Question about Nikon D5000 Digital Camera with 18-105mm lens
Can we use a Cobra Auto 150S Compact auto/manual flash and slave unit on a Nikon 5000 SLR
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
As a slave, yes, though you won't get any of the features of a Nikon CLS-compatible flash unit. You would be shooting in manual flash mode. Due to its higher trigger voltage, I would NOT put the unit onto the camera itself.
Posted on May 23, 2011
Is it possible to use the Cobra Auto Thiristor Auto 250, with my Nikon D7000
NO!!!
Using this flash with your Nikon will likely damage the camera.
If you really want to use this flash, you need to isolate it from the camera using something like this: Wein Safe Sync Hot Shoe to Hot Shoe High Voltage Sync Regulator SSHSHS
Jan 20, 2015 | Nikon Cameras
How can i turn the flash off of my nikon n65 camera?
In the PSAM modes the flash won't pop up on its own. In the AUTO and vari-program modes, you can set the flash mode by turning the command dial while pressing the flash sync mode button (marked with a lightning bolt symbol). Select Flash Cancel (lightning bolt in a circle with a slash through it).
If you need a manual, you can download one at
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Dec 22, 2010 | Nikon N65 35mm SLR Camera
What is setting for continues flash, regardless of lighting.
You should be able to take the camera off of the FULL AUTO mode (the green square) and put it on "P" mode (program mode), which is full auto except for flash. Then if you keep the flash open it should always use it.
Nov 21, 2010 | Nikon N55 35mm SLR Camera
My Nikon N55 will not auto focus.
Depending on the type of interchangeable lens you have mounted on the camera, there may be a switch on the lens barrel for choosing between auto-focus or manual focus. The N55 also will not auto-focus with the newer Nikon AFS lenses such as those used with the Nikon D40 digital slr. Finally, there was a service bulletin on the N55 back in 2005. Nikon discovered a problem with the auto-focus and fixed it for free, but there may have been a time limit. Here is a link to more info about that:
http://www.nikonusa.com/Service-And-Support/Service-Advisories/N55-Service-Advisory.page
Hope this helps : -)
Nov 30, 2009 | Nikon N55 35mm SLR Camera
I have a Nikon N65 and I just replaced the batteries. When I turn the camera on, I can't change the shutter speed/aperture or anything (on any setting..manual, auto, etc) and Err flashes.
Camera has a fatal error and should be sent in for service, or replaced. A used on may actually cost less than repairing your old one. Check out KEH.com
Nov 09, 2009 | Nikon N65 35mm SLR Camera
What is the best setting to use in a restaurant or nightclub?
That would depend on several factors. I'll assume that, since you asked this question, you don't want to read a lot of technical stuff about apertures and shutter speeds and so on.
If you want to use the flash, use either the Auto or Night Portrait modes.
If you don't want to use the flash, use either the Auto or Portrait modes and turn off the flash.
Oct 03, 2009 | Nikon F75 35mm SLR Camera
Can you use nikon sb25 flash with d40 dslr?
You can but with limitations;
Save me explaining,please read this http://forums.steves-digicams.com/nikon-dslr/137618-sb-25-d40-non-ttl-auto-mode.html
Apr 14, 2009 | Nikon D40 Digital Camera with 18-135mm...
Nikon N55 Won't take picture in Auto Focus Mode?
There was a recall on the N55 due to auto focus problems. You can do a google search or nikon.com email the support team and they will send you the paper. This is what I did, I wasn't charged since I had the correct papers. I, however, used one roll of film and my focus went out again! Mine doesn't even work on manual... If you want to try that maybe you will hae better luck than me. GOOD LUCK!
Apr 28, 2008 | Nikon N55 35mm SLR Camera
External flash problems
Sounds like the external flash is being triggered by the pre-flash.
On the D40 set the flash mode to manual. On the F65 set the flash mode to Standard TTL.
Nov 28, 2007 | Nikon F65 35mm SLR Camera
Nikon D5000 Digital Camera with 18-105mm lens Logo
340 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
