Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Suction is gone have cleaned out all areas that can be cleaned out????is it garbage
  • 300 Answers
Is it "garbage"? Not necessarily.
If you're really happy with the vacuum so far, and the motor sounds nice and smooth, it would be worth your while taking it to a service center for a tune-up.
That all depends on the price of a suitable replacement, of course.
Posted on May 23, 2011
My irobot will run but doesn't pick up anything
Check your suction. If there is no or little suction at the hose end then check for a plugged hose and all the suction areas. Make sure your filters are clean as well. Should be one and possibly two.
Dec 02, 2016 | iRobot Vacuums
It has lost suction
Have you got suction just before the motor? How about air coming out the exhaust?
Mar 14, 2015 | Vacuums
The suction of the vacuum has gone down from the suction that was when it was new(about two years old). All areas have be cleaned and there are no obstructions or blockages in the unit, it just seems less...
you may have a little wear in the hose,although sometimes it is wise top take it in for an overhaul.If you take it to a good tech they will take it apart,clean the motor and adjust the rubber seals.Simply,a vacuum means no air,the better sealed the vacumm the better suction...hope this helps
Mar 01, 2015 | Electrolux Proteam Brushroll Assembly 1500...
How to clean suction area
If you are referring to the front nozzle area, Hoover has made a tool called a nozzle cleanout tool # 39514003
Sep 13, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Why do I have no suction from our EP754C vacuum? Turns on but no suction?
Hi, please check the hose attachment you are using, sometimes tissue paper or fluff can cause the hose to block. You will have to remove any obstruction. Another test will be to check the area where the hose attaches to the vacuum, switch on without hose and use a piece of paper to see if there is suction in this area, if no suction then the problem could be that the inner filter housing the motor needs cleaning. Best of luck.
Jul 23, 2014 | Euro-Pro Shark EP754C Belt 2pk
How to regain my suction on the Delonghi vacuum cleaner?
Check the area directly behind the brush for obstructions before the hose connection
Nov 15, 2017 | DeLonghi Vacuums
My Bissell Pro Heat Select 2X does not pull up the dirt from the carpet into the water. The water just slowly disappears. The first time I used it the water got really dirty. The very next time I used it...
Inside the plastic suction lid is a little red plastic filter that has to be cleaned out every time you use it because it sounds like your vaccum is not picking up all the hair and debri before you clean the carpet causing the water to be injected into the carpet and disappearing and not filling the tank with dirty water. Steve
Jun 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Leaving bigger dirtier wet spots after cleaning
Sounds like the vacuum motor is defective or you have a clog in the vaccum line. Basically everything is running except the vacuum "Suction" cycle. Do you hear the "Suction" phase (light indicator) during operation when it loudens like a whine? That would be the vacuum phase. Is the dirty water reservoir clean, do you rinse it thoroughly when you empty it? Have you removed the hose assy and rinsed it out? I think it is still part of the auto cycle even if you don't use the manual tool.
Feb 24, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
My dyson vacuum motor is sounding very high pitched... The tubes are all clear and there is suction with the tubes not not real good suction on the beater brush area....
Your dirt path is clogged, probably not far from the brush area. This is the reason you noticed the hi-pitch sound coming from the motor.
You may have to remove the hose to clear it.
Jan 19, 2010 | Vacuums
Bissell 9400 ProHeat Upright Upholstery Hose
Set Ready Tools Dial to the Hose
Setting. This will allow spray and
suction from the hose.
Set Custom Clean Dial for Heavy Traffic, Normal
Clean, Light Clean
, or Rinse, as desired
Attach the cleaning tool to the end of the hose.
Plug in and turn on the Power Switch and Heater
(if desired).
Clean by pressing the trigger to spray solution
onto the area to be cleaned. Slowly move the tool
back and forth over the soiled surface. Release
the trigger to suction soiled water. Continue to
clean in the area, working in small sections, until
no more dirt can be removed. Rinse (optional)
and suction as needed.
May 26, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
43 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
