Question about Brother LS-2125 Mechanical Sewing Machine
How to sew Shell Tuck Stitch. - Brother LS-2125 Mechanical Sewing Machine
Stitch with maximum upper tension with proper stitch selection will gv a rounded effect too
Posted on Jan 10, 2013
  • mubyriyas Jan 10, 2013
  • Brother Master
  • 1,129 Answers
I can't find an image clear enough to actually see the stitch selection on the front of this machine.
Does it have a stitch that looks like three or 4 straight stitches, then one zig zag, then more straight stitches? This is the stitch you want to select to do a shell tuck.
Then hold your fabric with right side up and turn edge under about 8mm and seam along the edge using this stich so that the zig zag stitch goes over the folded edge each time to the right. This should pull in the folded edge a little giving a scalloped edge.
Just do a couple of trials to work out the best position for the folded edge on the needle plate to get the effect right, probably just the edge of the normal straight stitch but it varies for each machine. If your machine does this stitch with a variable adjustment on the width of the zig zag part, then you could finesse it with this too.
Posted on May 24, 2011
Hi I need to sew a fleecy backing to a crochet item which settings do I need for the wool not to strech? Thanks
I would put the fleece on the bottom. pin the wool item to top with pins fairly close together so it says where you want it. sew with the wool side up and use a normal stitch setting but go very slowly and tuck the wool bits under the sewing machine foot so it does not get caught on a loop of wool. remove the pin just before you are going to sew over it and it should keep your wool centered on your fleece. hope this helps good luck.
Jun 14, 2017 | Sewing Machines
How many stitches to crochet a full size shell stitch afghans
Depends on the yarn and needle used. A large needle and/or large yarn will produce larger shell stitches requiring fewer shells to create an afghan:
shell stitch afghan Google Search
Jan 05, 2017 | Sewing Machines
How do u Decrease a shell stitch
Shorten the stitch length to get shorter shells?
Jul 14, 2014 | Lion Brand Homespun Yarn
Hand sewing craft problems
watch some videos. :)
http://www.youtube.com/watch?v=o1txJLRPfuE
Sep 12, 2012 | Sewing Machines
Want to change a hand crochet pattern for an afghan and make it alternating rows of two different hand crochet stitches;
After the Shell row... chain 2,skip 1, then begin your double crochet.
May I suggest that you find a crochet forum or video on youtube? Lots of things to learn on Youtube. ;)
Want to change pattern within a shell stitch afghan, how?
LOL how did you manage to get so many postings of this?
How do you position the needle/ with which lever or dial? location?
Your model doesn't have a specific needle position adjustment. But you could try this - set it to the shell stitch or lingerie stitch on the stitch selector but leave the stitch width setting on zero, this may move the needle to the left most position with any luck.
Other possibility is to put it in a step of the buttonhole sequence, but again leave stitch width on zero and see if this moves the needle bar to the right or left for you.
Feb 07, 2011 | Elna 2007 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
587 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
