Question about Gateway GT5082 PC Desktop
I have a gateway gt5082 and I would like to know what size of fan i would be able to add on to it. The space on the back of it measures from the screw openings as approximately 100mm, but would a 80mm fan fit?
  • dragon_epic May 24, 2011
    thx, i might buy the fan today. final questions what brand of fan do you recommend and are u sure a 120mm fan will fit?
  • 2,632 Answers
Welcome to Fixya. The fan size should be 120mm
Thanks
Posted on May 23, 2011
    thanks for the answer, final question, will a 120mm fan fit, and what brand will keep my computer coolest?
  • Rofel Lantican
    Rofel Lantican May 24, 2011
    Actually you can use either 80mm or 120mm fan. However 120mm are cooler that 80mm. For the brand all brands are good but just look if they have Cooler Master with 90CFM or any brand with 90CFM. You also have an option ot choose a Fan with LED. Thanks
Computer case fan for Gateway Performance, mid-tower case
Case fan size is typically measured in mm. Common sizes include 40, 60, 80, 92, 120 and 140 mm. OEM cases can have proprietary fan sizes as well.
Jun 12, 2012 | Gateway Computers & Internet
Gt5082 what is the best sticks for gateway gt5082
Memory Upgrade for Gateway GT5082 Computer, the Gateway GT5082
Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory
Type, and comes installed with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your
Gateway GT5082 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) standard Memory installed.
For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Gateway GT5082 Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope it helps
Apr 14, 2012 | A-Data Technology 1GB kit (512MBX2)...
Can i install 2 X 2gb ddr sdram on my Gateway GT5082
From what I gather you can use DDR PC3200, DDR (non-ECC) that equate up to 4gb of ram. So, as long as the RAM you are putting in is PC-3200 and no more than 2gb per stick, you should be good to go.
Apr 14, 2011 | Gateway GT5082 PC Desktop
I have a Gateway GT5082 computer, the Onboard Video no longer works and I have a PCI Express video card to put into this machine, the problem is, I can't get any video on the screen to go into the bios and...
try to clear our cmos, you can do that whit jumpers, or if you don't know .. pul out power cord from computer, remove silver battery for few seconds and put it back in.. then try..
Feb 25, 2011 | Gateway GT5082 PC Desktop
Gateway gt5082: usb not working, on the motherboard and front. i have installed a new hd and installed the new recover gateway cd that came w/the computer. still nothing.
If you reinstalled operating system then it means it's a hardware issue. You'll have to check the internal connections from motherboard to front panel. I'd also poke around the bios setup page to see if it was accidentally turned off. It's not likely the case, but it's always best to check.
Hope this tidbit of info gets you going. Let me know if you get stuck or have a specific follow up question.
Feb 08, 2011 | Gateway GT5082 PC Desktop
I have an old gateway 7023ge computer and i wanted to find out the size of my cooling fans so i can replace them. i have 2 fans one front and one rear. they are both the same size.
Computer case fans for older computers were usually standard sizes of 80 millimeter or 92mm, maybe120mm. 25.4mm = 1 inch, so an 80mm fan is about 3 inches. Measure the diameter of the fan from the tip of one fan blade to the tip of the opposite fan blade. A 92mm fan is about 3 1/2 inches in diameter and a 120mm fan is about 4 3/4"
Again, these sizes are _nominal_, so whatever your measurement is closest to is what you need. You should be able to measure the rear fan from the outside back of the computer without taking anything apart.
Jan 29, 2011 | Gateway (8008625) Cooling Fan, Heatsink...
I don't know how it got there, but on the home or start page, there is a white bar(like a tool bar) across the top off the screen. It has some files or folders including recicle bin, 60 day trial - office...
A real pain these are as there is precious little space to read the documents, let alone the adverts.
Right hand mouse click on the bar and uninstall it.
Jan 05, 2011 | Gateway GT5082 PC Desktop
Gateway GT5082 will not load. It powers up, power on light is lit, harddrive and dvd drive flash at the same time. CPU fan runs continous nothing loads.
Try starting in SAFE mode first by pressing F8 repeatedly as you poweq up and see if it wil start in safe mode.
If so remove any recently installed hardware or programs and then re-start
Let me know how you get on
Aug 20, 2010 | Gateway GT5082 PC Desktop
Fan wont stop running it didnt used to run all the time?
Your system could have built up some dust.
You should take it outside, open the case, and spray some compressed air into the system.
I usually use two cans at the same time, works better than one at a time.
Let me know if that solves the issue.
May 25, 2010 | Gateway GT5082 PC Desktop
Nothing past Gateway BIOS Splash Screen
If everythings in, take off the case. Locate the semos battery. Remove it for 2 seconds, then put it back in. Reboot.
Apr 10, 2009 | Gateway GT5082 PC Desktop
Gateway GT5082 PC Desktop Logo
52 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
