What do I do? We're trying to save some frozen fish and it just sucks and sucks but doesn't stop or seal. Any ideas?
The bag is wrinkled or the gaskets are leaky, it has to pull down to a set vacuum in order to shut off and heat the strip to seal the bag. For the right now dilemma try pressing down on the lid while it's vacuuming and start looking for gaskets at foodsaver.com
May 29, 2010 | Tilia FoodSaver V2240
My 1992 cavalier shakes while idleing in gear with foot on break but stops while in motion or idleing in park?
hi from uk the symptoms you clearly describe sound like your brake servo /vacuum cylinder is at fault ie whilst brake pedal is off all is ok ? but when pedal pressed engine falters? this is a sign that the seal on the vac piston inside the servo unit is allowing air /atmospheric air to enter the servo as you brake and this assists braking however when inner pistonseal is leaking at some point inside the servo bore ie a scoared or rusty point ?the atmospheric air passes the piston/seal and so the vacuumpipe to servo is drawing this air into inlet manifold resulting in upsetting fuel mixture ie weak too much air ratio to fuel resulting inshaking engine you describe ? try this?? if you disconnect vac pipe from servo unit then seal off the pipe with thumb then ask assistant to start engine then it should run ok ? also it should be ok when b/pedal pressed remember there will be no vac assistance ?? if above test prove right ? then you will req a new servo unit only not complete master cylinder too ? you can diy this then bleed brakes after replacing servo ? hope this helps
Feb 27, 2010 | 1992 Chevrolet Cavalier
Hoover steam vac leak from the bottom when tank has water in it when not running but tank is not leaking
The tank is not sealing to the black rubber ring seal on the lower handle. make sure this seal is not displaced.
Nov 19, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Want to rmove sludge,organics from pod wihout rmoing the water
You may need to develop a centrifuge in line with your intake to throw off water, or a screened water take up which will drain back to your source, but it must be sealed while running.
Central vacs have an optional water pickup device that works in line for spills . I do not like these but the concept could help your scenario. The idea is that there is a short hose, then an inline pail with a drop bucket for the water and a flow thru intake and out port to the actual vac piping so the air can continue thru to the vac without carrying the water into the wall. Gravity makes the water drop and allows the air to continue down the vac line, but the sealed pail ensures you have continuous suction.
In your case you would have to rig a shutoff float as well. Look up a company called VACUMAX on the INTERNET. I think they might be of help as well if they are still in business,around Elmira Ontario, Canada
Sep 17, 2009 | Hoover U5507900 Elite Rewind Bagless...
1999 dodge cummins 2500 front axel seals
you need to pull off wheels,brakes, rotor /unit hub bearing, both axles and intermediate shaft, as well as the vac disconnec ton the front axle tube. if only the right side leaks then only then only pull the right axle and intermediate shaft and vac disco. it is a trick with a miller tool to replace the seal. the left side seal is inside the diff and the carrier has to come out to replace it. pete
Jun 09, 2009 | 2004 Dodge Ram 2500
Leaking fron the blade assembly
HELLO
there are two possible solutions
1 change seal or 2 change seal and blades in order to improve the life or your blender.
bye
j roman.
Mar 07, 2009 | VillaWare 5785 Smoothee Bar Work Top...
Bissell laminate floor cleaner wet vac and flips to dry vac
You just need to replace the cap and valve part # 2036919, You should be able to order the part thru Bissell.com, or they will tell you who you can call close to you.
Dec 06, 2007 | Vacuums
Tilia FoodSaver VAC420 Logo
703 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Ed Mac
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
