Question about Maytag MER6750 Electric Kitchen Range
What does this fault code F9-3 mean? The alarm came on with this code while I had two burners going and nothing in the oven.
  • 1,116 Answers
F9-3 - Max oven door lock time exceeded. Check oven door lock/door lock switches.
Posted on May 23, 2011
The F1 alarm is beeping.....what does this mean? Thank you!
The "F1" fault code implies a faulty oven temperature sensor. In order to diagnose which will require disconnecting the oven temperature sensor from inside the oven cavity and measuring the resistance using an ohm meter. The oven temperature sensor probe should measure approximately 1100 ohms at room temperature.
Here is the temp. sensor to order.
Dec 01, 2012 | Magic Chef CEL1115 Electric Kitchen Range
The alarm turn on by itself when the oven is off, F2Code
Faulty signal that is going to the alarm driver to trigger off the alarm. The possible fault is the switching circuit, possible a leak in this semiconductor that is causing this issue.
You will need to go back to trace from the alarm buzzer backward to the driver. Since all other features are working fine, it can be only the faulty trigger.
Disconnect alarm if you think the fault is beyond you to avoid this annoying fault.
Helpful?
Aug 21, 2010 | Maytag CWG3100A Gas Single Oven
My display says F3 and the oven won't turn on. What does this mean?
F3: Open or shorted sensor. The cancel key resets the control and stops the alarm. If fault is still present it will reactivate the alarm when the cook mode is chosen. Correction: Check sensor and wiring for shorted or open circuit.
this is on a maytag oven many ovens have their own code
Feb 11, 2010 | Kitchen Ranges
What does the F3-1 code on a Maytag flat top double oven range mean?
Well error F3 means open or shorted sensor. The cancel key resets the control and stops the alarm. If fault is still present it will reactivate the alarm when the cook mode is chosen. The error F3-1 indicates problem with Sensor of upper oven
Solution - Check sensor and wiring for shorted or open circuit. you need a multimeter to check them. Please post comments for further help or information........
Good Luck!!
Thanks for using FixYa!!
Dec 18, 2009 | Maytag Kitchen Ranges
Kenmore Electric Range
F1 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Feb 15, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Alarm fault code
f-2 is a faulty temp sensor. replace the oven temp sensor to solve problem
Nov 19, 2007 | Magic Chef CGR3742 Gas Kitchen Range
F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
Maytag MER6750 Electric Kitchen Range Logo
209 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
