Question about Dynex Televison & Video
After 30 to 45 minutes of operation the screen starts to flash with a light background and colored lines from top to bottom. This begins slow and gets faster . When the unit is turned off and left alone for some time and then urned on again it runs normally again for 30 to 45 minutes and then begins the same problem.
  • weanes317 May 24, 2011
    Unit is a DYNEX 22" LCD Model DX-LCD22-09
    Sound is not effected when this occurs
  • Dynex Master
  • 2,098 Answers
Please let me know the brand and model no. of your unit to assist you further.
Jdvillnaueva
Posted on May 23, 2011
  • 1 more comment
  • Jdvillanueva
    Jdvillanueva May 23, 2011
    Also, does the sound remain after the symptoms appear?
  • Jdvillanueva
    Jdvillanueva May 24, 2011
    Thanks for the response.
    This symptoms indicated of faulty either the LCD controller board or the main board. The main board process the image through the IC MSD119CL/BL and then feed to the LCD controller board. LCD controller board process it also and then feed to the LCD Panel.
    Since the sound is stable, high chance that the fault came from the controller board. You may confirm it by touching the IC's of this board. If you feel that the IC's gone to excessive heat upon the symptoms appear, this is an indication that the board gone bad and caused the symptoms.
    I'm not sure if you're unit has a built-in fan, if no fan installed, this is one reason why the symptoms appear.
    Check also the power supply for bulged electrolytic capacitor, if you found it, replaced this first and observe if the symptoms still persist. Also give the unit proper ventilation, keep away all obstruction from the fan/vent to have a sufficient air flow.
    Hope I helped you.
    Have a nice day!
    Thanks for using Fixya.
  • Jdvillanueva
    Note : Check also if you're unit is still under warranty/extended warranty, avail it because the manufacturer will fix it for free, opening the back cover will void the warranty.
Blue Vertical Line
It is sounding like when the laptop is turned on and heats up a bit, the line appears? Sounds like one of the panels is going bad or atleast has developed a problem. below are some tricks you can try to lessen the annoyance of the line. Dual-Scan STN displays are composed of 2 panels behind a single protective panel or screen. Because you are looking through the protective screen the display appears to be one large panel even though it is not. There is a physical separation line (gap) at the point where the two panels meet. When the computer is on and being viewed it is not unusual to see the visible separation line with the Dual-Scan STN displays. The line, actually the fine gap between the display panels, appears because the color and light pixels cannot run along the very outside edges of the panels. This line (gap) between the panels can be seen as a fine gray line and is most noticeable when viewing on a screen with a white or light background. Note the line may not be as noticeable when the screen is displaying certain colors or darker backgrounds. SUGGESTIONS: It is not possible to completely eliminate the line but there are some things you can try to reduce it's visibility. 1) Lower the display brightness/contrast. The brighter the backlight the more noticeable the line. 2) Use Wallpapers and Screen savers that use darker colors. 3) In the Control Panel/Display applet under appearance try different combinations of color schemes for your Window and Background choice Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Tip
How to Format an HP Recovery Drive
How to Format an HP Recovery DriveThe HP Recovery Drive is a partition HP puts on its hard drives for use in case the primary partition becomes corrupt or unusable. The recovery partition contains system files and the ability to boot and repair, format and reinstall the operating system if needed. For those who prefer recovery disks or who don't feel the need for the insurance of the HP Recovery drive, it can be formatted by following the steps below.
Instructions1 Open Disk Management by Right Clicking "My Computer" and selecting "Manage."
2 Click on "Storage" and "Disk Management."
3 Find the Recovery Drive partition. There are usually two partitions: the "C: partition" and the "HP_RECOVERY D: partition."
4 Right-click on "HP_RECOVERY D:" and select "Format."
5 Choose the File system and Allocation Unit Size and click "OK." The HP Recovery Drive partition will format and be available for your specified use
Tips & Warnings
Be very careful to not format the C: drive by accident.
on Dec 15, 2011 | HP Computers & Internet
Tip
Riding Mower No Start Troubleshooting
  • First check the air filter to see if it getting air and gas.
  • Check your gas cap. If your gas cap is clogged, your fuel tank can get a vapor lock, and you will have no gas flow. Loosen the gas cap to see if it will run longer.
  • Check the gas filter (if you have one on the mower) to be sure it is clean and has good gas flow.
  • Check to see if you are getting spark at the plug. Check out the video below.
If the engine clicks but will not start, the battery or solenoid is often to blame. To find the battery on a riding lawn mower:
  • The battery may be under the hood
  • The battery may be located under the seat
  • You may need to lift the hood to find the solenoid
  • Check the owner's manual for the battery or solenoid location
Check to see that all wires are securely connected and that the terminals are clean.
If the lawn mower still does not start, the problem may be with the fuel, if it was left in the mower over the winter months the fuel may have become stale or watered.. If the fuel appears dirty or contains water, you will need to drain the fuel tank and replace with fresh gasoline.
Other reasons for the mower not to starting also include:
  • Damaged or loose wiring
  • Problems in the carburetor
  • Maladjusted or damaged engine valves
  • A blown fuse
  • Ignition switch may be faulty
on Oct 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tip
How To Reset Your Mobile Phone
You can return your phone to its original state, as it was when it left the factory. This is also called a hard reset. You might want to do this if you are giving your phone to a friend or relative and you want to remove all your data first, or if your phone has a persistent problem that is not solved by powering off the phone and then powering it on again.
A factory reset is a drastic measure. It permanently erases all your personal data and customized settings, and also removes any programs you have installed. Make sure that you have backed up the information and files you want to keep.
As different phone models have its own reset procedure, view complete list here.
on Jul 09, 2011 | Cell Phones
Tip
How To Find Motherboard Drivers
How To Find Motherboard Drivers:
Here is a real world example on Fixya.com of some one having a problem getting drivers:
Question:
I need drivers for my FC GIGABYTE 8vm533m-rz motherboad
That is a some what a perfect question, the brand has been given and the motherboard modal number has also been given, so finding the drivers will be a peace of cake !
First of all, always go to the makers brand website, in this case we would go to Gigabyte's official website located here
Next, go to support & downloads;
Then copy and paste the motherboard modal number ( in this case is 8vm533m-rz )
From there we can get the drivers, located : HERE
locate the bios update: HERE
and that crucial mobo manual we all seem to lose: HERE
And that's the very basics, the same method would be used for every motherboard. Mostly all manufactures are happy to provide the drivers and support software on there websites.
Hope this helps some one out there.
on Jul 02, 2011 | Computers & Internet
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
Tip
Unlock Your Nokia mobile phone with Code Calculator
What is Unlocking?
Unlocking a mobile phone is the procss of removing any SIM Card or Network restrictions set on the phone by either the manufacturer of the phone or by the mobile phone's service provider. After unlocking a mobile phone, you can still use it with it's existing network or switch over to any other supported network.
Get free unlocking codes here
on Jan 10, 2009 | Nokia N95 Cellular Phone
Televison & Video Logo
44 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
