How do i change my ink cartridges in my epson workforce 520 series 3 in 1 printer?
  • 93 Answers
Replacing Ink Cartridges
Make sure you have a new ink cartridge before you begin.
Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are
vacuum packed to maintain reliability.
Leave the expended cartridge installed until you have obtained a replacement, or the ink
remaining in the print head nozzles may dry out.
1. Turn on the product.
2. If an ink cartridge is low or expended, you see a
message on the LCD screen indicating which
color to replace. Press OK.
If a cartridge is expended, you must replace it to be able to print or copy. If a
cartridge is low, you can continue printing until a cartridge needs
replacement.
If you're replacing a cartridge before you see a message on the LCD screen,
press xMenu, press u or d to select Maintenance, and press OK. Then
select Ink Cartridge Replacement and press OK.
3. Open the scanner, then open the cartridge cover.
4. Squeeze the tab on the cartridge and lift it up.
Dispose of it carefully. Do not take the used
cartridge apart or try to refill it.
Warning:
If ink gets on your hands, wash them thoroughly with
soap and water. If ink gets into your eyes, flush them
immediately with water. Keep ink cartridges out of the
reach of children and don't drink the ink.
5. Before you open the new cartridge package,
shake it gently four or five times. Then remove
it from the package.
6. Remove the yellow tape from the bottom of
the ink cartridge.
Caution:
Do not remove any other labels or seals, or ink will
leak. Do not touch the green chip on the front of
the cartridge. This can damage the ink cartridge.
7. Insert the new ink cartridge into the holder
and push it down until it clicks into place.
8. Once you replace all the cartridges that need replacing, close the cartridge
cover and push it down until it clicks into place.
9. Close the scanner.
10. Press OK to begin charging the ink. This takes
about 2 1/2 minutes. When you see a
completion message on the LCD screen, ink
charging is finished.
Caution:
Never turn off the product while ink is charging or you'll waste ink. If you see an ink
replacement message on the LCD screen, press OK and press down all the cartridges
securely. Then press OK again. If you remove a low or expended ink cartridge, you
cannot reinstall and use the cartridge.
See Page 47 in manual
Download Manual Here
Posted on May 24, 2011
I changed all my cartridges today May 18th. I still have lines going through it and there is a green tint to when printing color. Black is fine.
Have you:
1. run a nozzle check?
2. run head cleaning?
3. done head alignment?
Steps 1 and 2 are my first Epson fixup for your described problems.
May 18, 2016 | Epson Workforce 520 Printer
How do i check my ink levels?
Go To Below official EpsonPrinter Page For Your problem. How do monitor the ink levels on my Epson Stylus printer using Windows...
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Epson Printer Support
Apr 18, 2014 | Epson Workforce 520 Printer
Scanner Error - After installing 1st time Remanufacatured Ink Cartridges
Remanufactured cartridges have too many problems. I have be using refillable with auto-reset chips and never have a problem. Google- refillable cartridges and be sure to use the proper ink, dye base or pigment. It makes a difference.
Apr 09, 2014 | Epson Workforce 520 Printer
Epsom 520 printer problem
Bad printer nozzles, faulty cartridges and or ink.
Mar 19, 2014 | Epson Workforce 520 Printer
Epson WorkForce 520 Series How to check Ink Levels ?
Click on the Printer icon on the task bar and select buy ink.
Alternatively, In the Start menu select Epson>Epson Workforce 520 >Buy Ink.
Oct 25, 2013 | Epson Office Equipment & Supplies
Why doesn't my black ink work in my Epson WorkForce 600 series after replacing the black ink cartridge?
The Epson printer may only use genuine ink cartridges which contain a chip so that you cannot fill the cartridge with ink or use non genuine ink cartridges.
OR
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 01, 2013 | Office Equipment & Supplies
Epson workforce 520 won't recognise ink cartidges
When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
Feb 24, 2012 | Epson Workforce 520 Printer
Ink cartridge on epson workforce 520 is not over enough to change how to I move it
Hi, please try the following to resolve this issue.
Open the scanner unit and check for any jammed paper or foreign object that is blocking the print head movement. Then click the link below and follow the steps regarding remove and install ink cartridges in the Epson WF520 user's guide.
http://files.support.epson.com/htmldocs/wf520_/wf520_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Nov 14, 2011 | Epson Office Equipment & Supplies
4,736 people viewed this question
k24674
