I have a toshiba 65 inch theaterwide hdtv the red power light blinks no picture no sound
  • 6 Answers
SOURCE: toshiba 65 inch theaterwide
On any tv, first you must have two feeds coming in. That means either your tv must have two video cards, or your cable/antenna box must have two in order to se PIP. From there is a peace of cake... you push one button on your remote control and ....voila. Most tv's will have two video cards, one tor terrestrial antenna and one or more for cable/dish,.
Posted on Nov 07, 2008
abhishek33
  • 1239 Answers
SOURCE: MITSUBISHI 65 INCH HDTV, GREEN LIGHT BLINKING, WILL NOT POWER UP
There are four (4) caps on the 'DM' board that need to replaced. Parts: 680ufd 16 volts, orig are rated at 1,000 ufd.
Posted on Jan 07, 2009
  • 5 Answers
SOURCE: Blinking RED power Light 42hp95 Toshiba
I turned the 42HP95 TV off one night and it didn't come back on. Had the red LED flashing etc. Found the solution posted by CheapTech: http://www.fixya.com/support/t101749-tv_turned_itself_off_turn_back but didn't take it seriously because these things never work, others were mocking the answer blah blah. Well, just before kicking the damn thing to the curb, I grabbed a screwdriver, took off the back cover, unplugged the little do-hicky sugested in the Solution, and the idiot box came right back on. Go figure. Been working ever since. SO, you might want to try this before busting out the electrical schematics and dropping $$ on repair. Cheers.
Posted on Feb 20, 2009
SOURCE: power led blinks but no picture or sound
Had the same problem myself. Took some doing but I managed to find a service bulletin that I downloaded. The problem is with the siene module and all you need to do is unplug connector JP63A from the main board and your TV will work again.
Take the back off the TV (there are a lot of screws) and look on the left hand side of the main circuit board that is mounted in the center of the TV. You will see a small white connector that is labelled JP63A, simply unplug it. Plug the TV back in and let it reboot. That's it, should be able to watch immediately.
Posted on Mar 15, 2009
ginko
  • 19396 Answers
SOURCE: Need to reset, tv power green light blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
My toshiba tv has no sound,what is causing it to malfunction
I have a Toshiba 52HM95 the red light and the green light keep coming on but I get no picture but I can hear the sound very good what could it be please help
Jan 13, 2013 | Toshiba TheaterWide 52HM84 52" Rear...
My toshiba theaterwide hd 51h83 no picture no sound when plug in blue screen come on then go off in 3second then red light next to power button blinking no picture
call toshiba customer care. Seems like software issue. I had the same. I was told to put 2 special files on a usb drive, connect it to tv, to reflash to tv software. it came back to life after that.. just try..
Nov 23, 2012 | Toshiba 51h83 51-inch Hdtv-ready...
Blinking red light no picture
No picture or do u have a blue (or some other color) screen? And the blinking red light, is that the indicator light down by the power button that is blinking? I have the same tv and very similar problem, i have a blue screen and the red indicator light is blinking. If you have gotten ur problem fixed I would love to know how, or vise versa if I get mine fixed.
Sep 11, 2011 | Toshiba 65H84 65" Rear Projection HDTV
When I turn on the TV the sound comes on but there is no picture. It turns off/on automatically several times then the green and red lights blink with no sound.
this is common problem for rear projection TV set's you have to replace the BULB after a approx. time of 2 years I found the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=52HM84
Sep 17, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
No video, shuts off then back on
I checked Toshiba's website and found the manual for the set. The self restarting was indicitive of a lamp failure. The red light was solid while the green light blinked. It would then restart 8 times before both lights would then begin blinking.
Sep 15, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Televison & Video Logo
Top Televison & Video Experts
