Question about Garden
I have an ariens- 927046 rm-1028 riding mower the friction disk is scored in some places in second the tractor wont move unless you help it the friction disk and wheel where changed last year at a dealer i need to know how to adjust the tension on it if there is one because i want to machine the surface sraight then change the friction wheel if theres no ajustment im going to shim the disk the same as what i removed to get it smooth also i would like to know if the friction disk is supposed to be textured or smooth
SOURCE: mower wont start problem is with carb i think. need a manuel
need more info like is the engine spinning over and not cranking, if it spinns over check for spark at the spark plug, if you have spark you now have a fuel problem, if it doesnt spin over at all its probly in the battery or starter. to find out if its a fuel problem just spray carburator cleaner in
too the carburator it dont take much, then try cranking it and see if it runs if it does more then likely the carb needs to be taken off and cleaned, agaian not that hard of a job, just get the carb off and brake it down and spray carb cleaner in every hole in the carb,,,, good luck
Posted on Mar 26, 2009
SOURCE: drive belt
You may find that you have the wrong belt - I bought a belt for the correct model and then found that there are two different sizes depending on the exact model - they are 3 inches different in length for my model CTH160 113" and 110". Got correct belt and fits properly now.
Posted on May 16, 2009
  • 10865 Answers
SOURCE: I have a craftsman riding lawn mover 42" model #917270812
Hi Paul It sounds like the belt is worn, stretched, or possibly just two long for your machine. Save yourself a lot of aggrivation by checking your operator manual and getting exactly the right belt for your mower.
You don't say how old your machine is but if it has been mowing for many, many hours, the tensioning spring may need to be replaced. If that is the case you can order a new one at Sears.com
Posted on May 20, 2009
panilling9
  • 284 Answers
SOURCE: Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Posted on Jun 14, 2009
mowerman1857
  • 389 Answers
SOURCE: ariens 1440h cutting problem
moz-screenshot.jpgGo to this site: http://www.ariens.com/corporate/pages/partsradar.aspx (copy and paste in your address bar)
follow the instructions given and you can download a VERY GOOD picture of where it goes
Posted on Sep 29, 2009
1028 rear engine riding lawn mower model # 927046 is not moving when in gear. Was told I needed a drive box unit for it
check to see if the key in the axle is in place or if you put it in gear the axle turns in the wheel . is the pulley in place and not loose. the belt is good you said. but the pulley may be stripped. (axle key, belt, pulleys, or belt off of pulley)
Nov 19, 2016 | Garden
How to relace drive belt on ariens tractor a20va46?
There are multiple belts on the Ariens A20VA46 lawn tractor. Which belt are you asking about?
Service and Owner's manuals can be downloaded from the following link: Find Manuals by entering your tractor's model and serial numbers.
The deck drive belt is easy to change by releasing spring pressure on the idler pulley (usually under a plastic cover). See the user's or service manual for directions from the above link.
The two transmission belts are somewhat more difficult, but are usually long-lasting. The newer type of continuously variable transmissions used on these tractors have a friction belt like a snowmobile but under much less load. As a result, they are long-lasting. The engine to transmission belt is a conventional V-belt and may require occasional replacement. Usually, there's a similar tensioner pulley you would release in order to replace this belt.
Jul 14, 2014 | Ariens 34 In. Zoom Series Riding Mower
The pto wont work
check for power at the clutch
Apr 21, 2012 | Ariens 34 In. Zoom Series Riding Mower
While trying to remove blades on Ariens Zoom 34, the spindle moves
you're gonna need to use an impact wrench on those spindle shaft nuts because they tighten themselves over time and they wont come loose with a ratchet and socket.
Dec 07, 2010 | Ariens 34 In. Zoom Series Riding Mower
Snowblower wheels wont engage when they are on the ground they move slowly when I lift it
1) Traction drive belt slipping or worn
a) idler pulley not fully engaging
b) cable/lever adjustment
c) spring missing or broken
2) Friction drive disc slipping or worn
a) rust on hexagon shaft not allowing friction disc to move
b) missing or broken engagement spring
3) clevis pins missing or broken on wheels
4) roll pin on drive shaft missing or broken
inside the cover for the gearing mechanisms, chain drives, gears ect.
Dec 06, 2009 | Ariens Garden
Friction wheel
thanks for trying i found the solution i went to ariens.com website and found a free service manual that showed me how.it was very helpful
Apr 01, 2009 | Ariens Garden
Will not engage foward or back .
Remove the cover on the very bottom under the engine, you will see a wheel with rubber ( the friction wheel ) on it, when you squeeze the handle for the drive you should not be able to turn that wheel by hand. First check to see if there is enough rubber extending from the metal disk it is attached to, if there is then it might be just adjusting the drive cable till the drive disc grabs the friction wheel sufficiently. If there isn't enough rubber or the rubber is chewed up you may need to replace the rubber part ( if the disc has screws in it to be able to seperate) or replace the whole wheel ( if the disc doesn't come apart ).
Jan 12, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens Snowblower won't engage into drive
I had the same problem with my 5HP Dual stage (C950-520240) Canadian model and found that the arm connected to the traction cable (part #85449 "Shaft Traction Clutch") which forces the friction disk up to the rubber friction wheel had a cracked weld and had bent, preventing positive contact with the rubber friction wheel. The drive wheels would turn if you lifted the back of the machine off the ground, but would not work if under load. First I replaced the belt and rubber friction wheel, but no go. I had to basically disassemble the whole drive assembly to find the problem, very frustrating because you could not see the crack in the arm from head on. I had the cracked and bent arm straightened and welded, all is OK now. enb54.jpg
Dec 05, 2008 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
630 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
