Question about Maytag Atlantis MAV6260AWW Top Load Washer
Scarf stuck around agitator.
Scarf is wraped around agitator , would like to remove agitator to remove scarf,
Thanks Sam
  • 640 Answers
Remove cap and ,,remove 1/2 inch agitator screw and pull straight up
Posted on Dec 28, 2008
SOURCE:
How do I remove scarf that is caught in washing machine agitator
You can manually reverse the motor while tugging at the scarf as it has wound up on one direction. Gradually pull while the motor is moved and it must come out freely.
Feb 12, 2013 | Washing Machines
Pants tie stuck around agitator on older model top loader. How do I remove the agitator?
If it is newer you yank the agitator off there by grabbing the neck
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 08, 2011 | GE Washing Machines
Material chord lodged around agitator of kleenmaid KAW393 washer
sorry to saybut you would probley need to stripp down most of the unit...to remove chord.
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
Necklace stuck in washer
Hold the bottom part of the Agitator,(The part that you are talking about),Undo the very top part in an anti-clockwise direction and it will come right off.Use a wrench to remove the nut on the top of the agitator and then lift it right out,you may need to move it from right to left.You will now be able to remove the necklace.Replace the Agitator the reverse of removal.
DW
Oct 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
A t-shirt is stuck under agitator/spinner thing. How do I lift off the spin assembly?
yes, remove the softener dispenser at the top of the agitator and there is a bolt there that is holding the agitator assembly. if you remove that bolt, the whole piece can be pull out and you can remove the clothe that was stuck in there.
tnx 4 using fixya,
drcool
Sep 06, 2008 | Kenmore 24032\24036 Top Load Washer
It eats my clothes
I would remove the agitator, checking to see whether the bolt that holds it to the drive shaft is securely tightened. If it is tight I would then check the agitator for a serial number, usually molded directly into the plastic agitator on the inside bottom. Use the internet to determine if the part is the correct agitator for your specific model of machine. I have seen the wrong agitator installed on machines before and it can do a number on clothes, especially sweaters.
Dec 14, 2007 | Frigidaire FWS833A Top Load Washer
Maytag Atlantis MAV6260AWW Top Load Washer Logo
368 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
