Question about Air Tools & Compressors
Whats the torque for 2000 chevy S-10, p/u, 2.2 engine, rod and main bearings
    Problem Solver:
  • 20 Answers
The torque on the main bearing caps ----------- 31 ft. lbs. first pass --70 ft. lbs. final pass ---start in center & work out to edge /////////////// torque for connecting rod bearing nuts is 38 ft. lbs. ----- recomended to oil all threads before assembly....
Posted on Jun 07, 2011
What the torque specs. For a 2002chevys10 4.3vortex mains and rod bearing
Torque Specs Database
Type: Dim: Length: Head: Nut Grade: 20 Ft-Lbs 240 In-Lbs 27.12 N-m Connects: Connecting Rod To Engine Block Years: All Vote Record: Vote Note: Vortec - Rod Cap Nuts - 2 Steps: 20 FtLbs; +70degs
http://ww2.justanswer.com/uploads/ZZdaryl/2009-06-14_153454_torque.pdf
Main Bearing Cap Bolt 4.3L Step 1 15 ft lbs (20) Step 2 Additional 73 Degrees
i don't know if that's correct for main bearing caps since another link states it's much higher
4 3 Vortec Piston Specs eHow
hopefully a GM guy will chime in to confirm the main bearing torque
the rod bearing torques are the same on all the other links
Mar 25, 2015 | 2002 Chevrolet S-10
What are the rod and main bearing torque specs for a 96 chevy S-10 2.2?
The torque spec for the main bearing caps on a 2.2 are 105 nm or 77 ft lbs all. But you know if your doing the crank there is a lot more to it then the torque . The main bearing clearance is 0.0006 to 0.0019 and the rod clearance is even tighter 0.00098 to 0.0031.
the connecting rod 45Nm or 34 lbs ft i hope be help you
Well good luck
Mar 14, 2013 | Chevrolet S 10 Cars & Trucks
I need the torque specs for the main bearing and conecting rods for a 2000 chev S-10 W/2.2L engine code (4)
I show the main bearing torque to be 70 ft.lbs.
The rod caps are torqued to 38 ft.lbs.
Best of Luck to you..
Aug 26, 2011 | 2000 Chevrolet S-10
Need to know crankshaft main bearings and rod bearings torque specks.
2 Different size engines for that year. If you have the 2.2 the main bearing caps are 70 ft/lbs (final torque) & the rod bearing caps are 38 ft/lbs (final torque). If you have the 4.3, the main bearing caps are 77 ft/lbs (final torque) & the rod bearing caps are 45 ft/lbs (final torque). I hope this helps and good luck.
Mar 13, 2011 | 1996 Chevrolet S-10 Pickup
I need to know the torque specs for rod and main bearings on a 4.3 chevy engine
MAIN BEARINGS BOLTS TORQUE 75 FT LBS ROD BEARINGS TORQUE 20 FT LBS + 70 DEGREES. CRANKSHAFT PULLEY DAMPER BOLT 70 FT LBS
Nov 01, 2010 | 1993 Chevrolet S-10
I have a v-6 2000 nissan xterra. What are the
Rod bearing torque
Step 1 - 10-12 ft.lbs
Step 2 - 60-65 Degrees more
Main bearing caps torque
66-74 ft. lbs
Jul 02, 2010 | 2000 Nissan Xterra
Need torque for a 2000 Toyota Celicia GT 1.8L
Crank Main caps Tightening Torque
For the 12 Pointed Head Bearing Cap Sub-Assembly Bolts
Start from center bolts and tighten in a clockwise rotation working out
Step 1 all bolts 22 Nm or 16 ft lb
Step 2 all bolts 44 Nm or 32 ft lb
Step 3 all bolts 45 degrees additional clockwise rotation using an angle indicator.
Step 4 all bolts 45 degrees additional clockwise rotation using an angle indicator.
Hexagon Head Bearing Cap Sub-Assembly Bolts
1ZZ-FE Engine 18.5 Nm (14 ft.lb)
2ZZ-GE Engine 18 Nm (13 ft.lb)
Connecting rod:
1. Apply a light coat of engine oil on the threads and under the heads of the connecting rod cap bolts.
2. Install and alternately tighten the 2 connecting rod cap bolts in several passes. Torque: 1ZZ-FE: 20 Nm (204 kgf-cm, 15 ft. lbs.) 2ZZ-GE: 30 Nm (306 kgf-cm, 22 ft. lbs.) If any of the connecting rod cap bolts does not meet the torque specification, replace the connecting rod cap bolts.
3. Retighten the cap bolts by 90° more
4. Check that the crankshaft turns smoothly.
Mar 18, 2010 | 2000 Toyota Celica
WOULD YOU KNOW THE TORQUE SETTINGS FOR MAIN BEARING AND BIG END BEARING CAPS FOR ISUZU 4JG2 ENGINE
Mains Stage 1 83nm
Mains Stage 2 167nm
Big ends Stage 1 29nm
Big ends Stage 2 45 - 60 degrees
Hope this helps
Jul 10, 2009 | 1994 Isuzu Trooper
Torque specks
hi 1999 chevy malibu head bolts 1-8 40 ft lbs bolts9-10 30 ft lbs tighten all bolts an additional 90 degrees
rod bearings 18 ft lbs plus additional 80 degrees
head
top row of bolts 9 3 1 5 7 bottom row 10 6 2 4 8 from left to right
Feb 12, 2009 | 1999 Chevrolet Malibu
Torque specs.
connecting rod = first pass 18 ft lbs , second pass 75 degrees
main bearings = first pass 37 ft lbs , second pass 77 degrees
wow that wasn't easy to find for some reason .
Jan 01, 2009 | 2005 Chevrolet Impala
Air Tools & Compressors Logo
69 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
