Question about KEF Audio Q75 Speaker
One of my Q 75's is just not performing properly,all the drivers make sound,just not enough of it,I've swapped both speakers from right to left so it's not wiring or the reciever.No buzzing or unusual sounds,just low volumn.
  • 4,234 Answers
I have to disagree with the first response. Having the speakers out of phase will show up as decreased volume primarily in the lower frequencies and from BOTH speakers. In other words, the system will sound like there is little base or too much treble.
Internal problems with the crossover or a mechanical problem with the actual speaker drivers themselves can cause this. If you can gain access to the drivers themselves, try swapping one at a time to see if the problem moves.
Keep us posted,
Dan
Please
Posted on May 23, 2011
  • KEF Audio Master
  • 3,289 Answers
Try reversing the POLARITY of the wires on the speaker that is playing at a low volume (swap wires connected to the + and - terminals of the speakers). This would put the speaker back in phase if it were reverse connected, and provide the expected volume level again.
Vox vth120 valvetronix No sound from left speaker output
Try swapping the Left and Right speakers with the following procedure, observing correct polarity of wires:
[i] Label both speaker leads and speakers first to avoid confusion with restoring to same configuration.
L and R is good enough, masking tape suitable.
[i] Swap entire driver / lead assemblies.
Does left channel still not work?
If so then problem is amp.
If fault now swaps to R ch then amp is ok - problem external.
Return to original L&R config.
[ii] Disconnect leads at speaker ends only (power off).
Swap drivers only so leads are still same L&R but drivers now R&L.
Power up and test.
L channel fault = lead or connector fault.
R channel fault = driver fault.
With a multimeter:
Check buzzer-continuity of leads + + & - - end-to-end.
Check ohms of speakers closely match specified impedance.
Dec 19, 2017 | Audio Players & Recorders
Sound problems with an Onkyo receiver and a FIOS Set Top Box
If you are not hearing dialogue, then check your center speaker. Most voice tracks are routed to the center channel
Apr 06, 2017 | Onkyo Audio Players & Recorders
Audio device
Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps
Jan 16, 2013 | HP Compaq 6730s Notebook
Low sound output from Front Speakers
The out put transisters are probally fried for the front channels,
Nov 27, 2012 | Sony STR-DE695 Digital Audio/Video Control...
Speaker leads shorted on right rear channel of Logitech Z-5500 system
First check the speakers by connecting to front connector if thr no sound then replace the speakers.If you here sound while swap the rear amp IC might be damaged replace the IC .
Dec 19, 2011 | Logitech Z-5500 Computer Speakers
My Technics SU A700 mk2, doesn't have any signal in right channel. During (i am first owner)time I noticed that I had that right channel performance reduced arround 15% compared with the left one. ...
Have you tried cross-plugging the speaker cables (i.e. swapping left and right channels) to be absolutely sure it is the amp ? I have a speaker that needs a fair amount of volume to wake it up, but after that performs well.
Jun 15, 2017 | Cameras
I've got hp dx2480 business pc sound driver is perfectly installed but there's no sound
Right click my computer then properties then hardware then device manager then see if the sound drivers are installed properly if not installed properly you will see a question mark if disable you will see red X id disable enable the if the driver is marked with yellow question mark then reinstall the driver if the driver is installed and no marks indicated go to the speaker icon in the task bear and open the volume control and see wether mute is enabled if enabled disble them
Sep 24, 2011 | Compaq Audio card Sound Card
My laptop speaker stop working from it self
After reinstalling/installing an Operating System you can lose the Audio Drivers or sometimes they just corrupt.. Try reinstalling the Audio Drivers from the disk provide with your P.C./Laptop. If you no longer have the disk just visit the website of the makers of your P.C./Laptop or Motherboard and download the Audio Drivers from there, after that install them.
Thumbs up please if this works for you, thanks..
Aug 30, 2010 | Acer (54.AA806.001) Sound Card
Crackling noise coming from 1 channel
sounds like you are picking up some interference first try swapping out the RCA cables you are using to connect that component. also keep your RCA cables away from any 110V AC power lines.
same thing with speaker cables, speaker wire should intersect power lines at 90 degrees and should not run parallel to power lines.
many people use the wires that come with their components. these cables are thin and offer very low performance a thicker higher quality cable with a gold connector will not only better maintain the quality of the signal being transferred between components but will also have better shielding to protect the cable from picking up interference from other electrical components and power lines.
Also should point out that a blown speaker sometimes produces a crackling sound, swap your left / right speakers and see if the crackling sound still comes from that speaker if it does you have a blown / damaged component.
Dec 30, 2009 | Onkyo Audio Players & Recorders
Speaker sound is very low
Open the master volume control window by clicking the sound icon on the right hand side of your taskbar(near your clock).and check the balance is set to low for your speaker or not.try to set it at centre.
or try to update your sound driver.
Mar 10, 2009 | Sharp Computers & Internet
KEF Audio Q75 Speaker Logo
209 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Vernon Taylor
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
