I have installed the WLAN Adapter and tried to configure wireless network,but going back to "Realtek WLAN Client Utility" I noticed that in "Link Status" section line "Connection" stated -"Disconnected". Going back to "Network Preference" of my Mac G5(OS X 10.5.8) I noticed line "Status" stated -"Connected" with a note: "Ethernet Adapter(en2) has a self-assigned IP Address and may not be able to connect". The Version of a Driver I Installed from provided mini CD is: 1064 UI:1.6.8 . Naturally, the LED of the Adapter is not "On". Please,help me set up this Adapter. Thank you Robert Ph.# : (310)394-3356
  • 196 Answers
SOURCE: Connection Issues Occur When I Try to Connect Through a Broadband Network Adapter
To resolve this issue, remove the network bridge. To do so, follow these steps: 1. Click Start, and then click My Network Places. 2. In the left pane, click View Network Connections. 3. Look for any connection that is bridged. 4. Right-click the bridged connection, and then click Remove From Bridge. 5. Repeat step 4 for each connection that is connected with a bridge. 6. When the bridge is removed from each network adapter, right-click Network Bridge, and then click Delete. 7. Click OK. When the all the bridged connections and the network bridge are removed, the broadband hardware is automatically detected.
Posted on Feb 16, 2006
SOURCE: laptop cant connect wirelessly
Hey Charlie, If you re-installed your operating system you will need to get the wireless modem driver from your dell disk. For some reason they have not included the drivers in the windows software. If you can't find it then you can go on to the Dell site(obviously on another computer) and enter your service tag and get your drivers that way.
I hope this helps
Posted on Jan 26, 2008
  • 10 Answers
SOURCE: 2wire 1800hg random no internet/random access, repair/wait fixes
It seems that you said your computer gets the ip address from your router,, which means thru DHCP of the router but if you look at the DHCP settings of your wireless card inside your computer ---the DHCP is OFF -- check your ipconfig/all command as shown in your problem too,,, your wless card does not accept the new IP which comes from your router --as DHCP is OFF on your wless card and sticks with the old ip address whereas the router maintains a new ip for your computer in its table and a mismatch occurs and you loose the internet connection ,,,,thats why repair works and then again the IP changes in the router for your computer and your computer's wless card lags behind and use the old ip adress ..... DHCP--- IS DYNAMIC , WHICH MEANS IT RENEWS THE IP address after some time and you computer gets stuck to the old one ,,, hence mismatch. "you make the DHCP -ON on your wless card too. it will be fine."
Posted on Mar 06, 2008
crapiemael
  • 241 Answers
SOURCE: After replacing Cable Modem, D-Link DI-524 Wireless will not work
Did you call Comcast and give them the new MAC address of the Motorola SB5101 SURFboard cable modem? I'm surpised it works at all without doing this first. This is the hardware address of your modem so the world can see you, no one in the world has the same MAC address, they are all different. It's on a sticker on the modem.
Posted on May 28, 2009
mikegbali
  • 324 Answers
SOURCE: I cannot connect to wireless internet through my
make sure you the AP is on DHCP
Posted on Sep 08, 2009
My driver detects wireless networks then for no reason doesnt detect any then i restart my computer then it detects them again. wat could be the problem?
Make sure you get the Realtek Wireless Lan Utility; if you're not using it now you're lucky you can connect at all.
When you get that installed, or if you already have it, find the file in the REALTEK install folder called 8185.ini (or 8185x64.ini on a 64 bit OS), delete everything in it, and paste this into it. It'll give you more control over the card and open up new options in the wireless utility.
[Country]
AutoSelected=1
xxnCountry=2
[WLan Utility]
WZC=0
RtWLanTitle="REALTEK RTL8185 Wireless LAN Utility"
MANUFACTURER="REALTEK"
Model_Name="REALTEK RTL8185 Wireless LAN"
NO_Adapter_TEXT1="REALTEK RTL8185 Wireless LAN Utility"
NO_Adapter_TEXT2="Realtek Semiconductor Corp."
