Question about Blaupunkt Modena CD53 CD Player
No sound from speakers on modena cd53. (nor tuner,cd & aux) and both TDA amps tested ok. (speakers buzz when touching inputs of TDA)
How do you hook up speakers on pioneer tuner f-9
You cannot hook up speakers to the F-9 directly because is has no built in amplifier. It has only a preamplifier out. You will have to hook up this F9 tuner to an Amplifier's Tuner/Aux input using a RCA cable. The Amplifier out should be connected to the speakers and when you select the appropriate input on the Amp you will hear your Tuner sound.
Mar 31, 2011 | Pioneer Audio Players & Recorders
Do not know how to connect my kappa 60.5cs to my pioneer cd player do they have to go through an external amp?what do i do with the power plugs on the oppisite side why are there 2 per speaker
You need to run RCA cables from the CD player to the CD or AUX input on your amp / receiver unit. If you have a standalone amp, you need some way to control the volume. Basically, if you have a volume control on the front of your amp, you're OK. If not, you should also have a preamplifier that the CD player feeds first.
From the amplifier, then, a single pair of speaker outputs feeds a single pair of inputs on your speakers. The reason for two jack sets on the speakers is for "bi-wiring" or "bi-amping", not necessary for basic stereo reproduction.
So -
CD red/white RCA out -> preamp/receiver red/white CD/AUX input. Amp speaker output (red + / black -) to one red/black input pair on the speakers. An input on the speaker is side by side...
Keep the red to red, black to black when connecting the speakers, or you will wind up with poor sound and weak bass.
Jan 18, 2011 | Infinity US-1 Main / Stereo Speaker
How can I get sound through my speakers when using and HDMI input on my television?
just take an audio output from the source be it sattelite, ps3 etc to a line input on your amp. be it Tape,Cd,Tuner,aux. JUST DON@T PLUG INTO THE PHONO!!!! (it's for turntables only)
Jan 07, 2011 | Panasonic SC-HT900 System
A installed the kenwood dpx303 and the radio plays fine, but when I try to play a cd or use the aux input it shows that its playing but no audio will play through the speakers.
are you using an amplifier? if so, it sounds like you are using the blue wire (antenna remote) instead of the blue/white wire (amp remote turn on) to turn your amp on. the antenna remote turns off when leaving tuner mode.
Dec 07, 2010 | Kenwood DPX303 CD receiver
Only two of my amplifier inputs are outputting sound correctly!
Odd one! Normaly you would loose a channel if the main amp was down, or the pre-amp was. But clearly the main is working. The only conclusion is that there must be more than one pre-amp and that's why the Tape section works. The only way to solve this one is to go inside and trace the imputs to where they join the PC board.
A helpful hint is that if you touch the audio section with a srewdriver, it will buzz! And since you have two channels which copy one another you can work out where the fault is. Because if it buzz's in the good channel, it should in the same place on the bad one.
WARNING don't stick your srewdriver on power parts, and don't short any part out with it.
Feb 09, 2010 | Teac A-H300 Amplifier
I need a wiring diagram to connect up my kenwood amp, cd player, tuner and graphic equaliser
cd player(tape out)-------equalizer in------equalizer out-----amp line in.
tuner out-----to another line in in amp.
Nov 27, 2009 | Audio Players & Recorders
Speaker left channel? must be broken as both speakers are still working on right input (channel, not sure if this is the terminology?)
Have you tried isolating the problem to see what exactly the problem is? First I suggest disconnecting the left speaker from the system and test the speaker by it's self. If you have any technical knowledge and an ohm meter, you can connect an ohm meter to the two wires comming from the speaker and see if you get 8 ohms or less. You SHOULD see something in the neighborhood of 8 ohms of resistance if the speaker is good. If you're not a techy and want a simpler "go/no-go" test on the speaker, then take the two wires going into the back of the speaker and BRIEFLY touch them to the two terminals of a 9 volt battery. If the speaker is good, you will hear a "pop" in the speaker as the battery connects. Again, ONLY BRIEFLY touch them. DO NOT connect them to the battery and allow them to stay on for more than about a half second or so, else you run the risk of burning up the voice coil in your woofers.
If the left speaker passes the test, then let's look at the receiver unit. I am not familiar with this particular make and model, but I dare say it should have multiple inputs. Just to be extra certain that the speaker wasn't somehow the problem, go ahead and connect the right speaker to the left channel and let's test the left channel of the receiver. Try using the various inputs on the receiver (i.e. am/fm, CD in, AUX in, Video in, what ever it may have).. Does the left channel yield ANY sound at all under any conditions?
If I'm not mistaken, the system has a separate power amp and receiver unit. Try putting a signal into the aux inputs of the power amp it's self using an RCA cable. You can connect the other end of the RCA cable to most any other CD player, or you can usually touch your finger to the center conductor on the RCA cable and listen for a buzz or click in the left speaker output. If it doesn't give any sound, then the problem is most likely in your amplifier. If it does give you sound, then we need to look at the receiver.
Something else I just noticed about this particular unit you have, is that it uses a ribbon cable to connect the receiver to the amplifier unit. I would suggest that if the amplifier checks good, then try replacing this ribbon cable with another one. You may have to have one specially made, or you may be able to order one. I hope that helps.
Oct 25, 2009 | Philips (MCD700) System
Alpine CDA-7873 (Same as CDA-7876 basically)
the blue line from the radio harness does not have power when the cd or aux are being used and the amp is not turning on-wire the remote line from the amp to the red line and your amp will stay on and you will get sound
Mar 27, 2008 | Alpine CDA-7876RB CD Player
Can't get into AUX source
Are you sure it is an AUX input? According to the Manufacturers Specs, the AUX, is an optional accessory. There is a Pre-Amp connection, which would be an output, hence causing the problem you are having. Best of Luck.
Sep 13, 2007 | Kenwood KDC-MP232 CD Player
Blaupunkt Modena CD53 CD Player Logo
22 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
