Question about Samsung Televison & Video
The remote for my samsung tv has stoped working. have changed the batterys no luck. the only thing that the remote dose opperate is the volume.plz help
  • 10,594 Answers
Please get another same remote and confirm the problem either in TV or Remote itself. HERE is a weblink to get new remote for Samsung TV.
Posted on Aug 15, 2008
How do I fix the remotes to change samsung tv volume?
Just for the hell of it, change the batteries in one of the remotes and see if it works.
May 21, 2014 | Televison & Video
My remoute control joust change the volume and anyother keys doesn't work.
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since
www.samsungparts.com lists 37 pages of TV remotes (at 10 models per page).
Jul 02, 2011 | Samsung TV Remote Control
My samsong tv ps-42p2sb stoped working
Since your tv is in warranty call 1-800-Samsung. They will set up a service call to repair your tv.
Jul 03, 2009 | Samsung PS42P2S 42 in. Plasma Television
Volume controls do not work on remote, batteries have been chang
is that from remote no volume try tv volume if ok
your remote volume buttons are wornout push
button harder ??ok no i can fix remotes
need help call 0403960527
Feb 16, 2009 | Samsung TV Remote Control
Hi, I have a samsung le32r74bdx lcd tv and the volume has just gone to 100 and i can't turn it down?
First, start by unplugging set to try to reset. Then make sure that all settings in audio menu are correct. Also look for stuck volume up button on set and on remote. Sometimes buttons get lodged under surrounding frame. Also try to push volume down button on tv and watch for display on tv to see any change. If when you release button volume increases by itself, remove batteries from remote to eliminate it as cause. If nothing you try works expect to replace main pcb. You can probably price it online with model number. Good luck, Russmann.
Jun 09, 2008 | Samsung Televison & Video
Cant find soyo tv code
Need to know which remote you have.
Mar 15, 2008 | Televison & Video
Code for Samsung remote control
With your Sky + remote.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 29, 2007 | Samsung TV Remote Control
Volume control
Hello
If it is just not functioning for volume but do perform other functions then do open in there would be screws or can just be lock's clean the board and pad with cotton dipped into acetone if you don’t have acetone just use the dry cotton if it still doesn’t work change the remote
Good Luck
Oct 25, 2007 | LG 42PC1DA 42 in. Plasma HDTV
Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Sep 28, 2007 | Samsung TV Remote Control
Volume on Remote powers TV on and off?
This unit has upgrades available for this set. I am not at my shop now, but, I think the problem you described is usually cured by this upgrade. The set is under warranty, contact: 1-800-Samsung for a local servicer. If you need additional help, respond to this post and I'll reply.
Aug 26, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
54 people viewed this question
Henry  Thomas
Henry Thomas