NO_Adapter_TEXT3="Copyright (c) 2003-2009"
[UI Config]
ICS_Page_SHOW="1"
MACfilterPage_SHOW="0"
AP_Mode_ENABLE="1"
AP_Mode_WPA_PSK_ENABLE="0"
WPA2_ENABLE="0"
AP_WPA2_ENABLE="0"
WDS_AP_Mode_ENABLE="0"
RT_SET_ENABLE="0"
802_1X_SHOW="1"
Link_ANY_ENABLE="0"
EzConfigPage_SHOW="1"
SimpleConfigPage_SHOW="1"
WiFiProtectSetPage_SHOW="1"
External_Registrar_SHOW="1"
AdvancedPage_SHOW="1"
DbgWnd_SHOW="1"
WLANModeTo90="1"
PowerSave_SHOW="0"
TurboMode_SHOW="1"
WirelessMode_SHOW="1"
PREAMBLE_SHOW="1"
Channel_Plan_SHOW="1"
XLink_SHOW="1"
WMM_SHOW="0"
RTS_Threshold_SHOW="1"
Fragment_Threshold_SHOW="1"
WOL_SHOW="0"
DATA_RATE_SHOW="0"
Throughput_SHOW="0"
VWiFi_SHOW="1"
[98UI Config]
AP_Mode_ENABLE="1"
WPA2_ENABLE="1"
RT_SET_ENABLE="1"
802_1X_SHOW="1"
PowerSave_SHOW="1"
TurboMode_SHOW="1"
PREAMBLE_SHOW="1"
XLink_SHOW="1"
WMM_SHOW="1"
WOL_SHOW="0"
DATA_RATE_SHOW="0"
Apr 07, 2012 | Gateway Realtek RTL8185 54M Wireless LAN...
Tip
How to Install WG111v3 on MAC OS 10.3 , 10.4, 10.5
<p>The below article would illustrate the steps to install the NETGEAR wireless adapter WG111v3 on MAC OS 10.3, 10.4 and 10.5.<br /> <p><br /> <p>Please ensure that you have installed the latest version of driver for the adapter from the below link on your MAC OS computer:<br /> <p><br /> <p><a href="http://kb.netgear.com/app/answers/detail/a_id/2640">http://kb.netgear.com/app/answers/detail/a_id/2640</a><br /> <p><br /> <p>After the installation of the driver please perform the below task:<br /> <p><br /> <p>1. Plug in the adapter.<br /> <p>2. Double click on the NETGEAR WLAN Client Utility in the desktop.<br /> <p>3. On the NETGEAR WLAN Client utility select the Available Network tab which will detect the wireless network, select your network and click Connect.<br /> <p>4. If you are connecting to a secured wireless network then you will be prompted for a Wireless Network Security Properties menu.<br /> <p>5. Type the network key WEP/WPA security and click OK.<br /> <p>6. Click on Link Status which shows the connection as connected.<br /> <p>7. Check for the IP address by clicking on the Apple icon and select System Preference.<br /> <p>8. Click on Networks and check the IP address.<br /> <p><br /> <p>You should have succesfully established the wireless network on your MAC.
on Mar 24, 2011 | Computers & Internet
Intellinet wireless adapter malfunction
Wireless Zero Configuration (WZC) was introduced with Windows XP, it is also known as WLAN AutoConfig in Windows 7 and Vista. It is is a wireless connection management utility which dynamically selects a wireless network to connect to based on a user's preferences and various default settings. or most users the Windows Wireless Zero Utility is all that is needed to manage your wireless connections.
You can configure WZC as follows:
  1. Type services.msc in "run" and enter.
  2. Select wireless zero configuration from the list which appears in the next window.
  3. Double click on that option , and choose to Start or Stop the Wireless Zero service.
Here are steps to use Wireless Zero Configuration/WLAN AutoConfig in Windows 7:
  1. Click the Windows logo button
  2. Type services in the Start Menu's Search box and press Enter. Scroll to the bottom of the list and locate WLAN AutoConfig'. Double-click WLAN AutoConfig to open its Properties window.
  3. Click the General tab of WLAN AutoConfig service. Click the Startup type drop-down menu and click Automatic to have the service started automatically when the operating system loads. Click the Start button. Click Apply and then OK. Close the Services console window.
  4. Click the Windows logo button. Type cmd in the Search box and press Enter. In the Command Prompt window, type netsh wlan show settings and press Enter. Look at the last line of the Wireless LAN Settings entry to see if the message Auto configuration logic is enabled on interface or Auto configuration logic is disabled on interface appears. If the entry notes that it is disabled, type, set autoconfig enabled=yes interface=Interface Name and press Enter. Close the Command Prompt window.
Nov 25, 2011 | INTELLINET Wireless 150N USB Adapter...
I have ASUS WL-167G v3 Wireless USB Adapter. It works well with my MacBook but when I connect it to my WinXP PC, it detects the two networks that I have in my house, but does not connect to neither. Both...
You mentioned that you have Windows XP SP1... You need to install at least SP2 or even SP3 for this adapter to work. If this computer doesn't have internet access at all, then you can usually get SP2 or SP3 on a disc for free from Microsoft.
Feb 28, 2011 | ASUS Computers & Internet
There is no wireless internet conection from the router to the network places
make sure you turned on the wireless adapter....Check for the driver status....go to start>run>type "services.msc"
scroll down to wireless zero configuration (for xp) / wlan auto config (vista and win 7) and start the service....
also disable any utility that controls your wireless adapter and use windows default utility....
