Hello, i've just brought a samsung 46" series 8 led. and my aerial connection wont fit into the connection on the back. Is there a special slimline connection i have to buy its got a note on the back of t.v stating 14mm max connection width.. if you could let me know what ariel connection to buy that would be great thanks...
  • 643 Answers
Yes the Tv should have come with the tv. Sometimes its stuck inside the packaging. If you cant find it you have to order it from Samsung. I would go to where you purchased tv and see if they have any spares. Hope That Helps.
Posted on May 23, 2011
How fix samsung led tv screen flash/flicker problem.flashing with in a seconds gap.
Sounds like your HDMI connector. Press and wiggle the connections on the set and the converter box.
Jul 10, 2014 | Samsung UA32F5500AM 32" Series 5 Smart...
Bravia NX720 55
I have the same problem, called sony up but they are not responding back. The tv is still under warranty and brought it from Amazon. My situation is same but my led error code is 4 or 5 flashes. Does any one knows what's wrong with it.?
Sep 09, 2012 | Sony KDL46NX720 - 46" BRAVIA NX720 Series...
My Samsung 40" 8 series LED has stopped responding
Look for anything blocking in the sensor panel of the TV, like glue, gum or any other sticky substance, which might obscure communication. If these are ok, the sensor part has to be looked into.
Aug 21, 2012 | Televison & Video
PN63C7000 plasma turns on but shows no image.
HERE'S THE ANSWER TO YOUR PROBLEM:
There could be a problem with your aerial or set box if there is something wrong with your TV picture or sound. Don't forget that there may be work going on at your local transmitter, or some kind of local interference.
Here's what you've got to do: Check with the local neighbours or another TV connected to a different aerial in case you are not the only person's aerial affected.. If only your TV is affected, the problem is likely to be in your TV, set-top box or aerial. If other TVs are affected, it's more likely to be caused by work at your local transmitter, or possibly the weather.
Your problem is solved. Thanks.
Jul 04, 2011 | Samsung PN63C7000 TV
How do i connect my tv aerial to the panasonic tx-32lxd1? Do I need a dvd player to connect the aerial to. If so, it appears like I have to use a dvd palyer with freeview (the cheaper dvd players do not...
No, you plug it in directly in the antenna socket at the rear of the tv.
http://www.avforums.com/forums/attachments/lcd-led-lcd-tvs/12427d1113566868-panasonic-tx32-lxd1-lxd50-scart.jpg
You just need a special connector if you have the australian model, like in the picture above. Otherwise it just plugs in as explained in the user manual. If you need the manual
http://diplo-best.com/314.php?k=2e82a812e1d673595f5f6fcff561ba40&ID=199713&q=PANASONIC%20TX-32LXD1
Jul 03, 2011 | Panasonic Televison & Video
When I turn On my monitor, it is displaying black screen after the message "No Signal - Analog" (normal/usual message). When I disconnect the VGA cable from the monitor, it shows the message and...
The VX series are cheaply made with cheap caps and they failed due to bad caps, see my pictures here: http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/Viewsonic%20VX2235W/
VX2235 came out years (2006) ago so I cannot see that it will be only 8 months old. I fixed many of these VX series.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 24, 2011 | ViewSonic VX2235WM Monitor
Can't find the "wireless remote control" on my
hi,
LE-46B650T not support wireless remocon.
Only model C series already supported.
Mar 21, 2011 | Samsung LE-46B650T 46" HDTV-Ready LED TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
