Question about RCA Televison & Video
I need help programming my indoor antenna vhf,uhf,fm stereo ant119 on my 44 inch flat screen
4 Suggested Answers
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Posted on Feb 20, 2009
  • 5342 Answers
SOURCE: I bought HDTV/UHF/VHF/FM INDOOR PASSIVE
Is the antenna the correct one for your environment? Do you have the antenna pointed at the stations you want to receive? Use antennaweb.org or tvfool.com to get an idea of the location and likely channels you can receive at your location. Antennaweb assumes an outdoor antenna but is very conservative in the list of channels you can receive. (These may match the limits of the indoor antenna.) TVfool lists the stations and the appropriate antenna that will likely receive each station.
Tall trees and buildings will block the signal. Get the antenna as high as possible. Move the rabbit ears and UHF loop to maximize your signal strength. Then make sure the TV is set to use the OTA tuner (ATSC for digtal stations). (That may mean changing the source in the setup menu.)
Then scan for channels. Move your antenna or parts of it and rescan or edit the channel list. (For some TVs there is a weak signal setup option that will let you manually enter the station number (including sub-channel). Then it will provide the signal strength information as you move your antenna.)
I hope this helps. An amplifier may help you bring in weak stations with enough signal strength for the tv to see them.
Posted on Jan 20, 2011
  • 8457 Answers
SOURCE: I purchased a nexxtech VHF/UHF/FM
But the antenna u bought it is a digital antenna design though.Digital antenna design will help ur tv to getting broadcasting signals channels stronger and longer signals ranges though.
Posted on Sep 06, 2011
I purchased a nexxtech VHF/UHF/FM Indoor Antenna to bring in digital signals to my HDTV. It helps with the one analog channel that I receive (CBC), but does not bring in the other channels that should be...
Sep 06, 2011 | Televison & Video
I bought HDTV/UHF/VHF/FM INDOOR PASSIVE ANTENNA please help me to install it it is not working
Jan 19, 2011 | Philips Televison & Video
I can't get FOX on my converter box--what is the channel # for FOX?
It could be your antenna. Some retailers sold consumers UHF-only outdoor antennas and not VHF/UHF combo antennas. Other outdoor antennas may not have a power boost included for the VHF antennas (rabbit ears). The new DTV signals from stations are now broadcasting in lower power signals than before June 12.
Outdoor Antenna
KMSP/FOX 9 and KARE 11 both broadcast on VHF signals. WCCO and KSTP broadcast on UHF signals. You will need a VHF/UHF outdoor antenna to pick up KMSP and KARE 11 and also get all the other channels.
Indoor Antenna
Check your antenna to make sure it's a UHF/VHF antenna. You may need an indoor antenna that has rabbit ears -- that is the best way to get KMSP/FOX 9 reception on your TV. Your antenna should have a power boost to amplify the VHF signal if you are having trouble getting FOX 9 or KARE 11.
What Antenna Is Right For You?
Need help locating the proper outdoor antenna to receive your local television broadcast channels? Based on geographical maps and signal strengths, AntennaWeb.org locates the best antenna for you, whether it's a home satellite system, high-definition television (HDTV) or a traditional analog set.
Make sure you antenna is pointed toward Shoreview, where FOX 9 transmits from.
CALL FOX 9 FOR HELP: 952-944-9999
Apr 07, 2010 | Televison & Video
VHF channels come in however UHF channels are not
uhf and vhf tuning is performed in one board(tuner brd) there are some on line part stores that can help you with the number and price, you'll need to provide the model number. partstore.com is one of them, but there are more.good luck.
Jan 09, 2010 | Vizio GV46L 46 in. LCD Television
Since the digital switchover, I have lost channels, despite re running the setup and tuning. Any suggestions as to why this is happening?
I have a similar issue. When the digital switch happened here some of the local TV stations changed frequencies from UHF to VHF. I do not have a VHF antenna so I am unable to receive these channels. I do have a great UHF antenna, but it will not receive VHF. The fix is of course is a new UHF/VHF antenna. I am 50 miles away from the TV transmitters.
This may or may not be your problem. I hope this is helpful to you.
Bob
Nov 08, 2009 | JVC LT42P789 42 in. LCD TV
Message on screen
OTA stands for "over the air"and for a std TV it is searching for VHF/UHF signals as beamed from satellite. If the antennae is properly mounted and connection don't have any sulpher deposits, then the tuner has to be replaced. As far as the antennae, the basiscs are:
Based on this information, you need an antenna that receives high vhf and uhf. KVIE (ch 9, PBS) and KXTV (ch 10, ABC) are high vhf and not receivable with the CM 4220. I would recommend the Winegard 7694 or HBU-22 antennas. The Winegard has higher gain and is a 5 inches shorter than the HBU-22. Shorter boom length and higher gain will come in handy with an attic install. However, 7694 is more expensive ($60 vs ~$40).........................................sodeep
Sep 30, 2009 | Televison & Video
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
WHY MUST I RESCAN ALL THE TIME?
You may have several problems. If you are using a indoor antenna, upgrade to a outdoor antenna. The indoor antenna has to be adjusted every time you change a channel. If you plan to sit in a chair and never move when watching tv, you may be able to pick up a channel or two. Get a UHF/VHF antenna from a home improvement store. The big box electronic stores are selling a digital antenna. There is no such thing. The antenna doesn't know if the signal is digital or analog, it just picks up uhf and vhf signals. The other problem could be that the box is bad if it is not saving the scan. I would check the antenna first from what you said though.
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
I have a Westinghouse 26 inch TV. Model # SK-26H590D. It will not scan channel 9. I have tried both the automatic scan and the find channel scan. It is hooked to a Phillips Mant 510 vhf/uhf indoor antenna...
Feb 19, 2009 | Westinghouse SK-26H590D Television
Sanyo ds 31350 tv
Hi there!
Assuming that you tried to tune stations onto the UHF bandwidth and received nothing,Commonly the tuner box is probably at fault and needs replacement. The VHF and UHF signals are split inside the tuner so if you receive VHF fine then UHF should as well unless faulty of course. Some circuits require an external IC to do the switching, but more on the older models. Regards and good luck, JUS004
Apr 02, 2008 | Televison & Video
Televison & Video Logo
410 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