Mar 29, 2010 | D-Link DIR-655 Wireless Router
When I try to run the Dell Wireless Configuration Utility from the control panel I get the following error message:"The wireless network adapter could not be accessed. This application may have diminished...
Well Sir in this case i will advice you to disable the Dell Wireless Configuration Utility and instead use windows utility for a successful connection.
For disabling dell configuration utility follow these steps:-
1)Open dell Wlan utility , it will have five tabs at the top labeled wireless networks , link status , site monitor , diagnostics and information.
2)Click on wireless networks tab and uncheck the first option which says , "Let this tool manage your wireless network" then click ok or apply at the bottom right-hand side corner of the screen.
To Enable Windows Utility for Windows XP follow these steps:-
1)Open the Control Panel from the Start Menu.
2)From Control Panel click on network and internet connections and then open network connections from there.
3)Right-click Wireless Network Connection and choose Properties.
4)
Click on the Wireless Networks tab and if unchecked , then check the box for Use Windows to configure my wireless network settings. Then click OK.
5)Right-click on Wireless Network Connection, Select View Available Wireless Networks.
6)
This will lists all the available wireless networks in range. Select your network from the list and click Connect.
7)If you are connecting to a secured wireless network, you will be prompted for a Network key. Type the Network key(which is the password for the wireless network) and then click connect.
8)Your network list should now display your connection status. If you are connected and your router is setup for internet access, you are ready to connect to the Internet wireless.
This Link will guide you through the steps:-
http://kb.netgear.com/app/answers/detail/a_id/111/kw/wireless%20zero%20configuration/r_id/100109
Nov 24, 2009 | Computers & Internet
Does not save wireless security settings
Encrypting the network blocks any unauthorized computer from accessing the network and using its broadband connection. To enable WEP on the router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2. When prompted for a username and password type “admin” on password, unless you have previously changed the password of the router, and hit OK. This will bring you to the Setup page of the router.
3. Depending on the firmware of the router. Click on the WEP Key Settings button. Or you can click the Wireless tab and select Wireless Security. Or you can click the Security Tab and select Wireless.
4. From the WEP/Security Settings window, you may enable 64 or 128 bit WEP then enter your Password on the Passphrase field and click on Generate. Make sure to copy the characters on Key 1-4 on a piece of paper before you hit APPLY. You will be needing this once you enable WEP on the wireless PC’s. Also take note that if you enable 64 or 128 bit on the router, this should be the same WEP level that you will enable on the wireless cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1. Go to start>Control Panel>Network Connections>Right click on the Wireless connection then click on Properties>Click on the Wireless Networks Tab
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then uncheck “The Key is provided for me Automatically”
3. Type your WEP Keys on both the Network Key and Confirm Network Key field. (This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.) Then hit OK and then OK again.
4. After hitting OK a pop-up should appear on the lower right hand side saying “Connected”. Try pointing your mouse arrow on the lower double monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make sure that the WLAN utility of the Linksys adapter is already is installed. If not, you may follow follow the procedures below for "Installing the Linksys WLAN Utility"
1. Click on Start then Programs, then click on anything that says something about the Linksys Wireless Adapter. On the menu, select either WLAN Utility or Wireless Configuration Utility
2. On the lower right-hand side of your screen, double click on the Linksys Icon. This will bring up the WLAN Configuration Utility.
3. Click on the Profiles Tab. Make sure that the SSID that is set to default is your routers SSID. Highlight Default then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6. Type your WEP Keys. This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
Nov 15, 2009 | D-Link Vonage-enabled Wireless Router...
Belkin wireless G adapter shows as working but no networks
make sure the Wireless zero configuration or WLAN auto configuration service on your OS is running
Try to search for wireless network using the Belkin wireless utility after disabling windows
Nov 19, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Trying to connect to my home wi-fi using laptop with installed linksys wpc54g wireless adapter but the problem is when i use linksys utility it starts, but can't find wifi lans i see frozen word searching...
limited or no connectivity means your wlan not communicating with the router, check if you turn on the wlan switch on your laptop or try to install updated driver for you wlan
if thats a external wireless lan card try to unplug and plug it back.
Nov 17, 2008 | Computers & Internet
Cannot connect
Hi, A couple of questions to gather more information: On what platform are you using the wireless adapter, a laptop or a desktop PC? What brand/model or motherboard? If it is a laptop, is it built-in, USB or PCM-CIA card? If it is a desktop, USB external or PCI add-in card? What is the brand/model of the wireless adapter? What is your OS? Are you using Windows Wireless Network Configuration Utility or a third party/wireless adapter manufacturer client/utility program? Have you tried NetStubler to verify if your wifi card is receiving something? Post back then we can start figuring things out. Kind regards.
Aug 22, 2007 | Zyxel ZyAIR G-570S - Wireless access point...
Computers & Internet Logo
David Payne
David Payne
