Question about Toshiba Satellite X205-SLI1 Notebook
X205-SLI1 17" Notebook PC PC Notebook 3 beep
  • Toshiba Master
  • 4,338 Answers
Memory problem:
Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on May 23, 2011
Toshiba Satellite® X205-SLi6 PC Notebook
have you solve your problem, I have the same problem!!!! i Would like to know if you have find a way to fix it?
Jan 21, 2011 | Toshiba Satellite® X205-SLi6 PC Notebook
3 bits
I think when the tree beeps is on ..the blame is on the video card ..so unless you changed the video card as well you just made a wrong move ..The part that should be changed is either teh video card or the ram memory ..cause they are the only one that causes beeping when something is wrong ..So check the card it may be just not plugged well ..and the ram memory as well ..Unplug them ..and use them one by one and boot up and see how it behaves..Even if it is not enough ram in it for to run the operation system ..it should at least show the devices and the logo screen ..
Apr 09, 2010 | Toshiba Satellite X205-SLI1 Notebook
Problem for Toshiba Satellite® X205-S9349 PC Notebook: i get power to the laptop, harddrive flashes a few times, then nothing. No beep sequence. took out ram strips, cleaned them, and reset them...
I have just recently experienced this same issue. My fix was easy. I removed the video card. removed the heat sync. Using a heat gun about 2" away from the backside of the video chip (bga) for about 30 seconds. Then immediately with a doubled up piece of cardboard, press down on the chip for 30 seconds. Let cool, then reassemble. I did this a month ago and still going.
Feb 01, 2010 | Toshiba Satellite X205-S9349 Notebook
Toshiba x205 Sli1 suddenly died. Got 3 beeps.
3 beeps usually means that either the chipset or the processor is dead. Nothing you can do, take it to a repair shop.
Nov 06, 2009 | Toshiba Satellite X205-SLI1 Notebook
I gt power to the pc but it does not boot and the
well on the satellite x205 it could be a couple things. there isnt any beep code? if there is no beep code then it would need atleast a main system board. i worked on 2 last week but they had beep codes (3beeps) which were video cards. in your case pull each stick of ram, then if thats not the case order a main system board.
Nov 05, 2009 | Toshiba Satellite X205-S9349 Notebook
Toshiba wont turn on, has beeping after i press power
i had a similar problem with my satellite notebook. the problem was that it was overheating. what i did was pull the processor and heat sink out, it was covered in dust and not allowing air to go through the heatsink. i just cleaned it up and it stopped overheating.
Apr 28, 2009 | Toshiba Satellite X205-SLI1 Notebook
Getting 3 beeps when starting the comp. with no screen.
some prblm is dere wid d ddr1 or ddr2 compatibility...jst check d compatibility of d ram n insert accordingly..having fit at both ends...that's it...it's not a big issue...
Apr 11, 2009 | Toshiba Satellite X205-SLI1 Notebook
Toshiba Satellite® X205-S9349 bios beeping
the beep codes you are getting are for video but if the system boots and you have video im sure it is something with the ram on the video card. unfortunatly this will require a service from toshiba. these cards are intergrated and will require the motherboard to be replaced.
Sep 07, 2008 | Toshiba Satellite X205-S9349 Notebook
Toshiba Satellite X205-SLI1 Notebook Logo
202 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
