AO Smith 2 hp 3450rpm 56C Frame 230 Volts Swimming Pool - Jet Pump Motor Service Fac Logo
Posted on May 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pool originally had a 2 speed AO Smith pump motor. Several years back it was replaced with an AO Smith single speed motor. I am replacing that motor with a new AO Smith single speed Centurion Switchless E-Plus 1.5 HP, single Phase ,P56J frame, 230 volt. The terminals on the old motor were burned and I had to replace the disconnects on the incoming power lines. I have black, white, red and ground. It looked like repair person before had taped off the black line and was not in use, I'm suspecting this was because switching from 2 peed to single speed motors. Which wires go to L1 and L2. Thanks Tim
John Prohaska
Level 3:
President:
  • AO Smith Master 1,378 Answers
  • Posted on May 24, 2011
John Prohaska
AO Smith Master
Level 3:
President:
Answers
1378
Questions
Helped
689214
Points
3511
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to L2...it will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
John
Capacitor is bad
Capacitor can be replaced:
Copy following link for general resources:
http://waterheatertimer.org/Color-codewire.html#motor
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Im replacing a 2 speed Hayward motor with a AO smith 1 speed motor. I need to no how to wire the 1 speed
to wire a single speed motor you use only the black, white and green wire. there is usually a wiring diagram on the side of the motor to show how this is done.
no wiring diagram then put the black wire on the L1 or H1 post and the white wire to the common and of course the green to ground
Need to replace back half of a.o smith pool motoer
Do you mean A.O. Smith motor? This is the back half of
the Pool Pump. A.O. Smith motors are the most common motor drive for household pumps, so I believe
that you can easily find the replacement. Just specify
the horsepower (HP) rating, voltage: 220/110, single
phase or three phase. Just send your e-mail comment
for more info. God bless you.
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
