Question about Zebra QL 420 Plus Thermal Label Printer
Need to have the print darker - Zebra QL 420 Plus Thermal Label Printer
  • 1,116 Answers
Resolving Print Quality Issues on Performance Line PrintersCheck this link for your model solutions:
https://km.zebra.com/kb/index?page=content&id=SO7322&actp=LIST_POPULAR
Posted on May 23, 2011
  • 4 more comments
  • hermand25 May 25, 2011
    This is helpful but I forgot to mention. The print comes out perfect when doing a test print. But for some reason on two of our many zebras the labels come out very light when used for normal printing. Any suggestions to fix this?
  • Gale Todd May 25, 2011
    There are different types of issues due to light printing. Once a symptom is determined see the following for possible resolution:
    1. Light print on one side (left or right)
    2. Light print in the center
    3. Light print that occurs at fixed 2" intervals along the page or blurry streaks in printout
    4. Sharp streaks in printout.
    5. Universally light print, even over entire page.
    6. A section of the printout (from ¿ to 2") is lighter than the rest.
    For conditions 1 and 2, ensure that the print head is firmly latched in the closed position. There are two latches, one on each side that must be in position for proper print. If this does not solve the issue, the printer may need calibration, which can only be done in the field by highly technical users. It is usually best to have the printer returned for this procedure.
    If condition 2 is not solved by checking the print head latches, the printer must be returned for service (warped guide plate or bad screws on early TTP 8200s, usually before week 2 2002)
    For condition 3, open the print head and check the platen for physical damage or debris. Physically damaged platens must be returned for service for repair. Debris can be blown out with an air dusting can or IPA can be used to clean the print head and platen surface. It is common for the platen to become very dirty and require several cleaning passes. This condition can also occur when the print head has reached end of life.
    For condition 4, clean the print head surface with IPA. It is important to properly identify this problem correctly and not mistake it for a platen defect as covered in point three. Printers with sharp streaks in their printouts usually have many failures across the head from ion migration (usually 20+ pixels distributed randomly) may have a bank out (1/4 of the printout is missing), or may be missing single pixels from print head damage (usually less than 10). Usually this condition required the printer be returned for replacement of print head. Ion migration problems (that occur when the printer has been sitting powered on for long periods of time) are covered under warranty for 7 years from the date of manufacture. Missing pixels are not covered under standard new product warranty if they affect less than 10 pixels. Bank problems are covered under standard new product warranty.
    For condition five, verify the print head is locked down, and after that ask about the paper the customer is using and how much printing the printer has done. If you are not using a Zebra approved paper, the paper may be to blame for the poor print quality. If the printer has printed 60000+ pages, the print head may be worn and my require replacement.
    For condition six, there is always some minor variation between the four banks of the print head, but there shouldn't be any areas that are significantly less dark. If there are have, the customer will probably have to return the printer for print head replacement under 7 year warranty (firmware over burning caused greatly reduced print head life). At the same time as this replacement, the firmware will be updated to a version that does not have this problem
    This is very informative but its a brand newish printer and all of this has been done and checked. Its not a hardware problem its something to do with software or contrast settings. I just want to know how to do this....
    Resolution
    Change the darkness setting in the Windows driver.
    Click the "+" sign to open up the "Head Settings" option in the driver settings menu.
    Use the slide control to adjust the current settings to change the darkness of the printed output. This changes the temperature of the print head and so is also referred to as temperature. The higher the value, the higher the temperature and the darker the printed output.
    To set the print darkness in the driver;
    Click on Start Settings, Printers.
    Right click on the driver and select Properties.
    Select the Printers tab.
    Expand the Device Options tab by clicking on the + to the left of Device Options.
    Expand the Head Settings tab.
    Adjust your darkness setting.
    Collapse the Device Options tab by clicking on the - next to Device Options.
    Click on Apply, then OK.
    Close the printers folder and test your printer.
How to get the black darker
You can use Paint on your computer to modify it. If not it just might be the type of printer. See if you can buy darker ink at another store. If not your pretty much stuck like that. You can also go to copy stores or most major stores to get stuff copied for free or cost....
Windows 7 XP Security Center
Jan 29, 2014 | HP Designjet 5500 InkJet Printer
Rimage everest 2 prints get darker after 10 prints
1. for print cartridge2.for print media
3.for room temperature not adjust with printer needed .
4bad contact with print cartridge and the printer
Aug 29, 2012 | Rimage Everest II Printer
Our C9800 Oki laser printer is printing images darker in colour on one side of the page to the other. It looks like it is printing with a lot more yellow on one side. If I send the paper short egde feed it...
What you have here is one of the LED print heads is not sitting correctly on the corresponding drum. Make sure the LED head is free to move and there is no foreign object sitting in/on the drum. Where it is darker the print will be fuzzy around the edges and that confirms what I have said.
Jun 30, 2017 | OKI 9800hdn Laser Printer
My printer prints fine, but how can I make it print darker. It seems to have gotten much lighter and the ink is relatively new.
There should be a button on the top that says lighter/darker, move it 2 clicks to the right for more ink to be used..... please let me know if there is anything else you need, happy to help! Guy :)
Sep 23, 2010 | HP LaserJet 3050 All-In-One Printer
Print is to light. How do I get it to print darker
there is a option u can do it dark and light,,,
press dark or light botton, than its gives u dark print ,,
if there is ok than change your cartridge,
May 04, 2010 | HP Officejet 5610 All-In-One InkJet...
How do I get a darker print?
when you click to print a document it has properties next to the printer click on this then set the print quality to best it will come out darker!!
Apr 08, 2010 | Dell Photo 964 All-In-One InkJet Printer
My photos print out way darker than the monitor shows this happens with two different printers...I need tips on how to adjust it. NOT a computer person ;)
Hi this could be your printer aswell, your printer could be printing the colours in darker then it should, or if it is this Screen , then your screen is probably set too bright then it should making everything lighter and brighter
Thanks
Dec 28, 2009 | Dell 1703FPt 17" TFT LCD Flat Panel...
HP 5550 Laserjet prints dark
The only time I saw a color laser Printing darker than normal the issue was tranfer belt. The condition you describe matches the problem I was involved in and the tranfer kit fixed the problem.
Hope this helps
Aug 28, 2008 | HP LaserJet 5550 Printer
Printing darker
charging connections are not properly connected
Sep 06, 2007 | OKI C5150n Led Printer
Zebra QL 420 Plus Thermal Label Printer Logo
659 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
