Question about Sony Playstation 3 (PS3) Console
After hooking up cables, power etc to another TV (nonhdtv), no picture on tv
  • Sony Master
  • 4,806 Answers
All you have to do is reset the video settings on the PS3. Hold down the power button until you hear a single beep, then press it again.
That should have reset the video settings so you can play on the new TV.
Regards.
Posted on May 23, 2011
Have blank screen with sound. Flashlight test shows writing etc. Says cable not hooked up when it is. When HDMI cable is hooked up it shows up.
I hope I can help with this. It could be either the colored cables are not positioned correctly (they should all be on the same row) or it is on the incorrect TV Input. This can happen when we have other devices connected to the TV such as CAble box, gaming console (xbox, ps4,wii), dvd player, etc. The fact that you said the HDMI cable works fine and shows picture, it tells me it has to do with those colored cables.
Jul 28, 2016 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Hi-Def TV does not sinc with DISH VIP 922 receiver?
I am lost on ur question, do u mean the TV will not show anything from ur Dish? I always use HDMI cables, quick and easy hook up. now when u use HDMI cable u will need to go into your TV menu or look on the TV (Sanyo, Phillips,, etc) remote and locate the Input, Source, Antenna button. and go the the correct video stream that u have hooked up to on back of ur TV. U should see HDMI 1 HDMI 2 etc choose each one till u get a picture.
Jan 01, 2015 | Televison & Video
How to hook at&t uverse cable box
If set works with games etc via rear audio/video jacks do the same with cable----get a cable box with audio/video etc outputs on it and go from them to ones on the rear of set----no coax connection needed and a better picture.
May 19, 2012 | Toshiba 57h83 57-inch Hdtv-ready...
No sound no picture....power is on and all cables are hooked right
Do you have the tv set to the correct input? ie, HDMI 1, HDMI 2, Component 1, etc. Usually, flat panel TVs have multiple inputs. You have to set the tv to whatever input you have the cables plugged into.
Mar 03, 2011 | Televison & Video
My Samsung HC-p4363w have no pic or sound but the power red light is on
Try pushing the "source" button on remote or on the TV. Wait about 5 seconds, if no picture, push again. Do this at least 6 times or until you get a picture. With each push, the TV will look for cable input, dvd input, etc. until it finds your cable signal.
Also make sure your cable/antenna is hooked up and working.
If that doesn't work, hold down the "enter" button for 10 seconds to reset the tv to original factory settings. Then follow the on-screen menu setup instructions.
-please rate me. Thanks and good luck.
Nov 20, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
Killed by lightning, have power, no picture...
The warranty does not cover lightning, check if your insurance covers it.
A lightning strike on such panel ( HDMI ) is very difficult to repair and if not impossible.The HDMI connector is hooked to the ground of the TV set so everything could be damaged.
My advice is not to repair.
Aug 10, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
No sound or picture but menu comes up
Check video source like DVD Player has power, check connecting cords, cable connections etc.
when TV gives menu on screen that means TV is fine and problem could be hooked video signal items.
Apr 15, 2009 | Hitachi 51F59 51" HDTV Projection...
Samsung hlp4667 only get a picture with HD input.
is there anything else hooked up to your tv other than cable or satellite? if no other components (dvd, vhs, etc) then you will get a snowy screen because the other inputs are for other components that are hooked up. a picture is showing on the HD input because you have cables hooked into that input.
Mar 15, 2009 | Samsung Televison & Video
No picture from samsung blu-ray to samsung TV
Put the blu ray player into the tv to see if you get a picture,if you do put it back into the amp then assign the hdmi input you have used in the amps set up menu,if you did not get a picture when hooked up to the tv run a cable from the video [yellow] out put to the video in put on the tv and then set the out put of the blu ray player.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | Electronics - Others
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
