Question about Cameras
How do I set the Iso and flash - Cameras
  • kakima May 23, 2011
    What make and model camera?
  • 3,287 Answers
ISO is the sensitivity to light. The lower numbers 80, 100, 200 are the LEAST sensitive (but provide the best looking pictures). Sensitivity has to do with the amount of light needed to properly expose an image. ISO is a part of exposure that works with Aperture (f stop) and shutter speed (in seconds - or fractional seconds). Here's how it looks:
The graphic above shows that varying either of these three values changes the exposure. If you change one by one step, you have to change one of the others by one step to get about the same exposure result. Each of the step values on your camera for the shutter, aperture and ISO is twice as much as the previous value. ISO 1600 is 2x ISO 800, which is 2x ISO 400, and 2x ISO 200 and finally, 2x ISO 100 (some cameras go to ISO 50 or less!).
The shutter works the same way: 1/1000 is 2x faster than 1/500, and 2x 1/125, and 2x 1/60, and 2 x 1/30, etc. These are easy to see the how each is twice as much as the other.
Finally, the aperture. Each "f stop" allows 2x as much light as the previous value. f2 lets 2x as much light as f2.8, which lets in 2x as much as f4, etc. I know the number don't double like you would expect, and the smaller numbers allow more light (you'd think it was the other way around) - but it's because we're talking about a circular lenses and it has to do with how we calculate area of a circle (3.14 x R squared). It may be easier to recall small numbers = equal large openings by thinking of f numbers with a "1/" over them - like this: 1/f1.4, or 1/f2, 1/f2.8, etc. Here's a chart that shows how aperture and shutter speed work together at one ISO setting.
Read them across, the top line shows that 1/250 @ f1.4 is the SAME as 1/125 @ f2.0, which is also the SAME as shooting 1/60 @ 2.8, etc. If you were to increase the by one step, the shutter speeds would increase by a factor of two. Twice as much light by opening the aperture by a single stop means you must halve the exposure time or halve the ISO value. Likewise, if it's too dark to get a decent picture; increase exposure time or ISO value to capture enough light.
Assume a properly exposed picture requires 1/30 of a second at f5.6 with ISO 200. If the camera was increased by one step to ISO 400, you can take the picture a f5.6 still but in 1/60 sec - greatly reducing the chance of blur from holding the camera in you hand. You could even go up one more step to ISO 400 and shoot in 1/125 sec, which would reduce the blur even more. Fast shutter speeds reduce the "camera shake" and stop motion in sports photography - or other moving objects. If you had the camera set up on a tripod, you could dial the ISO down to ISO 100 and shoot at 1/30 of a sec at f5.6. If your lens can open up to f4, you can shoot in half the time because the lens is letting in twice the light. Some point and shoot cameras don't allow changing f stops or even shutter speeds - so all you can do it raise and lower ISO.
Which camera and flash do you have?
Posted on May 23, 2011
Iso led keeps flashing on my eos 10s
clean the iso detect pins in the film chamber, and check to make sure they are not bent
Jan 05, 2013 | Canon EOS-10S 35mm SLR Camera
Fmay nikon d40 flash in not working..
You might be shooting with a higher ISO or in settings where the D40 meter finds enough light and doesn't activate the flash.
Try changing the ISO to a lower one, like ISO 200 and take some test shots indoors, in a darkened room.
OR, you might have the mode dial set to "no flash". That's the crossed out lighting-bolt symbol. Just set it for P or another mode and you're back in business.
Hope this helps
Mar 02, 2011 | Nikon D40 Digital Camera
Bad indoor pictures. When I take indoor pictures and it says to use the flash I do but then my pictures turn out dark/grey. Then I try it without the flash and they are brighter but then blury. I even...
The flash has a range of up to around 10 feet at the wide end of the zoom, down to 6.5 feet at the tele end. Maybe you are using it on to big a distance or at to low ISO? Try setting the ISO to 800 and see if it helps. images get a bit more grainy at 800 ISO but are also less prone to camera shake, if you use it without the flash. The camera goes as high as 1600 ISO, but images get very grainy at that setting.
Jul 01, 2010 | Canon PowerShot SX100 IS Digital Camera
Pictures are over exposed when outside
You may have the settings wrong. Check in the MENU to see if you have it set to "inside" pics rather than outside.
Also the ISO has a lot to do with the exposure. If the iso is set too low outside sunlight pics will be white or overexposed. Try setting ISO on wheel for various options select program mode button and MENU select ISO 120 or 250. These are are pretty general settings. the flash will only engage inside or outside if the light is low ( like evening) I suspect your ISO setting is at a setting that is incompatible with bright sunlight
t
Also select White Balance and move it to DAYLIGHT
take a few shots inside and out to see if there is an improvement.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Samsung Digimax L60 Digital Camera
Can't take pictures w/ flash
Maybe you have the ISO set to a very high number. Set it to "auto ISO".
Sep 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Built-in flash not flashing as expected
I'm not sure if the problem is the flash or settings on your EOS, from what your saying.
Lets try to change the settings first.
Try to change the settings of your camera, look in your manual. What your looking for is ISO, this is the exposure. By taking practice shots and changing ISO you will find a setting that will match your preference.
Also, it seems like your flash is faulty. Contact Canon to fix it for you.
If you have the money, try to fix your flash. Otherwise set your ISO to auto or change it every time you take a picture outside or inside.
Sep 13, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Grainy pictures...iso problem for olympus stylus 820
Without ISO you will not be able to take pictures.
ISO is the old ASA which is related to film speed
ISO 50 is very slow film speed and may result in blur and some grainy appearance , same as if you PUSHED ISO up to 800 in low light.
Try setting it to ISO 100 and see if that helps.
You can still select auto, but its related to either shutter or aperture priority in relation to the set film speed ( now ISO 100)
Sep 09, 2009 | Olympus Stylus 820 Digital Camera
Pictures are dark
The ISO (sensitivity) is set too low, like 200 ISO.
Change the ISO setting to 3200, or maximum just to see if pix become very light.
Normally, you might want to keep it around 800 ISO.
Put in new alkaline batteries to test the flash. Don't use rechargeables or "heavy duty" for this test.
Aug 30, 2009 | Cameras
Can't take pictures in low light/no flash with my Nikon D40X
First of all you need a tripod to cut down on the movement . Next use the mode dail and select a nigt setting .
You can even use a shutter speed in Aperature Prioity .Ypu might want to use exposure comp .
This should work for you.
Apr 07, 2009 | Nikon D40x Digital Camera
Canon 430 EX flash problem
Were you indoors? if so, take the ISO of AUTO and out it on 400. Leave the camera set like you had it, Manual 1/60 @ 5.6. Do notuse evaluative metering. Use single spot metering or the smallest center weight setting.
Jun 28, 2008 | Cameras
Cameras Logo
144 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
