Question about GE Microwave Ovens
GE jvm1850dm has power to it but nothing works at all.
    Problem Solver:
  • 12 Answers
The switches by the door could be defective.
Posted on May 23, 2011
We installed a GE Spacemaker Microwave. I put some potatoes in and the microwave was working, suddenly it went off. No light nothing, it just went completely dead. Came back ON after 15 mins,started...
The main fuse may be intermittent, causing complete power failure, the other possibility is a defective door switch not operating properly, or loose plug in the power feed, I suggest a technician to take closer look at the system because this could prove tricky to find the culprit.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
We had a power surge and now the microwave does not work, model number MH1160XSB-0 whirlpool, what could be the problem? We put a fuse in and it kept blowing.
Model MX6110XB. Nothing worked. LCD panel was dead. Unplugged and replugged; and everything works.
This fix described for the GE Spacemaker. They say problem result of a power surge. Apparently applies to different manufacturers; or does GE make Whirlpools?
Dec 09, 2010 | Whirlpool Microwave Ovens
GE JNM1851DM. only 6 months old and it is dead. Worked fine and then all of a sudden stopped working. The wall outlet has power so I know it is not a breaker in the house. Nothing works on the micro. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 09, 2010 | GE Microwave Ovens
GE 1800 XL not heating, no power, except fan works and clock also
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Mar 29, 2010 | GE XL1800 1100 Watts Microwave Oven
No power, i have power to the outlet but nothing on the unit works.Is there a fuse?
remove the cover ... look on the floor of the unit near where the cord enters the cabinet.
Oct 12, 2009 | GE Advantium 120 Convection/Microwave Oven
Ge profile spacemaker 2.0...It has power going to it...But NOTHING...''lights'' up..all is dark and not even lights or fan works...Is there an internal fuse or breaker?..or any thing?
HI,
this will require the skilled hands of a qualified GE tech. the damaged part here is the Magnetron assembly. this is a very sensitive part that creates radiation and the heating process as well. you will need to replace this device asap if possible.
thank u
rate me!!
Jul 26, 2009 | GE Microwave Ovens
I have a GE JE 1860. Someone ran the microwave for 15 minutes with nothing in it. Now it doesn't work at all , no power, no lights, nothing. Is there a fuse that may have gotten burned out? Is this...
There is a fuse and cavity thermal fuses as well as one on the magnatron that is supposed to reset itself.. The fuse is behind the control panel and the cavity fuses will require removal of the cabinet. Did you check for power at the plug?
Eric
Jun 20, 2009 | GE JE1860 Microwave Oven
I got one of your microwaves on May 6th, 08. On Sunday June 1st it just stopped working. It will do nothing, not even light up, when you push the buttons they do nothing. The power is ok, I checked it by...
If it's a GE microwave, GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
If it's a different brand, please reply back so we can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 06, 2008 | GE Microwave Ovens
2 1/4 year old GE Spacemaker XL 1850 Microwave doesn't heat
Check this website:
http://www.partselect.com/microwave+no-heat+repair.htm
It sounds like it is either the power diode, the high voltage capacitor or the magnetron. If it is the magnetron, it may not be worth fixing as these can cost well over $100.
Do you hear a buzzing sound?
Dec 13, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
