Question about Samsung HLR5688W 56" Rear Projection HDTV
Replaced lamp, however 50% of screen continues to turn black when the TV is on a long time.
  • Samsung Master
  • 8,457 Answers
This problems it is not fixable or worth fixing because of the CRT picture tube of screen itself.Slowly dying,now the tv it is not worth a whole tv anymore if tv require a new CRT picture tube.CRT picture tube,if u can get a hold of it,most likely only can buy it from the tvs corporations themselves only and they charges u like a new tv,because the CRT picture screen it self 90% important to the tv functions itself.
Posted on May 23, 2011
How long do I have after the lamp replacement warning comes up before I have to replace the lamp?
You can use the Lamp even if the TV displays the message to replace the lamp. However, the performance of the TV, i.e the picture may become dark, entire screen may display in black after some time. If you can view the videos normally even after displaying the message, you may continue using it.
Thanks for understanding.
Feb 02, 2011 | Sony KDF-50E2000 50" HDTV
Heard a pop sound/TV screen went black but there is sound.
Pop sound would be broken lamp in tv, when did you replaced last time lamp in this tv?
Check lamp of tv that would be broken, replace it to solve your tv problem.
Let me know if you have additional question.
Thanks.
Nov 28, 2010 | Sony KDS-50A2000 50" HDTV
When i turned it on screen went black...3 lights started to blink on front of screen
The "LAMP"LED light indication flashes or stay lite?The projection lamp life is over.Replaced the projection lamp.Tv require a new projection lamp.
Oct 19, 2010 | Samsung HLN5065W 50" Rear Projection...
I have a sony kds-r50xbr1 and the problem is that it takes about 1 min to turn on and the screen appears for a bout 1-2 sec and then shuts off to a black screen where the power/standby blinks continuously...
Its time to replace lamp in this tv because existing lamp has reached to end of its working life span and causing problem. If lamp got broken, you will see lamp light lit on tv front but weaker lamp cause above symptoms.
Lamp replacement procedure is easy and written in user manual.
Buy Sony original lamp for good and bright picture in tv.
Thanks.
Jul 23, 2010 | Sony KDS-R50XBR1 50" HDTV
The tv screen turns off but sound still stays on as normal when i turn of tv and turn on it works for a short time i have had the bulb replaced but still continues any ideas
Hi,It sounds like an issue with the board that powers the lamp,it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. Good luck and have a blessed one!
Apr 29, 2010 | Samsung HLP5085W 50" Rear Projection...
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
White flashes on screen , then temporary black screen.
I would try the lamp first,if it has never been replaced they only last for up to 5,000-8,000 hours.
Jun 17, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Sony kdf-50E2000
bad lamp driver, if you have already replaced the lamp. If not, try replacing the lamp WITH AN ORIGINAL SONY LAMP!. Don't waste time with cheap replacements, you get what you pay for.
Oct 18, 2008 | Sony KDF-50E2000 50" HDTV
Samsung HLR5688W 56" Rear Projection HDTV Logo
167 people viewed this question
Jerry Greenberg
Jerry Greenberg
