Question about KitchenAid KWVU205YBA Kitchen Hood
Kitchen aid slide out vent hood mod. # kwvu205yba-0 All fan speeds and light does not work. unit is getting power.
Powerman
  • 68 Answers
SOURCE: Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
Posted on May 03, 2007
  • 100 Answers
SOURCE: How to reset my Jenn-Air Jxt8836ADS kitchen hood?
According to Jenn-Air (Maytag) if you remove the power from the hood for 15 minutes it will reset the board. So depending on how long the power was out the outage would have done this. There is a good possibility that the outage ruined your board.
Posted on Nov 02, 2007
shaggyrat
  • 1224 Answers
SOURCE: Zephyr typhoon AK2100 Kitchen Range Hood
its the relay inside that controls which speeds the hood works at this connects to the switch speed control
Posted on Jun 01, 2008
  • 3 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Posted on Apr 27, 2009
ricardok45
  • 135 Answers
SOURCE: KA Mod K5SS: no longer have variable speed; only 3 of the lowest
Hi. Go to mendingshed.com. Look up Kitchenaid Mixer Parts. Near the top of the page locate their FREE Kitchenaid Service Manual in Adobe format. Download it. This valuable document will help you with your troubleshooting of the speed control and anything else that needs fixing. This manual supports your K5SS. Mending Shed also carries Kitchenaid parts.
If you order parts from Kitchenaid, be prepared to wait at least a month for them to arrive!
If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on May 02, 2009
How to replace control switches for a venmar hood fan
[PDF]Download - Venmar
www.venmar.ca/DATA/.../131_5_en~v~Installation_Manual.pdf
Before servicing or cleaning unit, switch power off at ... solid-state speed controldevice. 8. ... should not be allowed to accumulate on fan, filters or in .... We recommend to install the hood at a minimum distance of 24" from an electric range and.
FAQ - Venmar
www.venmar.ca/en-faq.html
Can I use other controls than Venmar controls with my unit? What is the ... Range Hoods. Can I replace an "over-the-range" microwave with a range hood? ... VenmarConnaisseur C270 and C600M · Rocker switch control. Venmar V10 ...
Range Vent Hood Switch Parts In Stock from RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Range-Vent-Hood-Switch-Parts
Shop for your Range Vent Hood Switch from our huge inventory. Check our ... RepairHelp for Range Vent Hoods ..... Blower variable speed control switch.
Range Vent Hood Repair Help - Free troubleshooting
Jan 23, 2016 | Venmar Kitchen Ranges
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Removing over the hood microwave
There is no microwave hood on a Kitchen Aid blender
Sep 06, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
How do you replace?
Kitchen hood replacement can be completed easily with a family member or a friend. While you may wonder why anyone would replace a kitchen hood, the answer usually is simple. Here is how to replace a kitchen hood.
Tools Needed
  • New Range/Kitchen Hood
  • Screws
  • Screwdriver
  • Friend
  • Wiring Nuts
  • Circuit Tester
Warning: Remember that you are dealing with electricity, so stay away from water and use all safety precautions issued by the manufacturer.
Step 1 - Shut off Electricity
Remember to turn off the electrical supply to the old kitchen hood. You will need to do this via the circuit breaker box. Wait for 10 to 20 minutes and then test the wires with the circuit tester to double check that no electricity is being supplied to the kitchen hood.
Step 2 - Remove Old Hood
After you know for a fact that it is not receiving an electrical current, you can begin the process of removing the older kitchen hood. You should first take off the electrical wiring cover that is located by the light fixture. Then have your family member or friend hold up the old kitchen hood while you remove any screws or bolts from it. Once that is done, you can then freely slide it off.
Step 3 - Check Wiring
Double check that you have at least 12 inches of wiring to connect your kitchen hood to the wall. It should be noted that if you have a kitchen hood without vents, proceed to step 5 next.
Step 4 - Find the Ducts
If your new kitchen hood has vents, you will need to locate the fan or vent duct. Once you have found it, you can open up the vent hole where it will belong.
Step 5 - Wires
Open up the covering for the wiring and put the covering in a safe area for easy reach.
Step 6 - Install the New Kitchen Hood
Have your friend or family member hold up the kitchen hood and mark the areas where the screws or bolts will be. Then have them put down the kitchen hood and screw in the screws half way into the holes. After that, you can slide in the kitchen hood.
Step 7 - Route Wiring
Lightly pull the wiring through the proper holes and connect both black wires from the new kitchen hood to the black wire from the wall with a wire nut. Then connect the two white wires from the hood with the white wire from the wall, again using a wire nut. Next, connect the green wire to the green ground screw. Then place the wire covering back on.
Step 8 - Tighten Screws
Finish tightening the screws in place.
Step 9 - Test
Check to make sure the fan and light work. If it is supposed to vent outside, make sure that the air is leaving the vent with no issues. If something does not work proper, repeat steps 6 and 7 until everything works well. Remember that you will be working with electrical equipment, so follow safety measures issued by the state or the city.
Jan 29, 2011 | Kobe RA9436SQB Kitchen Hood
Range Hood Issue
Definetly need a new motor control.
Nov 26, 2008 | Kitchen Ranges
Light and blower speeds malfunctioning
Hi mutt750,
I'm Harvey the Master Plumber.
I agree. It sounds like your neighbor is doing well. I would replace the control board too. Sounds like a nice guy. Time to invite him over for a bbq?
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 07, 2008 | KitchenAid KWVU205YBA Kitchen Hood
KitchenAid KWVU265YBA
had same problem. microcomputer part # 4360092 and micro switch part # 4360362 needed to be replaced. cost 255.95 and 23.59 for parts respectively.
Feb 25, 2008 | KitchenAid KWVU265YBA Kitchen Hood
Oct 31, 2007 | Jenn-Air JXT8836ADS Kitchen Hood
KitchenAid KWVU205YBA Kitchen Hood Logo
198 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
