Question about LG LRTN19320 Top Freezer Refrigerator
Water leaks out of my freezer coming from the back
  • LG Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 24, 2011
Water is leaking out onto the floor from freezer
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Ads by Google' + // // '' + // '' + // makeBoldAdWords(google_ads[0].line1) + '' + // // '' + // makeBoldAdWords(google_ads[0].line2) + ' ' + // makeBoldAdWords(google_ads[0].line3) + // '
' + // google_ads[0].visible_url + ' ' + // '
' + // ''; // } // else if (google_ads.length > 1) if (google_ads.length > 0) { s += 'Ads by Google'; /* * For text ads, append each ad to the string. */ for(i = 0; i ' + makeBoldAdWords(google_ads[i].line1) + '' + '' + '' + google_ads[i].visible_url + ' ' + makeBoldAdWords(google_ads[i].line2) + ' ' + makeBoldAdWords(google_ads[i].line3) + '
' + ''; // '' + // makeBoldAdWords(google_ads[i].line2) + ' ' + // makeBoldAdWords(google_ads[i].line3) + // '
' + // google_ads[i].visible_url + ' ' + // '
' + // ''; } } } document.write(s); G_GGL_SKIP += Math.min(google_ads.length,G_MAX_ADS_AT); return; } var G_MAX_ADS_AT = 4; //var G_MAX_ADS_AT = 3; google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#) google_ad_channel = "4447185069+3033438690"; google_ad_output = 'js'; google_max_num_ads = '4'; google_ad_type = 'text'; google_feedback = 'on'; if(typeof G_GGL_SKIP == 'undefined') { G_GGL_SKIP = 0; } google_skip = G_GGL_SKIP; // -->
Aug 22, 2011 | Admiral 26 cu. ft. Side-By-Side...
GE refrigerator mdl tbx18jabkrww is leaking from underneath the appliance. The appliance has an optional ice maker installed. Do you know what the issue could be?
If your chest freezer is showing signs of age, it may begin leaking. There are a few methods for troubleshooting faulty chest freezers but knowing some of the obvious signs of why it might leak can be very useful if you need to fix it yourself. Leaking is not limited to older models so be aware that certain maintenance procedures can help prevent leaks in newer models.
Understanding Changeable Parts Prior to Troubleshooting There are not that many serviceable or changeable parts inside a chest freezer. A chest freezer works on a very simple basis. It contains evaporator coils, condenser coils, a compressor, a compressor overload, a relay and a thermostat. These are the basic moving parts of a chest freezer but some of them are not serviceable.
The condenser coils condense the water and the evaporator coils disperse excess water caused by the freezing process. The compressor is a heating component which compresses excess water and recycles it through the system.
Defrosting Remove the contents of your chest freezer and place them in an alternative area to keep them frozen. Unplug and defrost your chest freezer before you do any troubleshooting or maintenance. Wipe and clean the inside of the freezer so that when you plug it back in it, will free of any grime or loose bits of debris. A clean freezer will also help to promote visibility when it comes to fixing leaks.
Where is the Leak? Once you have defrosted your freezer, you need to establish which part of the freezer the leak is coming from. It could be coming from the inside of the freezer and this would indicate a thermostat issue. Alternatively, it could be coming from the freezing unit at the back of the freezer. Water always finds a way to escape so your leak could be restricted to one place but the actual cause could be elsewhere. Locate the drain tube which is normally found at the back of the freezer. You will probably have to unscrew or unclip the backing panel.
Check the Drain Hole If the drain hole on your chest freezer has become blocked for any reason, you will need to clear it thoroughly to continue getting the best performance from your chest freezer. The drain hole is a component within the lower works of the freezer through which excess water runs to be recycled.
Compressor Issues Your chest freezer contains a compressor which evaporates the excess water from the freezer. The freezer will defrost excess ice and the water flows down the drain tube to a pan where the heat of the compressor evaporates the water. If your compressor has failed, the leak will be caused by the water failing to evaporate. Have a repair contractor replace your compressor or, if this is not cost-effective, you may need to buy a new freezer.
Thermostat If your freezer is not freezing at all and is dispersing water in several places, you may well have a thermostat failure. Check that your freezer is cycling correctly prior to making changes or altering the thermostat. Only if the freezer is not cycling are you likely to need to change the thermostat. If you have checked all the parts of your freezer and you still cannot locate the leak, calling in a service technician might be the best answer. Take care in solving the problem....
Aug 20, 2011 | GE J Series 18.2 cu. ft. Top Freezer...
Inside water dispenser is leaking
Hoping this will help to solve the problem....
Aug 18, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Hi there, I have a MAYTAG MSD2758DR Refrigerator and every night water is leaking from front left and floor is getting wet. The amount of leaked water is nearly a cup of water.
Aug 18, 2011 | Maytag MSD2559XE Side by Side Refrigerator
Water leaking inside around the drain from the freezer, water collects in the bottom under the drawers
Defrosting
Where is the Leak?
Compressor Issues
Thermostat
Hope this will help in solving the problem...
Aug 04, 2011 | Amana ATB1504AR Top Freezer Refrigerator
Water freezes in bottom freezer and then leeks onto floor
Defrosting
Where is the Leak?
Compressor Issues
Thermostat
If your freezer is not freezing at all and is dispersing water in several places, you may well have a thermostat failure. Check that your freezer is cycling correctly prior to making changes or altering the thermostat. Only if the freezer is not cycling are you likely to need to change the thermostat. If you have checked all the parts of your freezer and you still cannot locate the leak, calling in a service technician might be the best answer if you can not handle it yourself..
Do take care in solving the problem....
Jun 28, 2011 | Amana Refrigerators
Freezer leak, Ice inside the freezer (AMADA ARB220ZC)
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 08, 2010 | Amana ARB220ZC Bottom Freezer Refrigerator
Frigidaire leaking water out the bottom
it comes from freezer. remove back cover of freezer and unclog hole where water collects
Feb 13, 2010 | Frigidaire GLRS234ZA Side by Side...
Hotpoint. Water is leaking from behind light bulb
The drain hose in the back of your freezer is frozen shut. The water you see is coming from the defrost cycle. Turn off the refrigerator. Remove the floor from your freezer and remove/thaw all of the ice. Locate the drain in the back of the freezer. It may be behind the back panel. Thaw the drain until water flows freely through it. Reassemble the freezer, and you are back in business.
Oct 22, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Water leaking from bottom
my GE side by side fridge leaks water from the bottom only when I connet the water filter inside the fridge. The leak stops when I remove the water filter. What could be causing this?
Jul 14, 2008 | Refrigerators
LG LRTN19320 Top Freezer Refrigerator Logo
67 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
