Question about Lexmark X4650 InkJet Printer
Printer will not print the ink packages are new but the indicator on print que shows (?) on both black and color indicators. the que shows printer 1 to 3 % progress then stops. thank you for your help
  • Official Brand Answer
  • 3,344 Answers
It could be that the print spooler service on your computer has stopped. - Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
- type in "NET START SPOOLER" (this will restart the print spooler service)
Try to print again.
Posted on Jun 01, 2011
How to check the ink level onC4480 printer
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the print cartridges appear.
Or
Print a self-test report
1. Load A4 unused plain white paper into the input tray.
2. Press and hold the Cancel button and then press the Start Copy Color button.
The product prints a self-test report, which might indicate the source of the printing problem.
3. Make sure the test patterns show a complete grid and the thick color lines are complete.
• If more than a few lines in a pattern are broken, this might indicate a problem with the nozzles. You might need to clean the print cartridges.
• If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black or photo print cartridge in the right slot.
• If any of the color lines are missing, faded, streaked, or show lines, this might indicate a problem with the tri-color print cartridge in the left slot.
Nov 30, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
I've just replaced the black ink cartridge for my Epson Stylus TX100, ink level is ok as the indicator shows. But i get blank prints for black, other colors are fine. What's wrong with the black ink...
There is nothing wrong with the black ink. Just run the head cleaning for better printing.
1. Go to printer and faxes
2. Right click your printer ( Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet)
3. Click printing preferences
4. Click Maintenance Tab
5. Click Head Cleaning
6. Run head cleaning for 5 times then try printing.
Nov 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
Kodak 5300 All In One Printer. Black ink quit printing.
Hi there.
It could be the chip in the cartridge... faulty for printing?
Settings in the printing process?
Iceman.
Nov 10, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
Blinking teardrop light blinking
Blinking drop light on HP6122 signifies an ink cartridge is out of ink. There are two cartridges -- color (larger of two) and black (smaller of two). Blinking drop light only indicates either, but not which. HP6122 service software and print driver are available from HP website http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=83027&lc=en&cc=us&dlc=en&lang=en&cc=us. HP6122 service software has a printer maintenance utility which includes ink cartridge monitor. Use the maitenance service utility to determine which (or both) cartridge is out of ink. With cartridge replacement, printer should automatically print test page, then reset and be ready for printing from your computer. To clear printed documents from print que, open the HP6122 print que via control panel > printers > double-click on HP6122 driver to show que > select document tab > select cancel.
Mar 26, 2009 | HP DeskJet 6122 InkJet Printer
Replaced Original Black Ink Cartridge but still bad low ink prints and low ink indicator lit.
Sounds like the print head is dirty take some rubbing alcohol and qtip and clean the print head.
Dec 03, 2007 | Canon PIXMA MP160 All-In-One InkJet...
No color printing with lexmark x4270
How may times did you use the printer to print befor this happened? If you used it a lot then you may need to buy more ink. My printer showed full ink and it turned out that they were empty.
Feb 26, 2007 | Lexmark X4270 All-In-One InkJet Printer
Use of black ink
My husband answered this for me- it takes different colors to make black, therefore it uses some of the color ink
Jan 16, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Lexmark X4650 InkJet Printer Logo
143 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
