Question about HEALTHRIDER R60 SoftStrider Treadmill
My healthrider r60 suddenly stopped while I was running and won't turn back on. I tried different outlets so I know it is getting power.
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: healthrider r60 stops when it reaches 4mph.
Unplug unit and remove the motor shroud you will have to do DC Amp Measurement.
Measure on the hot DC lead (usually red) going from the controller to the drive motor. If you have a simple multi-meter with a DC amp test setting the best way to test is to put the meter inline on the red motor lead with alligator clips. If you have a more expensive clamp meter, clamp the meter around the red motor wire. Run the machine at 2.5 MPH without a person on the belt. If the motor and drive system are healthy, you should have a reading in the 2-3 amp range. Then walk on the treadmill at the same speed. With a person of average size (around 200 lbs.) you should have a reading in the 6-8 amp range if the belt is good. The readings will fluctuate more with a load but you are looking for an average reading but you shouldn't see spikes above 10 amps. If the amp readings are high without a load, you could have a problem with high resistance in the motor, a bad bearing, or over-tightened belts. Regular readings without a load but high readings with a load indicate a worn belt and/or deck.
Posted on Jun 28, 2010
Belt shifted to side
You need to tension the belt .
Turn the machine on and up to 4 kph or 3 mph.
Stand on the side rail with 1 foot and try and stop the belt with the other. If you can stop at all tighten the rear roller with the allen key provide with the machine. Turn it on both sides clockwise 180 deg whilst machine is still running. If still loose tighten another 90 deg.
Jan 27, 2013 | HEALTHRIDER R60 SoftStrider Treadmill
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Healthrider S500i HRTL12990 belt won't run
HI,
If you can then before replacing the Motor control board do one thing. Replace the IGBT on the control board. Igbt is the component which drive the motor. It will not cost a lot. The only thing is you should be very careful while working on the motor control board because there you can see two capacitors which is capable of store charge for a long period of time even the treadmill is unplugged. Before doing work on the control board you have to discharge the capacitor. If not it will lead to serious electric shock. You will get many pages on web to know how to discharge an electrolytic capacitor. I have add the picture of the motor control board with the igbt marked. You can find the part number written in its frond side. Replace the IGBT first.
Ajin
Jan 19, 2012 | HEALTHRIDER Exercise & Fitness
Demudifier worked great, all a sudden it just stopped. No power. Now it won't start up. What should I try?
First, check the outlet that it's plugged into, to make sure that there's still power to the outlet. If there isn't, then the circuit breaker for that outlet has been tripped, in your home's circuit breaker panel. Leave the dehumidifier unplugged and reset the circuit breaker. If it trips again, without the dehumidifier unplugged, then the outlet is at fault. Perhaps there's a loose wire connection or the interior of the outlet is cracked.
If it didn't trip without the dehumidifier plugged in, plug the unit it in,. But, before you do, make sure the dehumidifier's Master ON/OFF Switch is OFF. Once it's plugged in, turn the Master ON/OFF Switch to ON and set your controls. If it runs now, GREAT! If it trips the circuit breaker again, there's either a short in the power cord or an internal electrical short. Which will require extensive troubleshooting to find.
Hope this helps you solve the problem. Please let me know. Thanks.
May 05, 2011 | Fedders A7DH45B2A Dehumidifier
Incline motor stays on going down, and will not respond to the controls. healthrider R 60
could be bad incline sensor or c/board is going bad. one more try bipassing the board with power to the incline motor fully powered 18volt batt will or higher will move the motorby flipping thr wires on the bat the incline should go up and down. if working ok then check board
Mar 16, 2011 | HEALTHRIDER R60 SoftStrider Treadmill
Healthrider r60 stops when it reaches 4mph.
Jun 28, 2010 | HEALTHRIDER R60 SoftStrider Treadmill
HEALTHRIDER R60 SoftStrider Treadmill Logo
77 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
