Question about Samsung Televison & Video
Since the disc has invalid information no more title list can be recorded - this is the error message when I try to record with my Samsung DVD-R130. Can you help me with this?
  • hoberglisa33 May 24, 2011
    Probably. I tried it again today and it worked, then didn't work, then worked again. I am sure it is "circling the drain" so to speak but thank you for your help.
  • 643 Answers
If the disc has been finalized you can not add anything else to it. Hope This Helps.
Posted on May 23, 2011
  • hoberglisa33 May 23, 2011
    Thanks but this was a blank disc. I was advised by a guy at the store to clean the player with a swab with a little alcohol on it - this worked for a little bit but now the machine will not read any discs, even ones that it previously read.
  • Mando Mojica
    Mando Mojica May 24, 2011
    That usually indicates the lazer is bad. Lazers usually run more than the unit itself. Hate to be the barrer of bad news.
Disk won't eject Error message: System error is detected System error is detected BE file:\Dvdv_util.c, line:264 Sensecode( 3: 2: 0), Detail:0x0
Hello
When operating, errors happen. Turn off the device.
(To turn off, press and hold the power button on the front
of the device for 10 seconds.)
After turning off, press the Open button and remove the
disc from the device
If needed reset the device to its factory settings after the disc is ejected. To reset it to factory settings:
Press the [UP] and [DOWN] buttons on
your DVD recorder simultaneously
when the power is on. All settings
including the password will revert to
the factory settings. Do not use this
unless absolutely necessary.
(Note that this function is possible only
when no disc is inserted.)
ok.
Jun 04, 2011 | Samsung DVD-R130 DVD Recorder
Samsung DVD-R130 will not load dvds, but will play CDs
Hey,
have you tried a lens cleaner? the lens may have gone bad and would need to be replaced. Do you have warranty on the player?
Sep 02, 2008 | Samsung DVD-R130 DVD Recorder
Hola como esta quisiera saber como hago para programar mi DVD SAMSUNG R130 ya que me aparece con la palabra SAFE y no me deja hacer ninguna fucion le agradesco de antemano su colaboracion Att: Jorge...
Gracias Jorge Sanabria por darme la oportunidad de responder tu pregunta.
Chequiando el internet me doy cuenta de que el Samsung DVD-R130 DVD Recorder no es un producto que lo recomiendan por clientes .
Esta es la informacion que encontre. http://reviews.cnet.com/dvd-recorders/samsung-dvd-r130/1707-9141_7-31738526.html?tag=mncol;lst#manDesc 3 de 10 compradores no recomiendan este producto. Mi opinion personal es de que si lo puedes regresar eso fuera lo ideal pero si no se puede asmelo saver y buscamos una solucion para este problema.
Si esto soluciona tu problema x favor as grado mi respuesta. gracias
============================ Thank you Jorge Sanabia because you give me the oportunity to answer your question.
Checking the internet I notice that Samsung DVD-R130 DVD Recorder is a product that is not recomended by the customers.
This is the information I found. http://reviews.cnet.com/dvd-recorders/samsung-dvd-r130/1707-9141_7-31738526.html?tag=mncol;lst#manDesc
3/10 customers don't recomend this product.
In my personal opinon is that if you can return it, that will be the ideal but if you can't please let me know to find a solution to this problem.
If this solution solve the problem pleas grade my answer.
Tahnk you
Aug 15, 2010 | Samsung DVD-R130 DVD Recorder
Dvd will not record
Hi and welcome to FixYa,
Initially, try to clean the lens using a CD disc cleaner. Additionally, verify that your blanks are either DVD-R or DVD-RW.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 16, 2009 | Samsung DVD-R130 DVD Recorder
I cannot finalize it keeps on saying no title list.
Are you absolutely sure there are recordings on that disc?The message means the recorder can´t find any. If you have a chance and it´s a VR-disc, try playing it on another player that is known to be able to play unfinalized VRs. If it was recorded in video mode there´s nothing you can do. If the material is of great importance turn to data retrieval professionals.
Dec 12, 2008 | Samsung DVDR120 DVD Recorder
Copying video to dvd
1st, does it come with a driver...if it doesn't, just make sure it is installed properly in your PC, then you just need to install a dvd writing software in your PC e.g. NERO Pro (v7 or later)...then, all will fit in...
Jul 23, 2008 | Samsung DVD-R130 DVD Recorder
Will not playback get error message Please Check Disc
i have a r136 , have you got the dvd discs u need ? i had the wrong format .
eg, dvd+rw needed dvd-rw
if not and there re-recordables they dont work after a few recordings and u need a new disc.
Dec 05, 2007 | Samsung DVD-R130 DVD Recorder
Problem dubbing from VHS to DVD
Try different brands of disk, most dvd-r recorder are disk sensitive, buy only one disk per brand, find the brand compatible to your recorder by just inserting the disk and wait for confirmation that it is ready for recording session. I have tried around five brands, sony and maxell as well as verbatim are good dvd-r disk.
Aug 23, 2007 | Sony RDR-VX555
Problem with samsung dvd player.....
what is the model number of your dvd player? i suggest try to use DVD-R types. and try resetting the unit if this will help.
May 29, 2006 | Samsung DVD-R130 DVD Recorder
Televison & Video Logo
205 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
