Question about Lanzar VIBE 2CH 360W MOSFET AMP Car Audio Amplifier
I have a faulty MOSFET amplifier amp-360, there is power supplied to it, ground and remote are fine as well as input and output signal, there is no sound at all, i have measured the values across the positive and negative terminals and i have nothing, i was wondering which components i should be looking at as the source of the problem.
    Problem Solver:
  • 12 Answers
The power supply circuit could be defective. Unless you have a very expensive unit, it usually would cost more to have it repair then just purchase an used unit. If you are planning on fixing it yourself, chances are that you may not be able to find schematics or replacement parts for the unit.
Posted on May 23, 2011
  • 2 more comments
  • hyper_shadow May 23, 2011
    The power supply is fine, It is intended for use in a car, i have a second amp which operates fine, (Same make type model etc), i was hoping it would be a dead transistor or capacitor to be honest, that i could fix myself, if it is other components, i would be more hesitant to dive in with a soldering iron
    sorry i misread the comment, the power supply circuit is fine Ive metered it and it's all good, so it is the signal side which is dead.
  • jayngo1 May 23, 2011
    There is an inverter circuit which supply the higher voltages to the amplify circuits, the inverter is a switching power supply, with an IC driving power MOSFET transistors which then drive a transformer, and finally, the high speed rectifiers to convert the power into positive and negative supplies needed for the amplify cicuits.
    so those are the components i need to look for and test, thank you, i'll reply if i learn any more.
What is a opamp
An opamp is an operational amplifer. The OPA134 is a single amplifier with differential inputs. The best way to describe this IC is that it is an ideal amplifier with infinite gain, with high input impedance and low output impedance making it both a voltage and current amplifier. The output signal is divided with resistors and provides feedback to the minus input to inject negative feedback. The ratio of this feedback basically determines the final gain. The input signal may go to the positive input for a non-inverting amplifier or to the negative input for an inverting amplifier. Roughly the voltage gain in dB will be 20 x log of Vout/Vin. There is a difference in the gain of 1 between inverting and non-inverting for accuracy sake, but that is the basics.
This particular part is very high quality in performance and should be replaced with the equivalent part or one from Burr-Brown. The power supply is typically +/- rails and ground is usually the virtual point between the split supplies representing 0V. Sometimes the input signal will not be referenced to ground and will be fed to both the plus and minus inputs which will be balanced (impedance wise) to form a differential input that rejects common signals such as noise. Pretty cool device, I couldn't live without them. OPA134 Precision Amplifier Operational Amplifier Op Amp Technical documents
Jan 10, 2014 | Texas Instruments OPA134PA IC, AUDIO,...
Planet audio
Sounds like your power supply to the amp. Make sure you location has plenty of air flow around it and use at least 10 gauge wire to the power input. Same size on the ground and make sure all contacts are clean. Your alternator will run hot when the sound is cranked and the car is moving. The heat lowers the amperage output of the alternator and will cause the amp to cut in and out.
Nov 07, 2013 | Planet Audio PX1500M - 1500W MOSFET...
I hooked up a dual mosfet 4 channel amp and i am not getting power to it. the way it is setup is from battery to 100 amp fuse, from fuse to inside cab of truck then to 500 K farad, Split from + to power on...
Bad ground sounds like you may have paint or undercoating stopping the ground from making good contact or unhook the remote wire and run a small wire from the main power to the remote hook up and see if it works ...... May have a faulty remote
Apr 25, 2011 | Dual 2-Channel Bridgeable MOSFET Amplifier...
Is this a good amp
I classify this as a sleeper of the car audio industry. it is powerful, well built, cheap, feature laden, sounds great! very comparible to the big names such as kicker, alpine, fosgate an all the rest. i would prefer this amp over any of them any day of the week! here are the specs for it incase u didn't have them.
  • Max. Power Output: 800W x2Ch.= 1600W @2 Ohms
  • Power Output:
    • 330W x 2Ch.(@2 Ohms) Less Than 0.5% THD
    • 220W x 2Ch.(@4 Ohms) Less Than 0.3%THD
    • Bridge: 660W x 1 Ch.(@4 Ohms) Less Than 0.5% THD
  • All Measurements Done @ 14.4V DC, 1 KHz Input Signal.
  • Dual VU-Meter
  • Dual Fan Cooling System.
  • LPF (Low Pass Filter) Variable 30Hz-250Hz
  • HPF(High Pass Filter) Variable 50Hz-l KHz.
  • Slope Adjustable 12-24dB.
  • Variable Bass Frequency(30Hz-120Hz).
  • Variable 0-18db Bass Boost.
  • High & Low Adjustable Level Input.
  • Dual LED Indicated Power Status (Protect/Power).
  • Mosfet DC-DC Switching Power Supply.
  • Built-in Protection Against Short Circuit, High Temperature & Overload.
  • Auto Power On/Oft By Remote (+12V).
