Question about American Audio Audio Players & Recorders
How to repair American Audio DL15 Speakers - American Audio Audio Players & Recorders
How to replace the walking belt on Weslo cadence dl15 Treadmill
Installing An Icon Fitness Treadmill Belt- No Exposed Roller Bolts
You can save yourself a great deal of time by following these instructions as opposed to those of the manufacturer. Please contact us if you need any further help. UNPLUG THE TREADMILL BEFORE DOING ANY REPAIR!
Step #1- Before unfolding the treadmill, disconnect the lift shock from the ball joint. Most have a small retainer clip that can be pulled with a small flathead screwdriver and then the shock can be removed from the ball stud.
Step #2- Unfold the treadmill and then remove the three wiring connectors for the incline motor and then one of the incline motor mounting bolts.
Step #3- There are two shoulder bolts that hold the entire motor tray in place. These are at the back of the motor area and must be removed to gain access to the front roller bolts. Remove the two shoulder bolts and then you can pull the motor tray slightly forward or backward to gain access to the roller bolts.
Step #4- Follow the replacement instructions included with the walking belt.
Step #5- Reverse the process of step one, two, and three to reassemble the treadmill.
http://www.treadmilldoctor.com/installation?utm_source=fixya&utm_medium=cpc&utm_campaign=mendi
Jun 26, 2012 | Weslo Cadence Dl15 Treadmill Walking Belt...
I bought American DJ discolights with T20f control. I do have American Audio mixer and cd player CDI 300. 2 powered Mackie 450 speakers. How can I connect the stuff?
I can only give you some ground rules to follow: Connect ALL of the audio equipment to a single receptacle or power conditioner. This may mean running an extension cord back from where the speakers plug in to the mixer. Use BALANCED lines, either XLR or TRS to connect the speakers to the mixer. Power the lights separately. To give anymore suggestions would require a diagram of how your venue is laid out and the location of power, etc.
May 10, 2011 | American DJ T20f Chase Control Pack W/foot...
My american pro amp is 600 watts, and when i have my two tens hooke up to it, on cuts in and out but stays on if i have i very loud, then i tried to hook up a 12 in sub and it didnt even work???i need an...
How are you connecting your speakers, stereo or bridged. What is the impedance of your speakers? What is the rated impedance of your amplifier? These are all questions you should have the answers to before you hook anything up to your amplifier.
Jan 10, 2010 | American Pro VS1402 Car Audio Amplifier
Inside speakers play subs wont
You need to buy a high to low adapter.
good luck
caypianan@yahoo.com
Nov 02, 2008 | American Audio Car Audio & Video
Installation
If you've got a standard 4 speaker system (2 front, 2 rear), your best option is to connect both left speakers to the left channel amp output and both right speakers to the right channel amp output. The only thing you lose is the ability to fade the speakers front to back.
Mar 04, 2008 | Legacy - American II: 2 Channel 1200W...
How to fix my amer.pro1000watt amp which has a burnt fuse an doesnt put out music
You blew the output transistors. They all need to be replaced. Check this for more info: http://www.techlore.com/article/14696/
Aug 14, 2006 | American Pro VS-2043 Car Audio Amplifier
41 people viewed this question
Top American Audio Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you an American Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