  • Dimensions(mm) : 300(W) x 57(H) x 697(L)
Apr 04, 2010 | Rockwood 4224RTX Car Audio Amplifier
Is it bridgeable
yes you can bridge this amp to one channel
here are the specs for the amp
  • stereo or bridged mono output
  • Tri-way capable (Tri-Way crossover required)
  • 100 watts x 2 at 2 ohms
  • 200 watts x 1 in bridged mode
  • requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
  • PWM MOSFET switching power supply
  • Intelligent Surface Mount Technology for cleaner sound and greater reliability
  • selectable 85 Hz high-pass/low-pass crossovers, 18 dB/octave
  • preamp outputs
  • speaker-level inputs with SmartEngage (turns the amp on when it detects signal from the receiver, eliminating the need for a separate turn-on lead from your receiver)
  • 9-3/4"W x 2-1/8"H x 9-3/4"D
  • Feb 06, 2010 | MTX Thunder 4202 Car Audio Amplifier
    Amp 7541a amp was working fine, Took it out of one
    REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. KEEP IN MIND, THAT DURING THE INITIAL TURN ON OF THE AMPLIFIER, THEY SOMETIMES WILL ILLUMINATE THE PROTECTION LIGHT WHILE STABILIZING THE POWER SUPPLY AND OUTPUTS, BUT AFTER THAT THEY SHOULD SHOW NORMAL POWER UP. IF YOU GET IT TO POWER UP FINE, THEN RECONNECT THE SPEAKERS AND IF STILL OK, THE RECONNECT THE RCA'S. IF IT IS STILL POWERED UP, THEN START TO TURN UP THE MUSIC. IF IT IS STILL POWERED UP AND NO MUSIC, THEN CHECK THAT YOU DEFINITELY HAVE A PROPER SIGNAL COMING FROM THE RADIO. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
    Nov 18, 2009 | Infinity Reference 7541a Car Audio...
    I cant figure out wh y my sony xplod 500w amp isnt working... i have everything connected but it still isnt wotking
    REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT POWERS UP FINE,THEN PROCEED TO CONNECT THE SPEAKERS FIRST AND SEE IF IT STILL POWERS UP FINE, THEN MOVE ON TO RECONNECT THE RCA INPUTS. AT THIS POINT YOU SHOULD HEAR MUSIC, IF NOT AND THE AMPLIFIER IS POWERED UP AND NOT GOING INTO PROTECTION, THEN YOU MAY HAVE AN INPUT PROBLEM FROM THE RADIO. IF THE AMPLIFIER FAILS TO POWER UP AT ALL AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. YOU CAN CHECK THE VOLTAGE TO THE REMOTE TERMINAL TO MAKE SURE THAT IT ABOVE 11 VOLTS, AS SOMETIMES A FAULTY REMOTE OUTPUT FROM THE RADIO CAN SOMETIME FAIL TO TURN AN AMPLIFIER ON. REMEMBER IN ANY CASE YOU ONLY HAVE AN AMPLIFIER, AN INPUT AND A SPEAKER. USE THIS PROCESS TO HELP YOU DETERMINE WHERE THE PROBLEM IS LOCATED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
    Nov 16, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    Does any one have the specs for a solid audio F2500D amplifier?
    Power Output
    RMS @ 4 Ohm: 700W x 1 Ch.
    RMS @ 2 Ohm: 1300W x 1 Ch.
    RMS @ 1 Ohm: 2500W x 1 Ch.
    RMS @ 1 Ohm: 4000W x 1 Ch @18v
    Signal to Noise Ratio: >100dB
    THD (IHF-A): 0.2%
    Input Sensitivity: 0.15V – 5V
    Input Impedance: 47KOhm
    Slew Rate: 10V/USec
    Damping Factor: 300 @ 4 Ohm
    Fuse Rating: EXTERNAL 200A Fuse
    Dimensions (in mm):
    Width: 240mm
    Height: 61mm
    Length: 570mm Features
    MOSFET Power Supply Amplifier.
    Double Sided Through Hole Epoxy PCB.
    Gold-plated Brass Set Screw Terminals.
    24dB/Oct. Crossover - Variable Low Pass Crossover (40Hz ~ 200Hz)
    Variable 24dB/Oct. Subsonic Filter 10Hz ~ 70Hz
    Variable Phase Shift
    5 Way Protections
    Daisy Chain Through Output RCA
    Bass Remote Control
    Power/Protection LED
    1 Ohm Stable Circuits
    Soft Start/Output Relay
    18V Operation
    Parallel Operation
    Nov 13, 2009 | Car Audio & Video
    Not a problem just a question
  • 100 watts RMS x 2 at 4 ohms
  • 200 watts RMS x 2 at 2 ohms
  • 400 watts RMS x 1 at 4 ohms in bridged mode
  • 4-ohm stable in bridged mode
  • Tri-Way capable
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • 50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
  • wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
  • MOSFET power supply and output devices
  • MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
  • TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
  • Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
  • NOMAD — advanced protection circuitry for "intelligent" shutdown protection
  • speaker- and preamp-level inputs
  • 11-1/8"W x 2-3/8"H x 9-7/8"D
  • Wire your sub in bridged mode (4 ohm mono)
    + to + on amplifier
    - to - on amplifier
    (using bridging terminals)
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Apr 25, 2009 | Rockford Fosgate Punch 401S Car Audio...
    NEW AMPLIFIER WILL NOT LIGHT UP OR POWER UP
    It sounds like your saying that you have two identical amp, that both are on the same power wires and remote wires and sam grounds? Well if thats the case then you did ok as One amp sounds like its blown. First tghing is check the main fuse. If its good and the unit still dosent resond then the power supply in the amp is blown as theres a switching supply that increases the 12 volts to get power to drive the Mosfet output devices. Was it ever working?? yes then the amp needs service. Do you know how to work on solid state elctronics down to componet level?? No?? Ok contact these folks at the addy im posting for you or take the amp to your local servicer. Good Luck. AudioSupport@VisonikCarAudio.com
    May 07, 2006 | Visonik VB212PKG Car Audio Amplifier
    Car Audio & Video Logo
    122 people viewed this question
    Top Lanzar Car Audio & Video Experts
    Chris Ward
    Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
